HP Releases First 4K EliteDisplay, Multiple 4K Monitors
Raevenlord
3,755 (1.23/day)
Portugal
System Name The Ryzening
Processor AMD Ryzen 9 5900X
HP today announced immediate availability of some monitors specifically geared for the professional - or at least pixel-conscious - crowd. The EliteDisplay S270n monitor features a 4K, IPS, 27" diagonal, 350 cd/m² brightness, 1300:1 static contrast ratio panel with 14 ms gray to gray response times. Display input duties can be allocated towards 1x DisplayPort 1.2 or 2x HDMI inputs (1.4 and 2.0). Additionally, there's 1x USB Type-C supporting Displayport 1.2 which is able to deliver up to 60 W of power to a connected device.
The other three models HP has announced today sport the Z27, Z32 and Z43 monikers, which directly reference the diagonal size of the monitors. The feature set is practically the same across all three of these models; they offer the same 4K UHD resolution and IPS based panels. 350 cd/m² remains as the peak brightness value, as well as a 1300:1 static contrast ratio, but the response time is improved on the 27" and 42" models to 8 ms gray to gray (the 31-inch model is at 14 ms, just like the EliteDisplay). The HP Z27, Z32 and Z43 all support 1x USB Type-C which supports DisplayPort 1.2 and can send up to 65W of power to the connected device. Display outputs are the same across these monitors (1x DisplayPort 1.2, 1x Mini-DisplayPort 1.2, 1x HDMI 2.0, 1x USB Type-C, but the Z27 and Z32 pats only carry three additional USB 3.0 ports, while the Z43 ups that number to 5x. All monitors are available now, with pricing being set at $549 for the EliteDisplay S270, while the Z27, Z32, and Z43 are priced at $559, $899, and $799 respectively.
1,224 (0.34/day)
Richmond, VA, USA
System Name lazy ass
Processor Intel i5 7600k 4.2 GHz
Motherboard MSI Enthusiastic Gaming Z270 (Z270 GAMING M3)
Cooling H80i GT V1 liquid cooling
Memory CORSAIR VENGEANCE RGB PRO 32GB (4x8GB) DDR4 3600MHz
Video Card(s) Gigabyte AORUS GeForce GTX 1080 8G 11Gbps
Storage seagate 2tb HDD/boot drive SSD Samsung 960 evo M.2
Display(s) ASUS 28inch 4k
Case Corsair Graphite Series 760T
Audio Device(s) mobo
Power Supply EVGA SuperNOVA 750G1 750 watts
Mouse Razer Mamba wireless/ needs a new one razer sucks
Keyboard Corsair K68 RGB
Software Windows 10 home
Benchmark Scores to be updated soon
Still don't get why monitor prices are twice as much as 4k TV's mine was 43 inch lg for $450 and I'm looking at 40-43 inches for a new 4k monitor they go from $700-1200 for a 43 inch. I'm waiting to see if anything better comes out but the prices on theses monitors ain't bad.
475 (0.07/day)
Colour gamut must be really bad since they aren't publishing it anywhere, not even on the data sheets. That correlates with the prices.
bug
13,846 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
TVs usually have to stick to 30Hz (maybe 60 in some cases) and that's it. Also, you wouldn't care much for a 40ms lag when watching a movie. The electronics are probably simpler. And yes, I know a TV has to handle additional inputs.
Scale is probably another factor, because while houses can have 3-4 TV sets, many can go without a desktop, so 0 monitors.
Is the 32" really more expensive than the faster 43"?
@Nephilim666 Idk if it correlates with the prices, they're pretty high for non-HDR monitors. Wide gamut would be nice.
FreedomEclipse
~Technological Technocrat~
24,191 (3.74/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Memory 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming) | 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
I think part of it is down to the panel having a higher DPI than your regular TV panel, other costs may include royalties and licensing fees that may have to be paid.
475 (0.07/day)
Found the colour gamut for 2 of these
s270n: '>99% sRGB'
z32: 99% sRGB, 100% bt709
Both 8 bit + frc
Hard pass.
