- Feb 14, 2024
- 30 (0.19/day)
(Ryzen 5 5600, ASRock B450M Pro4 R2.0) I'll post my full specs at the bottom of the post, I don't know if the mobo and CPU would be enough, but it can't hurt. Imma try to keep this short, basically my PC has been randomly rebooting since I built it in Feburary, mostly while gaming. I've basically tried everyhting from A-Z trying to fix it, but nothing has worked, including sending almost every single component in for RMA or flat out replacing it. When the PC reboots it shows me Machine Check Exception; Cache Hierarchy Errors with different APIC ID's in the Event Viewer, which point to the CPU. The one thing I havent tried is setting Core voltage, since that error apparently can be cause by cores not getting enough Voltage. The downside is I'm very tech illiterate when it comes to PC stuff, so I dont want to follow a random guide for a different Ryzen CPU. Thank you in advance for any help
GPU: AMD Radeon 6650XT
CPU: AMD Ryzen 5 5600
Mobo: ASRock B450M Pro4 R2.0
Ram: 16GB Kingston Fury Beast DDR4-3200 (Now Aegis G.Skill DDR4-3200)
SSD: 1TB Lexar NM620 M.2
PSU: 700 Watt be quiet! System Power 9
OS: Windows 10 Pro
OS: Windows 10 Pro
