HP Probook 650 G2 wifi problem
7 (0.00/day)
Hello everyone,
I got a HP Probook 650 G2 laptop but can't get wifi working. Wired connection works good. There's no wifi adapter in Device Manager. Wifi button in the upper right corner is in orange. When i press it, the only thing it does is turning airplane mode on/off. Downloaded and installed all newest official drivers from HP website, ran HP Support Assistant software utility, updated BIOS, looked in there for any clue of wlan/wifi etc... nothing. External wifi antenna with Atheros drivers works fine. Can someone help me to get internal wifi adapter working? How else can i check if it's connected to PC properly without disassembling laptop? Thanks in advance.
6,270 (0.93/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
no wireless in the device manager means either the card is dead or not even there maybe driver not installed but it should still be seen in Device manager......Did you try "Scan for new hardware" to see if Device Manager picks it up?
EDIT Did the internal wireless ever work on the laptop for you?
dorsetknob
9,106 (1.29/day)
Even if its fitted it should show up in device manager irrespective as to if the Internal Antenna are connected or not
This is a case where only a visual inspection will help diagnose/determin if you have a wireless card fitted.
Time to Open up that laptop (inspection plate on Base ????)
If you do not feel competent to dissasemble if there is no access plate then take it to someone who can or take it to a Shop
7 (0.00/day)
Look what i've found when opened laptop ;D slot for wlan is empty. I have to find another adapter. Thanks for answers, guys!
2,331 (0.45/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
silentbogo
5,488 (1.41/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Video Card(s) Inno3D RTX 3070 Ti iChill
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Software Windows 11, Ubuntu 20.04 LTS
The cheapest and 100% compatible option is any Intel M.2 wifi card. They cost less than $10 used (7265NGW etc.).
For the sake of reliability and compatibility avoid anything from Mediatek/Ralink and Qualcomm/Atheros.
By default it comes with Broadcom BCM943228 or WN8601L(e.g. Realtek 8188) but both are crap.
