How to go over msi afterburner limits
315 (0.15/day)
Italy
System Name The Worker/ Laptop
Processor Ryzen 5 3600/ i5 1035g1
Motherboard MSI b450 Tomahawk Max / Lenovo proprietary
Cooling Arctic Freezer 33 eSport One
Memory 16Gb DDR4 3200 Mhz Corsair vengeance LPX / 12gb ddr4 3200Mhz (4gb are soldered :( )
Video Card(s) Gigabyte gtx 1660 Ti OC @2030Mhz core and 7400Mhz memory / Intel G1 UHD
Storage 1 970Evo plus 500gb, 2x250Gb Samsung 850 Evo,3 TB HDD / 250gb WD SN530
Display(s) Asus mx259h / 15.6 FHD TN
Audio Device(s) Onboard / Onboard
Power Supply CoolerMaster G750M
Software W10 64bit
Hi guys I’m here today with a question: is it possible to go over afterburner limits?
let me give you a little bit of context
I have a gigabyte gtx 1660 ti oc with hynix memory and I was able to get +1500mhz on memory clock, the max that afterburner let me adjust.
So far the card is really stable
I could also get +80 on the core (originally +150, stable but Occt scan for errors gave me a big amount of them so I stepped back to where I didn’t get any of them) and the voltage is set to stock, +0%.
I read in a post from 2011 that you could go over the max by editing the config file setting the unoficial thing to 1 and pasting a line “I have read and I‘m aware of ....’ . I tried back in 2019 and it did nothin.
i don’t want to go extreme but It would be fun to play around a little more, If it is possible at all
315 (0.15/day)
Italy
Software W10 64bit
Regeneration
NGOHQ.COM
3,139 (0.44/day)
I was talking about the memory limit. Always best to overclock manually.
Use Final Fantasy XV Benchmark to stress test the video memory.
155 (0.08/day)
System Name Locutus TT P90 open air case
Processor Intel I7 12700K
Motherboard Asus Z690 WIFI D4
Cooling NZXT 280 mm AIO
Memory 32 Gig Corsair Vengeance 3600 DDR4
Video Card(s) Zotac 3080 Holo LHR
Storage 3 various branded SSDs and 6 TB Seagate HD
Display(s) LG 32'' g-sync 144 Hz VA IPS
Case P90 open air case
Power Supply EVGA G2 1 KW
Mouse Logitech G900
Keyboard Corsair Strafe
Software Win 11 Pro
Custom BIOS should do the trick.
315 (0.15/day)
Italy
Software W10 64bit
I also thought this but I don’t really want to do it cause my card has still warranty
i prefer something easy that won’t hurt the card much like a possible brick
19,378 (3.50/day)
Then you're stuck AFAIK. it's a bios flash with a higher limit or hard mods...
315 (0.15/day)
Italy
Software W10 64bit
Dang thats not great... also because my card is not so cool in winter and in summer is about 80C
19,378 (3.50/day)
80C is appropriate for that card.
But you're confusing... you asked intially about raising the limits.... but out of the other side of your mouth you complain about temperatures? You're aware raising limits and voltage will increase temps, right?
That said, you dont need to mod anything to lower the power limits and voltage to get lower temps (or change the fan curve).
315 (0.15/day)
Italy
Software W10 64bit
Oh it’s just me that doesn’t feel comfortable with that temp?
18,584 (2.66/day)
System Name AlderLake
Lower GPU temp is better , it will maintain a higher boost clock.
315 (0.15/day)
Italy
Software W10 64bit
Nono I understand well that an Oc of any kind will raise temps but At least in my case memory oc doesn’t rise them significantly. My worry is that if I flash another bios in any case I will have worse temps even If I set voltage and power limit as the ones I have now
Exactly... I could get 80mhz or boost with current temps, thats why I want to avoid things that will increase them
19,378 (3.50/day)
if the bios edits the voltage table higher, of course it would. More voltage = higher temps.
While it is true lower temps = higher boost bins, you arent going to get 80MHz out of a few C. Now... going water amd dropping 20C...maybe.
315 (0.15/day)
Italy
Software W10 64bit
Yeah but it’s not really worth. I’m fine with the performance I get, I would have liked to play a little bit more but I don’t wanna risk.
after all the max I can get is 2060 performance, which I’m close in some games.
21,812 (3.41/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4000 (Running 1:1:1 to FCLK)
Case Thermaltake Core X31
Software Gentoo Linux x64
23,350 (6.12/day)
A strong OC on air involves temperature and temp ONLY, from my experience. I get higher clocks and better perf from my 1080 at 90% power target than I do at 110%...just because across the whole voltage curve you have lower temps so at every load you lose less boost bins. Its not just the top end of clocks, but the curve that is easier to handle.
If you can stick below 80C at prolonged use at full utilization, thats where it caps out temp wise, and it is built to do so. Its how Boost tries to max performance.
