How to restore default GPU clock after an OC?
114 (0.02/day)
Philadelphia
So I have has slight improvements when overclocking my ASUS GTX 950 Unplugged. However, I wanted to go back to stock performance. I uninstalled Afterburner, is that all I had to do to make sure the OC is totally gone?
Also, just for testing sake I set everything to MAX in afterburner and my PC froze under load, could I have done permanent damage to my new GPU?
12,311 (2.29/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
You can use GPU z to see if your at stock https://www.techpowerup.com/gpuz/
I doubt if you permanently damaged anything but it does happen. Overclock at your own risk
114 (0.02/day)
Philadelphia
Okay, so it is possible for the overclock to be there even if Afterburner is not?
fullinfusion
Vanguard Beta Tester
9,909 (1.62/day)
No but experience shows me on an AMD card using be it trixx or ab some shit remains even after reverted back to stock. Best bet is to remove the driver and re-install.
Ruru
S.T.A.R.S.
12,375 (2.87/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X
Cooling Arctic Freezer 50, GPU with custom loop
Memory 32GB Kingston HyperX Fury DDR4-3200
Storage 256+240+128+480+2x1TB SSDs + 3TB HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p144
Audio Device(s) Corsair HS35
VR HMD Oculus Rift CV1
The chance to damage hardware with overclocking is about non-existent if running with default voltages.
141 (0.04/day)
Winnipeg, Canada
System Name I overclock AMD setups
Processor AMD 8320+ @ 4.95GHZ / AMD 6300 @ 4.8 Ghz / AMD 8350 @ In RMA
Motherboard Gigabyte 990FXA-UD3 / Gigabyte 970-D3P
Cooling Corsair H100
Memory 16GB DDR3 Corsair Vengace
Video Card(s) MSI GAMING GTX 980 @ 1545Mhz core
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer 144hz
Case Coolermaster CM 690 III (White Version)
Audio Device(s) Creative Titanium Fatality Pro
Power Supply Corsair Hx750i
Mouse Logitech G300s
Keyboard Microsoft Digital Media
Software Windows 10 64
Benchmark Scores 23.0k on Skydiver, 8.1k on Firestrike. 1.5k single, 9.7k multi CPU-Z
Even when going over stock most GPU BIOS's are limited to a voltage that would not cause damage.
I've never seen a GPU die in my 15 years of system building. I've seen green and white lines running across the screen, nothing an oven @ 375'F can't fix.
Kanan
Tech Enthusiast & Gamer
3,517 (1.05/day)
Europe
System Name eazen corp | Xentronon 7.2
Processor AMD Ryzen 7 3700X // PBO max.
Cooling Noctua NH-D14 SE2011 w/ AM4 kit // 3x Corsair AF140L case fans (2 in, 1 out)
Memory G.Skill Trident Z RGB 2x16 GB DDR4 3600 @ 3800, CL16-19-19-39-58-1T, 1.4 V
Video Card(s) Asus ROG Strix GeForce RTX 2080 Ti modded to MATRIX // 2000-2100 MHz Core / 1938 MHz G6
Storage Silicon Power P34A80 1TB NVME/Samsung SSD 830 128GB&850 Evo 500GB&F3 1TB 7200RPM/Seagate 2TB 5900RPM
Display(s) Samsung 27" Curved FS2 HDR QLED 1440p/144Hz&27" iiyama TN LED 1080p/120Hz / Samsung 40" IPS 1080p TV
Case Corsair Carbide 600C
Audio Device(s) HyperX Cloud Orbit S / Creative SB X AE-5 @ Logitech Z906 / Sony HD AVR @PC & TV @ Teufel Theater 80
Power Supply EVGA 650 GQ
Mouse Logitech G700 @ Steelseries DeX // Xbox 360 Wireless Controller
Keyboard Corsair K70 LUX RGB /w Cherry MX Brown switches
VR HMD Still nope
Benchmark Scores 15 095 Time Spy | P29 079 Firestrike | P35 628 3DM11 | X67 508 3DM Vantage Extreme
Reset Afterburner clock settings before deleting it makes sure nothing is left behind.
522 (0.16/day)
Beachy Gulf Beach
System Name RadActive Dragon & Black Dragon
Processor i7 5960X & 1090T
Motherboard Gigabyte X99-UD3P & Asus Sabertooth 990FX
Cooling EK EVO & Corsair H50
Memory GSkill TridentZ 32GBs 3200MHz & Vegeance 8GBs 1600MHz
Video Card(s) 2x 980Ti & 960 FTW
Storage Samsung Pro 256GB & Intel 120GB
Case Heavy modded Haf X & NZXT Apollo
Power Supply AX1200 & AX1200i
Software Windows 7 & Ubuntu 15.04
Yeah, there is reset button on AB. Just hit that and you are good to go.
292 (0.10/day)
You can use MSI Afterburner or the integrated AMD software to reset to default. In MSI Afterburner there is a 'reset' button. That 1100 core clock might be the boost clock for the GPU and if it is, it's perfectly normal.
Evans Young
7 (0.00/day)
If you are not too sure that your overclock is gone, simply uninstall the vga drivers, do a restart and reinstall the drivers. By this way everything will be cleard definitely
218 (0.06/day)
Virginia, United States
Processor Intel i7 4790K
Motherboard Gigabyte Z97X-UD5H-BK
Cooling LEPA AquaChanger 240
Memory G.Skill Ares Series 16GB (2 x 8GB) DDR3-2133
Video Card(s) EVGA GTX 980 Superclocked ACX 2.0
Storage Seagate St1000dx001
Case Cooler Master HAF X ATX Full Tower
Power Supply EVGA 850W ATX12V / EPS12V
Even with vBIOS mods most cards have a physical limiter as well.
I think pretty much (for Nvidia) any 9xx and above is pretty much go crazy, I don't think you can kill these cards without TRYING to do so.
And yet despite saying that, I still feel obligated to say:
This is my opinion and my opinion alone, it is not my fault if you fry your card.
522 (0.16/day)
Beachy Gulf Beach
O, I come across people who have manage to kill 9xx cards.
Either by bricking them with BIOS mods or pushing them hard enough to the point the card dies.
