How to properly upgrade to a better GPU? And some PSU wattage help.
340 (0.12/day)
Processor 8700k OC @ 5GHz (1.35 V)
Motherboard ASUS Prime Z390-A
Cooling Corsair H100i v2
Memory 16GB DDR4 OC @ 3000MHz
Video Card(s) EVGA RTX 2070 XC Ultra
Storage 4 x 250GB PNY SSD & WD BLACK 1TB HDD
Display(s) Samsung UHD 4K / BenQ RL2455HM
Case NZXT H500i
Power Supply Corsair 750W
Just to start off, I must say I really only play CSGO and Minecraft so I don't need a beast GPU.
Currently, I have a GT710 installed with GeForce Experience drivers. Next week I would like to upgrade to a GTX750Ti. How should I do this, should I uninstall all NVIDIA software and then switch to onboard GPU for the new drivers, or just pop in the new card?
Also, I am stuck with a proprietary PSU non ATX format, and it is a 320W 90% efficiency. The PC is a rather beastly HP ELITE 8300 CMT. Would I be able to run a low power 75W GTX 950?
Thanks friends.
19,368 (3.65/day)
What are the rest of your specs (CPU, memory, etc)?
Can you post a picture of the label on the PSU? What is crucial here is knowing how many Amps are on the 12V rail.
Chances are, you can go to a GTX 960 pretty easily. I wouldn't go less than that for 1080 gaming, CSGO and minecraft considered. I assume you have a 6 or 6+2 pin PCIe connector from the PSU, righT?
340 (0.12/day)
Case NZXT H500i
http://imgur.com/8p09Lfx
That's the PSU label. I do not have any GPU power connector so I was looking at the bus powered cards. Specs are listed under my pc specs.
Thank you!
43,593 (6.64/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
To upgrade to a new card, with your old card still in your system uninstall your drivers via the Control Panel. Then run DDU (Display Driver Uninstaller) in safe mode (there's an "upgrade/install new GPU option" use that). Power down, install new card, boot up and install the latest drivers.
You can get DDU here: http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
340 (0.12/day)
Case NZXT H500i
19,368 (3.65/day)
2,058 (0.70/day)
System Name AM4 / 775
Processor 2600x / C2D E7600
Motherboard B450 Aorus / ASUS P5G41C-M LX
Cooling TT Esports Duo / Chinesium cooler
Memory 16GB DDR4 3ghz / 4GB DDR2 800mhz
Video Card(s) 2060 Super / 5700-XT / GTX 650Ti
Storage 120GB + 1TB SSD / 160GB SSD
Display(s) Samsung CRG5 144hz QD
Case CiT shit chassis modded / Coolermaster Elite 430
Audio Device(s) Soundblaster FX / Audigy 2 ZX
Power Supply Superflower Leadex III GOLD / BeQuiet 450w bronze.
Keyboard Read Dragon Kumara
Benchmark Scores 1 Billion
His PSU is a HP 320 w with 16AMPS maximum.
19,368 (3.65/day)
Whoa.. didn't click on the link...
750ti...I guess... that's a shame...it's an incremental upgrade.
950 is probably pushing it...
340 (0.12/day)
Case NZXT H500i
I see. So It is not worth pushing for a low power GTX 950 and I should stick to a 750Ti?
19,368 (3.65/day)
Sorry, you mentioned a low power one... 75W and what CPU is in there?
EDIT: HOLD THE PHONE... your PSU picture says the 12vMAIN and 12vCPU shall not exceed 320W. It shows, if its a dual rail (likely single no OCP), that there are up to 16A on each rail... not to exceed 320W. Id easily run a full power 950 or even a GTX 960(120W) with a stock CPU... I bet that wouldnt break 200W total with both running full tilt. ;)
Someone confirm I am not blind there...
340 (0.12/day)
Case NZXT H500i
Yeah a 75w GTX 950 would be ideal. I have a Core i5 3470 @ 3.2 GHz
Someone please confirm that EarthDog is correct so I can buy this 950 :D:D:D
Toothless
Tech, Games, and TPU!
9,389 (2.50/day)
Washington, USA
System Name Veral
Processor 5950x
Motherboard MSI MEG x570 Ace
Memory 4x16GB G.Skill TridentZ
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
I'd get a RX460 if possible. The power in that little thing is pretty damn good though a decent PSU might be needed, not sure.
340 (0.12/day)
Case NZXT H500i
I can get a good deal on the low power ASUS GTX 950. Can anyone confirm I can run this with EarthDog's info?
19,368 (3.65/day)
I have said multiple times you can run a low power 950 with no issues. I am trying to have people double check you can run a 960 on it. I am 90% sure you can. So again, yes a 950 will be fine.
340 (0.12/day)
Case NZXT H500i
perfect. thank you buddy.
340 (0.12/day)
Case NZXT H500i
I just want to make sure I am not stressing this PSU too much to where it starts to heat up and whine!
340 (0.12/day)
Case NZXT H500i
340 (0.12/day)
Case NZXT H500i
I see. I was worried that the new GPU would over stress my PSU causing system failure down the road.
8,077 (1.38/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
You have 320 watts to work with. Your CPU takes 95 watts. Even if the rest of your system takes 50 watts, you still have 175 watts for a GPU. (No, I didn't say you can run a 175 watt GPU)
A GTX 750 Ti or bus powered GTX 950 is a no brainer - they'll work. (and I'd think that a GTX 950 is all you need)
A GTX 960 might work, you just have to see if you have a connector or 2 that you can use an adapter with to power it.
340 (0.12/day)
Case NZXT H500i
Thank you man. Really appreciated. Another forum is telling me I need at least a 500w PSU. They are saying my gaming keyboard mouse with LEDS and my Elgato HD60 (USB2.0) that I use to stream will make cause the system to draw more than 320w. Is this correct, or are they idiots? lol
8,077 (1.38/day)
Hillsboro, OR
System Name Main/DC
Just do it.
Edit: There's always a chance that a proprietary system such as yours does something that we can't expect. But it should work.
Edit2: Went looking for that PSU. It appears that it comes with a 6 pin PCI-e connector. Link Not sure what they're doing...
