How to stream with 1440p monitor
8,279 (1.31/day)
Mouse Logitech G604s
Im looking at streaming with my computer. Specs are listed under system specs.
What I want to be able to do is play games at 1440p but have them be streamed to 1080p without looking like compressed garbage and I cant seem to figure it out. I have a powerful enough computer where I dont need a stream PC and a gaming PC to achieve this.
I think what is holding me back is this setting:
But I cant change it to anything else to make the stream look watchable for users on 1080p.
I have these options set in the general OBS streamlab settings:
Am I missing something here? can anyone assist?
462 (0.10/day)
France
Processor i7 12700K
Motherboard MSI PRO Z690-A WIFI DDR4
Cooling Noctua NH-U14S
Memory G.Skill Ripjaws V 32GB 4400Mhz CL19 1T
Video Card(s) AMD Radeon 6700 XT
Storage 970 EVO 250GB|Crucial m4 128GB|MX300 525GB|MX500 1TB|PNY XLR8 2TB|Kingston NV2 2TB|14TB HDD|4TB HDD
Display(s) Acer XG270HU 27" 1440p 144Hz
Case Fractal Design DEFINE R4 Black Pearl Window
Mouse Razer Naga Trinity
Keyboard EVGA Z15 RGB Mechanical Gaming Keyboard
Software Windows 11 Pro 64bit
For the few I know it's better to play and stream at the same resolution, or at least get the same ratio as 16:9 (as your output), which is 2560x1440 or go play at 1920x1080, no downscale to do.
If by "garbage" you mean it's ugly with big pixels and all, it's all about the bitrates (you want to higher this) and then it will depend on your bandwidth capability (upload bitrate). 3,500 Kbps bitrate if your viewers have the 1080p option or else stay at 2500. The higher you want, the higher upload you need.
8,279 (1.31/day)
Actually by garbage I mean that it is all squished (compressed) on the stream side.
9,675 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
You are streaming something that isn't 16:9, it will always look squished, the pixel aspect ratio of the the input video does not match the one of the output. Whatever you're going to do it will never look right on a typical 16:9 display.
newtekie1
Semi-Retired Folder
28,473 (4.05/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Exactly this, you want the aspect ratios to match, otherwise it will always look terrible.
Best thing to do would be to play games at 2560x1440p, and have obs down scale to 1080p or 720p.
8,279 (1.31/day)
See thats what im trying to do and it isnt working. Except my resolution is 3440x1440
newtekie1
Semi-Retired Folder
28,473 (4.05/day)
Indiana, USA
It won't do it because 3440x1440 is 21:9 not 16:9. You have to set your resolution to 2560x1440, that is the 16:9 resolution of 1440p.
3,909 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
It's probably the 'Output (Scaled) Resolution' setting in the second screenshot causing the problem.
You can manually type resolutions there, so make sure output is also 21:9.
Unless they have changed this from a while ago when I tried streaming, most streaming platforms expect or only work with 16:9 content so you might need to play around with scene composition to place your 21:9 game content on 16:9 output.
Thread title is nicely misleading though. 1440p is generally understood as 16:9 resolution - meaning 2560x1440 - that does not cause any problems when streaming. Ultrawide 21:9 aspect ratio is the problem here.
