How to make Radeon Additonal Settings reappear!
2,707 (0.76/day)
On The Highway To Hell \m/
Just wanted to post the "magic" fix for the Radeon Additional Settings disappearance bug for everyone here.
The problem: Open AMD Radeon Settings. Click Preferences, then Radeon Additional Settings. Radeon Additional Settings cannot be started. :confused:
The solution:
I searched high and low until I found the following post.
http://forums.guru3d.com/showpost.php?p=5382651&postcount=55
Nothing else I tried worked until I finally did as instructed therein. It's been broke in all versions of AMD Radeon Crimson ReLive Drivers 16.12.1 WHQL and later. Well not 100% broke, as your previous settings will still be applied when installing new drivers(although if you clean install they won't). But the GUI to change(or reapply) them is(was) no longer available. Unless you install the ccc-next64(or ccc-next32 for 32 bit OS). And then PRESTO! There they are again! Cool huh?
You're welcome! :D
86 (0.02/day)
Alberta, Canada
System Name Fluffy
Processor Ryzen 7 2700X
Motherboard Asus Crosshair VII Hero Wi-Fi
Cooling Wraith Spire
Memory 32Gb's Gskill Trident Z DDR4 3200 CAS 14
Video Card(s) Asus Strix Vega 64 OC
Storage Crucial BX100 500GB SSD/Seagate External USB 1TB
Display(s) Samsung CHG70 32" 144hz HDR
Case Phanteks ENTHOO EVOLV X
Audio Device(s) SupremeFX S1220 / Tiamat 7.1
Power Supply SeaSonic PRIME Ultra Titanium 750 W
Mouse Steel Series Rival 600
Keyboard Razer Black Widow Ultimate
Software Open Office, Win 10 Pro
16.12.2 No bug here?
1,181 (0.17/day)
Processor 7900
Motherboard Rampage Apex
Cooling H115i
Memory 64GB TridentZ 3200 14-14-14-34-1T
Video Card(s) Fury X
Case Corsair 740
Audio Device(s) 8ch LPCM via HDMI to Yamaha Z7 Receiver
Power Supply Corsair AX860
Mouse G903
Keyboard G810
Software 8.1 x64
Same here, works fine for me.
2,707 (0.76/day)
Yeah I don't know why it happens or doesn't. But there's a bunch of us that were(or probably still are) having the problem. For whatever reason(s). I was pulling my hair out in frustration trying to fix it myself. Lucky you if you weren't. That's all I can say! ;)
1,181 (0.17/day)
Processor 7900
Cooling H115i
Case Corsair 740
Mouse G903
Keyboard G810
Software 8.1 x64
Did you do a fresh install? I've just been updating so maybe thats why its still working.
2,707 (0.76/day)
That's funny you ask. Because I just editted the OP regarding that. I was just updating. Which kept and applied my old settings. So at first I didn't even know the additional settings panel was gone. It was only after clean installing the latest version that I found out they were missing. Since clean installing deletes your previous settings. Then I had to system restore to get them back. And after installing every version since 15.something, I figured out when it broke. 16.11.5 was the last one that worked for me.
1,181 (0.17/day)
Processor 7900
Cooling H115i
Case Corsair 740
Mouse G903
Keyboard G810
Software 8.1 x64
I guess I need to do a clean windows install soon.
551 (0.10/day)
System Name AMD RyZen PC
Processor AMD RyZen 5950x
Motherboard ASUS Crosshair VIII Hero 570x WIFI
Cooling Custom Loop
Memory 64GB G.Skill Trident Z DDR4 3200 MHz 14C x4
Video Card(s) Evga 3080 TI
Storage Seagate 8TB + 3TB + 4TB + 2TB external + 512 Samsung 980
Display(s) LG 4K 144Hz 27GN950-B
Case Thermaltake CA-1F8-00M1WN-02 Core X71 Tempered Glass Edition Black
Audio Device(s) XI-FI 8.1
Power Supply EVGA 700W
Mouse Microsoft
Keyboard Microsoft
Software Windows 10 x64 Pro
They should add it to the radion tool instead of this workaround. I don't understand how hard is it... I had created a tool long back with AMD display lib with all this settings. I wish they add it to radion software
42,050 (6.62/day)
