How to use spdif cable
383 (0.08/day)
NJ Hillside
System Name Windows7 64bit Ultimate
Processor Intel Core i7-6700K
Motherboard Asus Z170M-PLUS
Cooling Cooler Master T4
Memory G.skill 32GB DDR4 (2x16GB) 3200MHz
Video Card(s) ASUS GTX970 4GB
Storage PNY 500GB SSD + Seagate 4TB SSHD
Display(s) HP LE1851w
Case Cooler Master N200
Power Supply Cooler Master 750watt
Mouse HP
Keyboard HP
Benchmark Scores no need
Hi
I have purchased spdif cable for my 9800GT, but I don't know where should to plug it :shadedshu:
my Mb G41M-VS3 R2.0
I have read user manual but useless :(
Thanks in Adv
4,357 (0.91/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
What kind of SPDIF cable? Like the ones from stores? Those won't work. You need a 2 pin SPDIF cable:
Also you'll need a DVI to HDMI adapter (make sure it has audio out). If you bought your Geforce new it might come with one:
1. Connect the 2 pin plug to the SPDIF header on the graphics card
2. Connect the two 1 pin plugs on the SPDIF header of your sound card or onboard audio.
3. Connect the DVI-HDMI adapter to the DVI port.
4. Connect the HDMI cable
EDIT: By the way, your motherboard doesn't seem to feature an SPDIF header. You might need to get a sound card with one.
EDIT2: Confirmed. The manual doesn't list an SPDIF header. You'll need a sound card with one.
536 (0.11/day)
Bahrain
System Name Lazyman 9000+
Processor AMD Ryzen 7 3800X
Motherboard X570 Aorus Ultra
Cooling Arctic LF II 280
Memory 2x8GB Crucial Ballistix 3600 MHz DDR4
Video Card(s) PowerColor Red Devil 5700XT
Storage Never Enough
Display(s) ASUS VG248QE+ Dell E2420H
Case LIAN LI Lancool II Mesh RGB
Audio Device(s) Sennheiser HD518 / Logitech Z623
Power Supply FSP AURUM PT 850W
Mouse Logitech G600
Keyboard Logitech G810 Orion Spectrum
Software Win 11
Benchmark Scores All over the bench
Sorry man, your motherboard doesn't appear to have a spdif header
6,753 (1.40/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
For your 9800gt? Those don't seem to go together.
12,307 (2.31/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
A 9800gt does not have a Optical plug. What are you trying to do?
126 (0.03/day)
System Name Mein pride und joy
Processor Ryzen 5 3600
Motherboard GigaByte Aorus X570 Elite
Cooling Cryorig H7 Ultra
Memory Kingston HyperX DDR4 16GB CL15
Video Card(s) Sapphire RX5700 Pulse
Storage Samsung 850 Pro 256 / Samsung 860 Evo 500 / Seagate 1TB
Display(s) BenQ XL2430T
Case Fractal Design Define R5 Blackout Edition
Audio Device(s) Onboard / Asus Xonar AE
Power Supply Seasonic SSR-650RM
/thread
Op, next time before bying S/PDIF cables for your gfc make sure you check your motherboard for S/PDIF out connectors.
Wrong. My 8600 gt had one. And we are not talking about about "that" connector which you might have thought about.
4,357 (0.91/day)
Mexico
I was looking at newegg but I can't find sound cards with spdif out headers. :( There's a 7.1 card from Diamond with an SPDIF IN header but not an OUT.
Funny, 5 years ago even cheapo cards from Sabrent and SYBA would come with SPDIF headers. I suppose that since graphic cards come with audio pass-through, sound card manufacturers just don't bother.
EDIT: The Asus Xonar DS has an SPDIF out header: http://www.newegg.com/Product/Product.aspx?Item=N82E16829132013
That'll set you back $45 though. I would sell the 9800GT and get a GT640 or something. It'll be a sidegrade but will come with HDMI output.
