How to Modify RX 5600 OEM VBIOS?
460 (0.31/day)
Earth, Solar System, Milky Way Galaxy, Local Group
Processor AMD Ryzen 7 5700X
Motherboard Asus TUF Gaming B550M-Plus (Wi-Fi)
Cooling Thermalright PA120 SE; Arctic P12, F12
Memory Crucial BL8G32C16U4W.M8FE1 ×2
Video Card(s) Sapphire Nitro+ RX 6600 XT
Storage Kingston SKC3000D/2048G; Samsung MZVLB1T0HBLR-000L2; Seagate ST1000DM010-2EP102
Display(s) AOC 24G2W1G4
Case Sama MiCube
Audio Device(s) Somic G923
Power Supply EVGA 650 GD
Mouse Logitech G102
Keyboard Logitech K845 TTC Brown
Software Windows 10 Pro 1903, Dism++, CCleaner
Benchmark Scores CPU-Z 17.01.64: 3700X @ 4.6 GHz 1.3375 V scoring 557/6206; 760K @ 5 GHz 1.5 V scoring 292/964
Hey guys. Recently I've been lucky enough to get a Dell-branded RX 5600 (OEM) graphics card. But its frequency is limited to 1820 MHz in the same way as the RX 5600 XT. When I tried to modify it with RedBIOSEditor, the GPU ID function doesn't work because it doesn't recognise this model I suppose. So, is there some way to modify its VBIOS, or simply remove its frequency limit?
Here's the link of this card:
573 (0.35/day)
Florida
Processor 5800x3d
Motherboard MSI Tomahawk x570
Memory 32 gb 3200mhz E die
Video Card(s) 3080
Storage 2tb nvme
Display(s) 165hz 1440p
Case Fractal Define R5
Power Supply Toughpower 850 platium
Mouse HyperX Hyperfire Pulse
Keyboard EVGA Z15
Extract the bios with GPUz then use MorePowerTool to change frequency/power limit/voltages.
460 (0.31/day)
Case Sama MiCube
Mouse Logitech G102
Thanks. But I've tried and it doesn't work. Frequency limit is written in VBIOS and can't be removed by register-level changes.
42,008 (6.62/day)
You may need to reference Igors lab
460 (0.31/day)
Case Sama MiCube
Mouse Logitech G102
Thanks. And yeah I did, but that snapshot is the result... GPU ID function doesn't work 'cause it doesn't recognise it. :(
460 (0.31/day)
Case Sama MiCube
Mouse Logitech G102
Hello? But nobody knows the solution?
42,008 (6.62/day)
460 (0.31/day)
Case Sama MiCube
Mouse Logitech G102
42,008 (6.62/day)
Damn bro. That's a whole different new level:( risk is much hhhhhhigher. I guess I'll try
I wouldnt bother unless if you have a spi programmer and know how to use it
Yeah lowest the RBE goes is 5600XT it would seem.
460 (0.31/day)
Case Sama MiCube
Mouse Logitech G102
2,982 (4.73/day)
Russian Wild West
System Name DLSS / YOLO-PC
Processor i5-12400F / 10600KF
Motherboard Gigabyte B760M DS3H / Z490 Vision D
Cooling Laminar RM1 / Gammaxx 400
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333
Video Card(s) RX 6700 XT / R9 380 2 GB
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD
Display(s) Compit HA2704 / MSi G2712
Case Matrexx 55 / Junkyard special
Power Supply Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup]
Software Windows 10 and 11
The main concern in RX 5600 XT is VRAM speed, not the GPU one. 1820 MHz is perfectly fine for this GPU.
Focus on getting max performance from your VRAM. 192 bit bus paired with 12 GHz GDDR6 is far from ideal...
460 (0.31/day)
Case Sama MiCube
Mouse Logitech G102
I tried 1750 MHz on this card but it's not stable. I don't think that should happen...
