How to refill an AIO ? (Cooler Master Nepton 240M)
Mr.Quinster
2 (0.00/day)
I have this Cooler Master Nepton 240M for 5 years now and is out of warranty. It is making weird noises because of bubbles. I saw there was a cap on it with void warranty so i thought this must be the refill cap. But after a long time of prying it still hasn't opened up. Has someone done this before because i cant seem to find any yt videos on these cooler master models being refilled.
7,469 (1.47/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Put it up so the vent is at highest point. Pour in some coolant.
8,104 (3.92/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
You're not going to get that fill port off without trashing the radiator. It's likely glued or soldered and if you twist it too hard I'd put money on the end tank cracking before the filler cap moves. Don't search for YT videos of people refilling a Nepton 240M, look for videos of people replacing the tubing on AIOs. You'll get more examples and tips that way.
The only way to refill most of these AIOs is to remove tubing (it looks like you should be able to cut the existing hose off) and replace it with the standard clear tubing and hose clamps as used in most custom loops. Not only will you be able to see bubbles, you'll be able to tell when it's time for new coolant. As for tubing diameter, you'll probably want to cut off the existing tubing first and measure the barbs on the block and radiator - go for the closest ID tubing that is smaller than the barbs and use dish-soap to lubricate the new tubing so that it fits. If it were me, I'd add a T-piece and a valve or end cap to make refilling and bleeding it a 2 minute job (instead of a 2-hour job) the next time you need to do it.
You'll want to drain the system completely, flush it as much as you can in reverse to try and de-gunk it and then refill with anti-corrosion inhibitor and biocide because you'll be dealing with mixed metals in an AIO. Too much anti-corrosion and your system will gunk up, too little and it'll corrode - so follow the instructions on the bottle carefully!
https://www.aquatuning.co.uk/water-...8/phobya-2-way-ball-valve-g1/4-knurled?c=2672 - an example of what I'd use as a fill port off a T-piece.
Mr.Quinster
2 (0.00/day)
Thanks for the fast responses guys! You have really helped me, i am now going to the hardware store to get some new tubing.
19,371 (3.58/day)
Buy another aio....
...part of the reason users buy an aio is because they tend to have less chance of leaking than a custom loop. If that is a concern and you cant get the fillport open, , go buy another. It lived a good life.
294 (0.05/day)
Saigon city
System Name Kurise PC
Processor i7 5820k 4,7ghz / Ryzen 1700x 4ghz / 8700k
Motherboard Asus X99 deluxe / MSI x370 gaming pro carbon / z370i strix
Cooling EK evo, xspc slim 360 rad, D5 pump, dual alpha cool GPU mono block, dual xspc 240 radiator, DDC 18w
Memory Crucial sport white 16gb x 8 128gb 2666mhz/ Crucial sport white 16gb x 4 64gb 2933 / ddr4 chinese 32
Video Card(s) GTX 1080Ti SLI / HP gtx 1080 SLI 1850/1520 / 2080ti ref
Storage Lite on 512GB x 3 / Plextor m2 256gb / samsung 970 evo
Display(s) AOC I2769Vm, AOC U3477PQU, AOC I2769Vm / Koios 40''/ eizo EV2730QFX 1:1
Case Xigmatek Elysium / Corsair 750D / Bitfenix prodigy M
Audio Device(s) creative blaster ZX / Blaster ZXR / Blaster x7 lmt + burson v5i upgraded
Power Supply Be Quiet 1200 / Thermaltake toughpower 1200w / chinese 750w sfx PSU
Mouse Asus Echelon/ steelseries black ops II/ james donkey
Keyboard Cm storm quickfire pro / Fire rose steampunk kb/ corsair k70
i just open my aio block and fill it , close it, let it run if any noise happens i stop it then open it up and refill . I'm using DIY AIOs for my 5 rigs no leak so far since i use all aluminum ( aluminum plated block, aluminum radiator and silicone tube )
sneekypeet
not-so supermod
29,485 (4.36/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
The easiest way into an aio is through the cold plate, if you have the proper tools, as mentioned above.
JKo
3 (0.00/day)
This is probably too late for your needs, but for future reference... the Nepton has a rubber plug under that "warranty void if removed" sticker, and under the plug there's a screw with a regular phillips head (pic below). Just pry off the rubber plug with a small screwdriver or with a small knife and undo the screw to empty/rinse/refill. Definitely not the fastest way to do it though, took at least 2 hours with my Nepton 120XL. If I ever need to do it again I'll definitely add a T-piece to the tubing to let out air from one point while pushing water in from another.
The liquid that came out was very clean, smelled like regular anti-freeze from a car, and had a greenish tint to it. It wasn't even nearly full after being in use for over 5 years. You could hear that there was air in there when it was running, and cpu temps were creeping up. I rinsed it with distilled water (no gunk came out), then filled with 1/3 anti-freeze mix that should be good for mixed metals.
