HWinfo64 shows abnormal readings for PSU +12V rail
279 (0.07/day)
System Name My-Best-So-Far
Processor Intel Core i5 12600K Boost @4.8GHz
Motherboard MSI Z690 Edge WiFi DDR5
Cooling Noctua NH-U14S - Air cooler
Memory XPG Caster 32GB DDR5 6000 MT/s CL40-40-40-77 | But running STABLE @ 4800 MT/s CL40-40-40-77
Video Card(s) Asus Strix RTX 3060 Ti 8GB
Storage SSD 250GB EVO...NVMe S40G 256GB & MP600 1TB LPX...HDD Barracuda 1TB & 2TB
Display(s) MSI Optix MAG Series MAG272CQR 2560x1440p 165Hz
Case Corsair 750D (Still one of the BEST for AIR cooling)
Audio Device(s) Realtek Audio
Power Supply SilverStone Strider 650W Platinum (ST-65F PT)
Mouse A4tech Bloody V3M
Keyboard HyperX Alloy Elite RGB - Mechanical
Benchmark Scores http://i.imgur.com/0O79u7Z.jpg
I have noticed that PSU (SilverStone Strider SST 650W) readings in HWinfo64 has been abnormal lately. Today, while playing game (Ghost of Tsushima) HWinfo is showing reading for +12V at 12.048V (max) and 11.328V (min) as seen in the picture, later it further dipped to 11.148V (min) after an hour of gaming, which is super abnormal.
I understand that software readings, specifically, PSU related are not entirely accurate. And in my case, readings are way off which compelling me to buy a new PSU; I have a few options in mind to get from. However, I am not sure if PSU is faulty, or HWinfo is way off on PSU's voltage segment as I can play any game on max settings (that my GPU allowed me to), or stress PSU by using CPU/GPU load testing programs with no sign of failure/crash/shutdown whatsoever. At the time of writing, I am playing Ghost of Tsushima.
Need opinions/guide on subject matter, please.
My PC Specs:
12600K at stock boost
Noctua NH-U14S
MSI Z690 Edge
DDR4 32GB RAM
Asus Strix RTX 3060Ti 8GB
2x SSD
2x HDD
SilverStone Strider SST 650W (ST65F-PT) PSU In Question
MSI Optix MAG Series 27" 1440p Monitor
2,044 (4.25/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) 1080P 144hz
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Some will say that you have a 10% swing +/-, so you're close to calling the PSU junk.
If you have a multi-meter, probe the CPU EPS connector to verify the readings. Don't assume the software is 100% correct.
freeagent
10,028 (4.23/day)
Winnipeg, Canada
Processor AMD R9 9900X
Cooling Thermalright Aqua Elite 360 V3, 6x TL-B12 V2
Memory 2x16GB Lexar Ares @ 6000 30-36-36-68 1.35v
Storage WD SN850 1TB, SN850X 2TB, 3x SN770 1TB
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Normally I would say it is literally time to replace it but.. it is working pretty hard, and you're 3.3 and 5v looks pretty tight.
I can do 650w no problem with my 5900X in my system.
1,025 (0.29/day)
Nova Scotia, Canada
Cooling Cooler Master Hyper 212 Plus
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
It's likely just a bad 12V connection in the 24-pin, try re-seating it or move the cable slightly and it'll likely come back up. Judging by how the 12V In for the CPU VRM is pretty solid ~12.1-12.2V I'm guessing this is the case.
This happens with my PSU from it being old and worn, if the 24-pin is not in exactly the right spot the 3.3V will droop below 3.2-3.1V and start causing issues.
3,682 (4.94/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Memory 32 GB DDR4-3200
Storage Yes.
Display(s) MSi G2712
Audio Device(s) Yes.
Software Windows 11 / 10 / 8
freeagent
10,028 (4.23/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
My X58 system was really bad for that.. well worn.
890 (1.17/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 7 9800X3D
Motherboard ASUS ROG Crosshair X870E Extreme Gaming Wifi
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5 6000Mhz CL30
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Case Cooler Master HAF
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium, RM850X (2024)
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB Platinum Cherry MX
Software W10-11 Enterprise- Linux Mint 22.1 Cinnamon Edition.
You can't really trust that software reading, you should measure it with a REAL Multimeter to be sure.
21,915 (3.42/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Software Gentoo Linux x64
I've never taken any stock in software readings here. If it isn't crashing, its probably within ATX spec, and not worth worrying about.
43,988 (6.81/day)
Cooling Scythe Ashura, 2Ă—BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED
ATX SPEC tolerance is + or - 5% so 12V rail minimum is 11.4V, max is 12.6. 5 is 4.75, 5.25. 3.3 is 3.135, 3.465.
Id be checking the ATX, EPS 12V, pcie etc.