12,307 (2.31/day)
Oregon
/thread
Please go on. What are you refuring to as 'that connector" I thought we were taliking about a SPdif, Optical or Toshlink. I have never seen a GPU with one. I could be wrong though
Anyway the OP need to explain what he is trying to do
4,357 (0.91/day)
Mexico
This is the connector Scatler is referring to:
The one to the left of the 6 pin PCIe power connector.
Geforce cards used to feature audio passthrough with this connector. Radeon cards have done that straight from the AGP/PCIe slot, without extra wires.
12,307 (2.31/day)
Oregon
Cant see the pic Im at work. Must be a s pdif header?
383 (0.08/day)
NJ Hillside
Mouse HP
Keyboard HP
12,307 (2.31/day)
Oregon
Ok so what are you trying to do?
383 (0.08/day)
NJ Hillside
Mouse HP
Keyboard HP
:) I am looking to get sound through an HDMI adapter
DVI to HDMI
12,307 (2.31/day)
Oregon
So your tryng to get sound and video to your receiver? And it has HDMI?
Your still not being clear as to what you want. That GPU will not put sound from DVI to HDMI
When it comes to HDMI is a whole new ball game. You cant just use adapters and expect it to work. If you want to run video and sound with only HDMI to your receiver or TV then you need a new graphics card. Otherwise its analoge audio seperate from video
8,483 (1.89/day)
Ovronnaz, Wallis, Switzerland
Keyboard Endorfy Thock 75% <3/none/touch/virtual
VR HMD Medion Erazer
my Asus Matrix 9800GT have a S-video HDMI DVI-D and a SPDIF (optical) and my HP oem 9800GT has a header on the top left of the pcb, near the SLI connector but only 2 DVI-D and not other output.
what 9800GT brand (they may have different solutions) oh i see EVGA then its nothing more than my HP OEM 9800GT with a different cooler, worse cooler also ... unlike NV original design it blow hot air in the case mainly instead of outside.
well i had that cable with my HP 9800Gt but i never used it since that card was more for a linux cruncher until it died :D i guess some brand does it better ... (IE: Asus with the Matrix 9800GT)
536 (0.11/day)
Bahrain
Mouse Logitech G600
Software Win 11
So your tryijng to get sound and video to your receiver? And it has HDMI? Your still not being clear as to what you want. That GPU will not put sound from DVI to HDMI When it come to HDMI is a whole new ball game. You cant just use adapters and expect it to work. If you want to run video and sound with only HDMI to your receiver or TV then you need a new graphics card.
You maybe misunderstanding something jetster, i have that exact evga 9800GT at home and yes you can get audio through DVI-HDMI adapter provided you connect that spdif "digital audio" cable to the gfx card.
It's a 2pin cable that should be provided through a MB header not the optical one as you mentioned above, but as OP's MoBo doesn't have that he either buy's a new graphics card or a sound card with the necessary spdif connector
12,307 (2.31/day)
Oregon
I understand that. Its just old tech and his MB does not have digital audio and not all DVI cables can carry audio. So untill we find out what he is trying to do we dont know if he needs a sound card or a new GPU for watching movies. I dont think he trying to game with that 9800gt (but you never know) so Im guessing he just needs a AMD6450 or some other low end HDMI card
383 (0.08/day)
NJ Hillside
Mouse HP
Keyboard HP
so, final result I am not able to use it :(
anyway i will check different HDMI-GPU
Thanks all :lovetpu:
Mussels
Freshwater Moderator
58,413 (8.04/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
TRWOV had it correct in post 2. despite having the connector many nvidia cards back then didnt have working HDMI anyway, and it *only* worked for stereo pre-encoded dolby digital media (so 5.1 movies only, basically)
it was a very VERY limited technology, and mostly crap. getting a more modern video card will get built in HDMI and greater performance with less heat/noise/wattage.
