Hi y'all. I'm trying to upgrade the graphics card on my HP AIO. Model is Envy 23 -d160qd.
Here are the specs:
IPISB-NK motherboard
Intel H61 chipset
Intel I-7 3770s Ivy Bridge CPU
2x8 GB Micron 16KTF1G64HZ-1G6E1 memory banks
Motherboard has a MXM-A 3.0 socket.
So far I tried successfully these 3 cards:
GeForce 630M
Radeon HD7450A
Radeon HD7650A (the one actually working on the machine)
Trying to get something a little bit better than the HD7650A.
So far I tested, with no luck, a Firepro M5100 (higher TDP, machine won't boot up, overheating power circuits on the MB).
And actually I'm testing a Quadro M1000M (same vendor, HP. Came from working HP Z1) and tomorrow I'll be receiving a Firepro M4000 that I will test. I don't understand why the M1000M does not work. The vendor is the same, the TDP is almost identical, format and socket pinout is the same, so, at least electrically, it should work. I tried booting the machine with the security boot disabled and the legacy mode enabled, but no luck so far. At this point I think that the problem is either the VBios or the BIOS on the computer, preventing the machine from booting up if a "non approved" MXM card is detected.
I'll appreciate any input from you guys. I tried already the HP forums but (and I don't want to be rude here) they're basically useless when you try to dig deeper into the issue.
Thanks a lot!
BTW...I forgot to mention that I already upgraded the power supply to a 230W one.
Here are the specs:
Intel H61 chipset
GeForce 630M
Radeon HD7450A
Thanks a lot!
