- Dec 6, 2011
- 4,784 (1.00/day)
- Still on the East Side
Huntkey Enterprise Group, a global professional power supply provider, has unleashed its new GS series power supply, which is suitable for gamers.
GS means Green Star. It uses a 12 cm fan, which can reduce fan speed and lower noise. GS also means Gamer Star. With dual +12V rails and highly efficient design, the efficiency of GS series power supply can reach up to 82% at typical load. Active power factor correction circuit can improve PF value. Extra long 12V 4+4pin CPU cable supports tower gamer chassis.
Features:
● Complies with ATX12V V2.3 standard.
● High efficiency and robust +12V outputs.
● Active PFC provides reliable power.
● Super low noise with a 12 cm fan.
● Extra long 12V 4+4pin CPU cable supports tower chassis.
● Compatible with Intel & AMD CPU.
● Compatible with NVIDIA & AMD graphic card.
● 100% Hi-pot tested & 100% Burn-in tested.
● MTBF≥50,000 hours.
Features:
