Hey, so I successfully finalise my first build today consisting of a 3800x Ryzen with a Noctua D15s + Gigabyte x570 Elite + 3200Mhz C14 and a RX590 Fatboy .
I am not intending to do any overclocking, mainly using for gaming/browsing and programming.
Currently my temp are great, idle low to high 30's, while playing high 50's to lower 60s.
The RAM that I got is 3200Mhz C14 , I have only enabled XMP so I can use the memory I paid for. I also played a bit with the voltage and the clock speed, setting max voltage to 1.3 and max clock speed to 3,900.I am assuming those settings are okay for what I intend to do with the PC, but just wanted to check with someone more experienced if it would be safe in the long term for the CPU.
My BIOS settings currently:
The Advance PBO was a default setting after booting the PC. On disabling PBO I was observing idle temps low 50's to low 60's so I decided to turn it back to Advance.
And those are my Ryzen Master settings:
I have noticed the voltage fluctuating from 0.300 to 1.2 and some other numbers with a big gap in between. Is that normal?
