how to restore pc from recovery partition
654 (0.10/day)
India
System Name HP envy 17 3090nr
Processor Intel core i7-2670QM 2.2ghz
Memory 8gb
Storage 1TB
Software Genuine Windows 7 Home Premium
Benchmark Scores Windows experience index 6.9
Hello,
I've hp dv 6226tx.
I've ost my recovery disks and i need to reinstall windows vista in my laptop.
it has d: as recovery partition, nut i had created 3 other partition too in my hdd.
is it possible to restore my laptop using this partition? if yes, how?
I've tried F11 but it does nothing and F10 leads to bios setup.
Thanks.
newmodder
669 (0.10/day)
british columbia
System Name Gamer
Processor amd phenom quad core 9950 black edition
Motherboard msi ms-7309
Cooling 120mm front,120mm rear
Memory 2gigs ddr2 800
Video Card(s) BFG gtx 260 maxcore
Storage wd 160gig sata2 hd
Display(s) LG 20in widescreen
Case USP 100
Audio Device(s) onboard Logitech x-530 5.1 spkrs
Power Supply Antec Neo 550watt
Software windows 7 Ultimate 64 bit
The first thing you should do is backup any important data, such as pictures, music files, favorites, and anything important that you've saved since purchasing the computer. All new data will be lost and the system will be returned to factory condition.
Next, you'll want to unplug any external devices, such as USB printers, cameras or scanners. These devices could interfere with the recovery process.
There are a couple of ways to reach the recovery screen. The easiest will be to tap the F10 key repeatedly when booting the PC. This will take you to a screen to begin the process. Or, once in Windows, you can go to Start>All Programs>HP Tools>HP PC System Recovery.
Follow the onscreen instructions. The process may take an hour or two depending on the size of the hard drive. Once complete, your HP computer should be reverted to the original factory condition.
654 (0.10/day)
India
Memory 8gb
Storage 1TB
I think you've not read my whole post. :(
I've formatted OS partition and other OS now on that partition, so no HP software in it..
and on pressing F10 it leads to bios setup, not recovery setup. even F11 isnt working..
but i can see recovery partition in my hdd. i've total 4 partitions in my hdd.
newmodder
669 (0.10/day)
british columbia
System Name Gamer
Case USP 100
sorry..missed that part...go into bios and select the restore partition as first boot device, and see if that works, if not you will need a operating cd
654 (0.10/day)
India
Memory 8gb
Storage 1TB
i didnt find any such option "select restore partition as boot device" in bios. :confused:
95Viper
Super Moderator
12,777 (2.22/day)
What os is on it now?
Your specs list Vista?
654 (0.10/day)
India
Memory 8gb
Storage 1TB
95Viper
Super Moderator
12,777 (2.22/day)
Don't know what to really tell you.
1. Try viewing the files in the partition and see if there is a Recovery Manager .exe file and run it in Vista compatiability, if neccesary.
2. Or, Try installing the update for recovery manager and see if will install.
3. Or, you may have to order the recovery disks.
654 (0.10/day)
India
Memory 8gb
Storage 1TB
I've instaled update for recovery manager but i think it's only recovery manager updater as after installation it shows nothing , even nothing in programms to uninstall in controlpanel..
anyway to recover using recovery partition as i lost cds and F11 isn't working.
12,304 (2.32/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
Did you try F-8 .....
Below the safe mode there will be a option for restore or recovery or something like that
654 (0.10/day)
India
Memory 8gb
Storage 1TB
In F8, there are plenty options but no option like recovery..one option named directory services recovery
12,304 (2.32/day)
Oregon
Well the one good thing is HP will sell you the recovery disks for $15 They continue to support this even after the warranty have finished. Dell does not do this. I just received a set for a 8 year old notebook
Sounds like you messed up your partition "i had created 3 other partition too in my hdd" F 11 would have been the option for the recovery manager.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bph07143#N914
http://h10025.www1.hp.com/ewfrf/wc/...8578&cc=us&lc=en&dlc=en&product=3398125#N1503
654 (0.10/day)
India
Memory 8gb
Storage 1TB
I've just recovered using disk manager-->recovery partition--right click--mark partition active.
no need to spend even 15USD.
I hope this thread will help other users too.
Thanks.
quickercarter
1 (0.00/day)
Using PC Restore:
1. Turn on the computer.
During the boot process, a blue bar appears at the top of the screen.
2. Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish starting, and then restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot.
3. Click Restore and click Confirm.
The restore process takes approximately 6 to 10 minutes to complete.
4. When prompted, click Finish to reboot the computer.