AsRock
TPU addict
19,204 (2.97/day)
UK\USA
Cooling D15
Keep a eye on it, and if you start getting system shutdowns then you might of already found the issue.
43,988 (6.81/day)
11.3 is below the atx spec
AsRock
TPU addict
19,204 (2.97/day)
UK\USA
Cooling D15
Yup, and last time i had such readings Seasonic ask me to send it in, how ever i was having shutdowns too.
It could be just a false reading, although you could all so tel HWinfo64 to save to file and keep a eye on the 3.3v, 5v and 12v rails and see if that see/s some thing if a crash does happen.
23 (0.13/day)
Processor Core i7-4790K Haswell
Motherboard Asus Maximus VI Hero
Memory 16GB G.Skill DDR-3 2400MHz
Video Card(s) Palit GTX 1080 Gamerock
Storage Samsung 750, Samsung 870, 2X WD Blue 6TB in Raid 1
Display(s) Acer Predator X34 3440X1440
Case Corsair 780T
Power Supply Corsair RM 650i
Here's my experience.
Way back in like 2009 I bought a PSU from a local store. It was a Hiper HPU-5K880 880W PSU. Big mistake.
The PSU eventually blew up while inside my rig. Before it did so I did notice abnormal 12V readings in HW Monitor.
12V readings usually hovered around 11.3-11.7V as per the screenshots I have saved.
Replace immediately.
2,044 (4.25/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Right 10% +/- meaning +5% and -5% from 12v.
Wonder if the EPS cable reseat did the trick or if there was anything done otherwise. Hope OP comes back let us know.
freeagent
10,028 (4.23/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I have injured 5 or 6 PSU's, I thought this was injured too, not yet.. but it will be.
Software can be trusted if your board is halfway decent.
4,872 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
this,
on the old JG forums, software was never considered an accurate measurement and I had a few PSU (from well known OEMs & brands) that showed they were out of spec yet ran fine. If you want an accurate measurement you need a multimeter power supply tester.
890 (1.17/day)
Belgium
It's easy to measure under load with a normal multi-meter and it stays the best way to know what is wrong. If possible you can even try another PSU from with you know is good.
That software reading you should take with a big grain of salt, sometimes you can have more then 10 percent deviation. It's really up to the quality Mobo you have.
The best way stays a good multi-meter! You have special PSU tester's out there, but that is more for a computer shop.
4,872 (0.97/day)
279 (0.07/day)
Sorry guys, I was at office as per my routine. So thought to share details once I get back home and check thoroughly what suggested by all of you.
I appreciate the responses from all of you.
So I unplugged PSU cables from MB and while I was probing the 24-pin Cable with multimeter that I got, It gave me,
+12V = 12.34
+5V = 5.14
+3.3V = 3.39.
Just to make sure the stock voltages are fine.
Upon replugging cables (24-pin, PCIe and CPU EPS connectors on MB), I made sure the PSU connectors have a good contact with the base connectors on MB as what @DR4G00N @ShrimpBrime have suggested up there. GUESS WHAT! This does the trick for me for real. Voltages are much better now on +12V rail or I say, drastically improved. See pic
Well, I had no idea if re-seating could create such a huge difference.
Thanks a lot, guys. I think I can stay with this PSU until GPU upgrade (RTX 4070 Ti/Super).
890 (1.17/day)
Belgium
That means a bad contact with made a resistor so voltages go down, this resistor is heating up the bad contact and is the reason of burning connectors, aka 4090 video card's.
You should clean the contacts better with IPA and then connect them again.
2,044 (4.25/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
+12V = 12.34
+5V = 5.14
+3.3V = 3.39.
I gotta give the credit where due. That was all @DR4G00N. I only suggested to check with a multi-meter.
Thanks dude!!
279 (0.07/day)
Thanks dude!!
Indeed, it was originated by @DR4G00N, thanks man. Sometimes little things create big difference.
2,044 (4.25/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
It's not always the case. I had an old 12 years PSU giving the same readings across several boards. I decided to junk it before it did become a problem. Multi-meter helped confirm it. Get a load and that 12v rail would droop. Actually within that 10% swing, but I don't like seeing less than 12v ever. At least not from quality power supplies anyways.
Glad it's fixed though!! :)
279 (0.07/day)
Yep, bad contact was the issue here but I just replugged with little force and it worked. I guess IPA cleaning not needed at this stage.
I am still unsure regarding multi-meter testing at load. I have that basic two-wired multi-meter bought from local electric shop. Can I check voltages when system is running?
2,044 (4.25/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Yes of course you can. Set the multi-meter to DC and probe positive negative on the CPU EPS connector which is easier than probing the 24pin motherboard connector. If it's a single rail PSU, it won't matter where you probe.
