How to SLI FX4800 on Asus Sabertooth P67
thamch
20 (0.00/day)
I just bought a new RIG but I'm not able to get this 2 cards to be SLIed.
The SLI Bridge is connected and I've check the ACPI and it do have the Nvidia SLI Certificate installed.
Graphic Card:
HP nVidia Quadro FX4800 BIOS 62.00.77.00.05
Driver tried:
Quadro Driver v266.45 - no SLI Enabled option
Quadro Driver v259.81 - no SLI Enabled option
Quadro Driver v191.66 - no SLI Enabled option, tried with and without SLIPatch_v1.0_final.
Please help.
5,479 (0.88/day)
Australia
these cards are old now days? i would suggest going way back in drivers to the 180.XX and see what happens?
thamch
20 (0.00/day)
Melvis, thanks for the reply. However the oldest driver for Win 7 x64 is 190.38. Can't go any older.
5,479 (0.88/day)
Australia
O ok for windows 7? that i didn't know, fair enough, then i wouldn't be to sure. Have you tried it under XP yet?
1,877 (0.30/day)
Cobourg,Ontario
System Name RyZen FX
Processor AMD Ryzen 9 5900x
Motherboard Gigabyte B550 Aorus Elite AX V2
Cooling DeepCool AK400 Zero Dark Plus
Memory Corsair CMK32GX4M2E3200C16 X2 32gig dual channel
Video Card(s) ASUS RX 7700XT TUF OC
Storage x2 Lexar SSD NM710 2TB 2XSeagate 1Terrabyte 1x Seagate 2 Terrabyte
Display(s) 40 Inch Samsung HDTV (monitor)
Case HAF-X:)
Audio Device(s) AMD/HDMI to Onkyo HT-R508 Receiver
Power Supply EVGA SuperNOVA 1000 G2 Power Supply
Software Windows 10 Pro X64
Graphic Card:
Driver tried:
Please help.
By chance does the so called sli bridge that comes with that mobo say on it SLI or is just the light copper colored ASUS bridge like the one in this review http://www.guru3d.com/imageview.php?image=28306
If it looks like that it is a crossfire bridge not a sli bridge.Sli bidges is always a dark brown or black and has SLI in big white letters,Try the bridges that came with the cards.
6,824 (1.19/day)
Viking Land
System Name CosmosII
Processor Ryzen 7700
Motherboard Gigabyte b650 gaming x ax v2
Cooling BeQuiet Pure Rock v2
Memory Corsair Vengeance RGB DDR5-6000 2x16GB
Video Card(s) Inno3d RTX 4070 Ti Super
Storage 1tb Corsair MP600 Pro XT
Display(s) 34" Ultrawide
Case Cosmos II
Audio Device(s) stock onboard thing
Power Supply RM850E
Software ½½
and they are "smaller" where they grab the sli fingers
thamch
20 (0.00/day)
Thanks for the info. Unfortunately the card doesn't comes with any SLI Bridge cable. I shall check with my seller if they do have spare SLI bridge for me to test. But according to the motherboard manual, it comes with the ASUS SLI Bridge connector.
6,824 (1.19/day)
Viking Land
Case Cosmos II
Power Supply RM850E
Software ½½
could you take a picture and show us?
use www.techpowerup.org and copy the IMG link under the picture and insert here
3,016 (0.52/day)
vermont
System Name The wifes worst enemy
Processor i5-9600k
Motherboard Asrock z390 phantom gaming 4
Cooling water
Memory 16gb G.skill ripjaw DDR4 2400 4X4GB 15-15-15-35-2T
Video Card(s) Asrock 5600xt phantom gaming 6gb 14gb/s
Storage crucial M500 120GB SSD, Pny 256GB SSD, seagate 750GB, seagate 2TB HDD, WD blue 1TB 2.5" HDD
Display(s) 27 inch samsung @ 1080p but capable of much more ;)
Case Corsair AIR 540 Cube Mid tower
Power Supply EVGA GQ1000W MODULAR
Mouse generic for now
Keyboard generic for now
Software gotta love steam, origin etc etc
Benchmark Scores http://hwbot.org/user/philbrown_23/
the ribbon in the pic that H8 posted IS an ASUS SLI BRIDGE. I have 2 of them exactly like it. msi and asus sli bridges look like crossfire connectors except the 3/4way sli bridge. I would say I thought the quado 4800's did not sli correctly. but i could be wrong. also check the mainboard AND bios for pci-e disable jumpers/option
thamch
20 (0.00/day)
Here is the picture of the SLI Bridge connector:
Is this SLI Bridge or X-Fire Bridge?
