i am also making workstation with HP z800 Motherboard
Aditya Singh
1 (0.00/day)
Using Chief-tech full tower cabinet, Corsair 1000w power supply,Xeon x5650 dual CPU with cooler-master 414 heatshink, 8*8 64 GB ram, 1 TB ssd and 4 TB*2 8 TB HDD, Nvidia FX5800 card , win 10 pro and 24 inch dual monitor. its awesome. But must be hack at first power supply ATX cable due to something different power codes for motherboard
111 (0.05/day)
Southeast USA
System Name “Frankenstein” Dell T5500 (installed in T3500 case)
Processor Xeon X5675
Motherboard Dell T5500
Cooling Dell Air cooler 0U016F
Memory 24 GB ECC Registered. DDR3 (4GB x 6)
Video Card(s) Sapphire R9 380X Nitro 4GB
Storage SATA SSD and WD HD
Display(s) Dell 24” LCD
Case Dell T3500 (donor)
Audio Device(s) Intel 2.0 HD audio on board
Power Supply Dell T5500 875 watt job. Nice beefy PS, but ugly power harness.
Mouse Um...generic?
Keyboard Dell basic keyboard
Software Windows 10 Pro 64 and PC Linux OS Mate 64
Benchmark Scores Coming!
I have been tempted to get a bare Z800 mb.
I am building a frankensteinish, piece parts Dell T5500 at the moment, but if I had realized what the Z800 offered, might have gone that route instead.
307 (0.13/day)
HSV and SFO
Depending on what you have available, I'd definitely upgrade that gpu as you can get much faster than the fx5800 now for fairly cheap. Even a little gtx 660 or better will double the performance--and you have the power supply for it already.
Also, since you're running just one x5650, I'd upgrade by adding a second one for another kick in the pants. And if you want to max it out, get dual x5690s if your motherboard can support it.
phill
16,572 (3.42/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
Can get them with the Sandy Bridge CPUs in as well I've seen on Ebay, but they are holding some big money... I'd go with @SamirD as well, or if your concerned about power usage, grab some L5640's :) I have four of them here (sadly only two in use :() but there's a little power saving to be had between the two :)
