Raevenlord
- Aug 12, 2016
- 3,755 (1.25/day)
- Portugal
System Name | The Ryzening |
Processor | AMD Ryzen 9 5900X |
Motherboard | MSI X570 MAG TOMAHAWK |
Cooling | Lian Li Galahad 360mm AIO |
Memory | 32 GB G.Skill Trident Z F4-3733 (4x 8 GB) |
Video Card(s) | Gigabyte RTX 3070 Ti |
Storage | Boot: Transcend MTE220S 2TB, Kintson A2000 1TB, Seagate Firewolf Pro 14 TB |
Display(s) | Acer Nitro VG270UP (1440p 144 Hz IPS) |
Case | Lian Li O11DX Dynamic White |
Audio Device(s) | iFi Audio Zen DAC |
Power Supply | Seasonic Focus+ 750 W |
Mouse | Cooler Master Masterkeys Lite L |
Keyboard | Cooler Master Masterkeys Lite L |
Software | Windows 10 x64 |
The HTC VIVE Pro Full Kit is one for the enthusiast, with the full bundle launching with the updated Steam VR 2.0 compatible base stations for a total play area of an incredible 10m x 10m, over three times that of the original. Also included in the Full Kit is a new set of pro controllers in the iconic blue colour. The VIVE Pro headset itself features a resolution of 2880 x 1600 (an increase of 78% over the original), with a built-in deluxe audio strap and slimlined cable management.
Modular Tracking with Steam VR 2.0 Base Stations
Scale your tracking - from seated to standing to full 10x10 meter (32'x32') room-scale tracking. SteamVR 2.0 allows you to add up to 4 base stations for wide-area tracking avoiding occlusion, and ideal for multi-user environments, all at sub-millimeter accuracy. With triple the original play area and 4 base stations (around 1,075 square feet) VIVE Pro will be leading the way with the next generation of game developers, offering a VR experience like never before.
High Resolution Display for Perfect Clarity
VIVE Pro features dual-OLED displays with an industry leading resolution of 2880 x 1600 pixels to make graphics, text and textures look perfectly crisp and clear, so you get the visual fidelity required for even the most demanding use-cases and environments.
Featuring even-weight distribution and a 24% increase in face gasket surface area, VIVE Pro was ergonomically engineered to provide maximum comfort and flexibility, even with extended use. VIVE Pro is simple to get on and off and adjusts easily for head size, glasses and interpupillary distance (IPD).
The VIVE Pro Full Kit includes:
VIVE PRO SPECS
Headset Specs
Available for Pre-order from £1299.00 (~€1468, ~$1709)
- Vive Pro Headset (Hi-Res certified HMD and headphones)
- 2 x SteamVR Base Station 2.0
- 2 x HTC VIVE Controller (2018)
- Supports Steam VR 2.0 Room-scale tracking
VIVE PRO SPECS
- Unprecedented presence with Hi-Res and 3D spatial audio
- Stay immersed comfortably with higher display resolution, easy-to-use headset & cable design, and improved ergonomics
- Chaperone technology
- Free to move around wirelessly with VIVE Wireless Adapter*
- *VIVE Wireless Adapter sold separately.
Headset Specs
- Screen: Dual AMOLED 3.5" diagonal
- Resolution: 1440 x 1600 pixels per eye (2880 x 1600 pixels combined)
- Refresh rate: 90 Hz
- Field of view: 110 degrees
- Audio: Hi-Res certificate headset
- Hi-Res certificate headphone (removable)
- High impedance headphone support
- Input: Integrated microphones
- Connections: USB-C 3.0, DP 1.2, Bluetooth
- Sensors: SteamVR Tracking, G-sensor, gyroscope, proximity, IPD sensor
- Ergonomics: Eye relief with lens distance adjustment
- Adjustable IPD
- Adjustable headphone
- Adjustable headstrap