1,877 (0.30/day)
Cobourg,Ontario
Case HAF-X:)
yep that is a SLI connector( wish they would have kept them black)Try installing it in reverse of what it is now,Could also be a bad connector lord knows i got 2 bad ones with a mobo ounce.
thamch
20 (0.00/day)
Thanks for the reply. I had read the manual and there is no special jumper or bios settings to enable the SLI. It has been enabled by default. I guess.
I've used the Everest Ultimate and in the ACPI BIOS, the SLI Cert is installed.
thamch
20 (0.00/day)
thamch
20 (0.00/day)
Tested the SLI Bridge on Z800 running dual Quadro 5000 Series, it works instantly once the machine is power up.
Looks like Nvidia had disable the SLI on uncertified mobo.
3,016 (0.52/day)
vermont
Processor i5-9600k
Cooling water
on the page you linked it shows the fx4xxx cards sli on those systems, maybe nvidia decided not to allow sli with them unless its from and oem?? just sounds like something nvidia would do
thamch
20 (0.00/day)
I would expect so. Anybody has any guide on how to extract out the HP Z800 SLI cert from the BIOS and import it into my Sabertooth UEFI?
fgh98h
17 (0.00/day)
HP Quadro FX 4800 on Asus board problem
Hi all,
I'm trying installing driver for quadro fx 4800 on a self made pc whit asus RE (x48)
the installation failed. i have try different driver, moded inf, flash card whit other HP
bios, no way. I can't find pny or Fujitsu bioses.
Is possible HP lock card for not HP workstation?
What i can try to make work the card??
Thanks
Regards
fgh98h
17 (0.00/day)
How you can run this HP quadro fx 4800 on no HP system??
i have one and can make this work on asus RE x48 !!
fgh98h
17 (0.00/day)
Could you guide me on how to make it work on x48?
Sorry, my bad!
i can't run a single card on rampage extreme x48!!
my question to you was if on your mainboard, a single HP quadro fx 4800
work? can you prove me this ? so y buy this main board!
thamch
20 (0.00/day)
Sorry, my bad!
Hello, 1 card of FX4800 can run properly on the Sabertooth P67. I can't do the SLI with 2 x FX4800.
Why this board, because it looks sexy and 5 years warranty !
fgh98h
17 (0.00/day)
What about your power ? how is sli certified ? amper for 12 v line ? watt?
i have also read this mobo run in 8x whit 2 pci-e used!
anyway can you show me some immage of this HP card running on your system please?
thx
thamch
20 (0.00/day)
thx
I'm using Corsair AX850. My board is SLI certified. But can't SLI both HP FX4800.
Yes, it will be 8x with 2 PCIe. But I can't SLI it now, so I had removed one of the card. In the process of selling the card.
http://img.photobucket.com/albums/v245/thamch/FX4800.jpg
fgh98h
17 (0.00/day)
I was asking if you can prove this just because, yor cpu as a grafic processor inside
and maybe is this working, and not the quadro. something like gpu_z is better.
I think you have tried the card separatley one o one and both are working right?
Well i can't understand why is not working on my system, i have tried to patch
whit sli cert. no way. I need to try on some p67/x58 chip to have absolutley
certainty it work.
Other try ,and i'm serching for that, is flashing whit pny bios, the card
if there are hp restriction, this can solve the problem.
