- Nov 12, 2011
- 786 (0.17/day)
- UT,US
System Name | Asrock 2012 |
Processor | FX 8350 4.2Ghz no turbo |
Motherboard | ASRock 970 PRO3 AM3+ |
Cooling | Corsair H70 for CPU |
Memory | 32GB DDR3 1960Mhz |
Video Card(s) | NVIDIA 1080 with stock fan |
Storage | 1TB GIGABYTE SSD NVME PCIE 2.0 + Samsung SSD Evo 850 250GB with Ubuntu + Samsung SSD 860 500GB win7 |
Display(s) | LG HDR 31.5" |
Case | Big Black Tower |
Audio Device(s) | Realtek audio + Audigy 2 ZS platinum |
Power Supply | CORSAIR RM850X |
Mouse | microsoft intellimouse usb to ps/2 |
Keyboard | Logitech |
Software | Windows 10 Pro 64bit |
Benchmark Scores | + |
i bought this:
Its a CD, the package was sealed and genuine aparently. the cd is shiny new and it all looks genuine that's not my concern.
I can't find a way to install it onto a micro SD or full size SD card using rufus. What rufus did was a copy of the installer while i wanted a installed ready to use XP install.
I tried the CD running on my dvd drive on my fx8350 but at some point while loading installer it crashes (check photo of CD and SD installers i tried both) and on both mediums while loading installer they crash.
I have a windows xp live CD I got way long ago like 2010 and that one at least shows the windows xp progress bar yet it crashes too (check photo)
-my concern is that the windows xp cd i bought might not be a 64bit that's why it crashes.
(the winxp live cd from many years ago shows a different code and the filename says livecd)
NOTE: I forgot to mention mostly the reason i need a winxp 64bit is so i could use an old PCTV 80e usb dongle to play cable tv/vhs/etc on my fx8350 in addition to the pc capture card that does the same thing with proper video adapters. right now on nor windows 7 nor 10 the dongle works, it doesn't work, OBS can't even see it.
![www.ebay.com](/forums/proxy.php?image=https%3A%2F%2Fi.ebayimg.com%2Fimages%2Fg%2FI5sAAOSwDYJmPGJE%2Fs-l400.jpg&hash=a1b4cea4078a5fb3189ef7b963523a23&return_error=1)
NEW Windows XP Professional x64 Edition Full Version Disk COA Product Key 64 bit | eBay
<p dir="ltr" style="margin-top:0; margin-bottom:0;">Genuine OEM software, new and factory sealed. </p>
www.ebay.com