8,190 (2.19/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
I have the same cooler, its been 6 years and it seems to be still going strong. I think after reading this thread I'll see about refilling it.
hat
Enthusiast
21,745 (3.32/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
I agree with the others. Cut the hose off, get new hoses and clamps, and add a T piece. Or a reservoir. A res will make filling it back up a shitton easier and it will improve temps, too.
4,213 (0.72/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
You could also just place it so that the tubing on the rad is at the bottom. Even with limited liquid, it'll work well enough and not be noisy.
The amount of liquid in the cooler 'should' be a huge deal as they work based on the thermal transfer properties, rather than the specific heat capacity.
I have an old Seidon that is 5+ years old and am running that way. My only concern would be when there isn't enough liquid to form a complete loop.
2,963 (0.85/day)
Long Island
With all copper OLC Type AIOs being available for as long as they have, I don't understand why CLC usage has continued... Corrosion inhibitors have a useful life of 18-24 months. Changing the coolant doesn't remove the crud.
https:// www.youtube.com/watch?reload=9&v=a_r4tWpMHHI
For those interested in the science
de.das.dude
Pro Indian Modder
8,936 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
ah a man of culture who has watched the GN video too.
Guys, wont getting the tubes off be harder?
that is from 2012. a lot has changed since then. AIOs now have a shelf life of 6 year.
Also distilled water doesnt cause galvanic corrosion. ALSO.. copper and aluminuim quickly oxidizes and creates a protective layer around itself which inhibits galvanic corrosion.
Im pretty sure the blocks and rads spent enough time exposed to the air to develop that layer.
Deleted member 24505
Take a pipe off, submerge it in fluid till its full, put pipe back on, clamp it
1,819 (0.72/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@de.das.dude
guess it has eluded you that OLC (AIO) are now in the same price range as CLC, while they will offer easier flush/refill/part replacement/top-off etc,
not even talking about EK/Alphacool etc using copper rads, removing alu from the loop/
So outside the Corsair stuff (5y warranty that covers ANY damages to the pc),
or some ultra cheap build, not making sense to stick with CLC.
de.das.dude
Pro Indian Modder
8,936 (1.71/day)
VR HMD ;_;
@de.das.dude
unfortunately, thats not the same everywhere. And not everyone is an american
1,819 (0.72/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
@de.das.dude
never said it, nor did i mention a price, but its also not the minority (with decent prices) on this planet that can get decent prices on HW.
how about Europe with places that have higher import/vat fees,
germany (20% vat) lists 240s from Corsair and the like for 80E, the Eisbaer is 88E,
thats not even 10US$ more to have 1. a res with window , 2. copper rad, 3. a pump with adjustable rpm, 4. "standard" G1/4 parts.
JKo
3 (0.00/day)
For me refilling the Nepton 120XL meant that I didn't need to spend way over 100€ (here in Finland with 24% vat) on an adequate new cooling solution that would fit in my mini-ITX case. Also rotating the rad so that the tubing is at the bottom is not possible without some heavy modifications.
Definitely going for an OLC with a copper rad if the Nepton can't handle the next cpu upgrade, or if the pump finally fails.
8,104 (3.92/day)
Case Veddha T2
Mouse MX Anywhere 2
Ugh, this thread's been necro'd and I'm getting pinged.
Yeah, you can get the manufacturer's fill port screw undone but it's a self-tapping thread so once you've undone it and re-tightened it you've lost the seal and you'll get air in the system over the coming weeks/months. I guess you can tighten it even harder to get another seal but there's only a very limited number of times you can do that (like, 0-2 times) before it's stripped and you have to trash the whole thing.
JKo
3 (0.00/day)
Interesting, it didn't look like a self tapping screw to me on the Nepton. I could be wrong tho. It did have a washer type rubber seal on it, so it's not relying on the threads alone.
Anyway, I undid it and retightened it maybe three or four times in my bleeding process. I guess I'll find out soon enough if it's fubar'd.
PS. Loving your avatar. For great justice.
8,104 (3.92/day)
Case Veddha T2
Mouse MX Anywhere 2
OK no, if it has a rubber washer it's because it's a regular screw and compressing the washer is what provides the seal - that's very much a re-usable design.
I guess it's possible that the port designs aren't identical between different models, or that CM have revised the design since I did a teardown on an old Nepton about 3 years ago. Mine was either soldered or just self-tapping because for whatever reason it gouged a huge chunk out of the radiator and stuck to the screw. Worked for me anyway as the radiator was the part of the AIO that I was trying to swap out from a 240mm to a 140mm one.
  • Like
Reactions: JKo
