How to resolve Nvidia OpenGL DrvSetContext failed functionality indeterminant
7,307 (1.04/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
I recently with the newest Nvidia GeForce driver version 566.36 been having this "Warning" showing up in Event Viewer in Windows 11 and a quick google looks like Nvidia needs to fix their driver to play nice with iGPUs!
This was the warning I received:
There are 2 solutions to fix this problem from my research.
Solution 1. Disable your AMD or Intel iGPU in the bios (If you don't use it for anything).
Solution 2. Install a "Driver only" for the iGPU with no AMD Adrenaline or Intel Graphics Command Center.
I have done the solution 2 since why I do not want to disable the igpu for my AMD Ryzen 7 7700 because if I need it sometime I do not want to troubleshoot why it's not working.
I use a Nvidia driver made with W1zzard's NVCleanstall but the stock one produces the same error for many people so Nvidia needs to allow iGPU because if anyone uses like AMD or Intel Graphics for Adobe, Encoding or something else it would be nice to have the control panel for the igpus available.
Not sure if this error happens on laptops since many of them is hybrid with igpus and dedicated graphics they might play more nice together.
42,684 (6.68/day)
You already put a ticket in with nv?
7,307 (1.04/day)
Nope I haven't really thought about it.
I thought it was more important to write a solution to resolve this issue here on TPU than creating a ticket with NV :D
