[Case Gallery] i BLUE up my rig!! (1st mod/build)
16 (0.00/day)
Pittsburgh,PA
Processor Intel Pentium 4 3.2GHz
Motherboard Intel G965 Express ATX LGA 775
Cooling Zerotherm 92mm cpu cooler,120mm,2x80mm fans
Memory Patriot SL DDR2 1GB PC2-5300 667MHz
Video Card(s) Gigabyte Geforce 7100GS 512mb
Storage WD Cavair SE 250GB 7200rpm
Display(s) Acer 19" DVI Widescreen
Case Cooler Master Centurion
Audio Device(s) Sound Blaster Audigy
Power Supply Themaltake TR2 500W
Software XP PRO/Ubuntu(wubi)
Specs:
Pentium 4 3.2GHz w/zerotherm CF800 92mm cooler
1GB Patriot SL DDR2 PC2-5300 667MHz
WD Cavair SE 250GB,7200rpm
Lite-on w/litescribe CD/DVD burner
Thermaltake TR2 500w
Acer 19" widescreen
XP Pro/Ubuntu(wubi)
Mods:
I put a window in the side,added some fans and cathodes and also put sum sleeving on the wires(still needs sum tidying up though).
HA, im sure you can always pick out a 1st time modder. Well im putting some money in the bank for my DREAM machine, which should come out a little better- a Zalmen case with an EVGA 680i SLI mobo,Intel core 2 extreme QX6800 2.93GHz,Geforce 8800GTX,Sound Blaster X-FI Extreme,2 1GB sticks of Corsair,150GB Raptor 750GB Barracuda,Sony Lite-on,Thermaltake 1000w and to top it off water cooled with a 32" Screen !!!! Now thats sum YIELD for ya.
C
cshalflife
nice im gona cut a window in mine soon but the problem is what material do i use with the window? ne one got a clue
16 (0.00/day)
Pittsburgh,PA
What you need.
I used Optix (an acrylic sheet) it cuts very easy and 3M Super weatherstrip adhesive, works like superglue. To cut the hole in the side panel i used a hand held wheel grinder. Oh and thanks for the D, it brings back memories.
C
cshalflife
i heard ull have to put a u channel through around the window u cut , and would adhesive be better than nuts and bolts , since ive been thinking to use nuts and bolts to hold my plexi in place
nflesher87
Staff
4,518 (0.69/day)
Texas
very nice looking bro
and :toast: for pittsburgh :) that makes 3 of us so far on here from Pitt ;)
16 (0.00/day)
Pittsburgh,PA
Preferences
Adhesive is easier, nuts and bolts just have a little more work involved, but its all in what you like. With n & b's you could change the plexi to a new design alot easier though. Let me know what you decide
16 (0.00/day)
Pittsburgh,PA
Toast
And a raise of the glass to you:) PITTSBURGH, gotta luv Primanti Bros.
nflesher87
Staff
4,518 (0.69/day)
Texas
haha most def, the pittsburger :eek:
haha that thing's a beast
once we get one or two more people from the area we're going to have to have a lan party man
I was just over Wile E's place tonight he has a sick setup X2 6000 WC'd with a 2900xt
plus he just got tec cooling and a 680i
993 (0.15/day)
Los Angeles...U.S.A
Processor i7 920
Motherboard EVGA X58
Cooling eight 120mm fans, Swiftech GTZ cpu block, 3 120mm radiator, MCP655 pump, primochill tubing
Memory 6 gig G-Skill DDR3 1600
Video Card(s) GTX 285's (SLI)
Storage 500GB Western Digital
Display(s) 3 Asus 23 in inchers
Case Lian Li A77B
Audio Device(s) on board 7.1
Power Supply Corsair 1000
Software win 7 64
I voted 8/10 because:
I really like the fact that you cut your own window. Looks good. Get some damn H2O cooling on it. ;-) And invest in some zip ties and some round cables. Nicely done! 8/10 from me.
FAXA
234 (0.04/day)
Processor Intel Core 2 Duo E6300 @3.15GHz
Motherboard Asus P5N-E SLI NF650i SLi
Cooling 2x120MM fans, Stock Intel Cooler, 1x80mm fans
Memory 2GB DDR2 PC5400 (2x1GB Corsair XMS2 w/ Heat Spreaders)
Video Card(s) Inno3D 8800GTS 320MB 650MHz Core
Storage 2x 250GB SATA300
Display(s) Dell D1226H 1600x1200 CRT
Case Windowed Coolermaster Centurion 5
Audio Device(s) Creative Sound Blaster Audigy 24-bit
Power Supply 520W Corsair HX Series Modular PSU
Software Windows Vista™ Home Premium (6.0, Build 6000) (6000.vista_rtm.061101-2205)
CM5 FTW!
Well done with your 1st build..I've got the same case as you :D and I've been doing some modding on it.
To improve - tidy up the cables a bit better.
16 (0.00/day)
Pittsburgh,PA
CM5 FTW!
Hey thanks for the input, ill be putting some new pics up next week with some cable management. Where are the pics of your case? i cant find them.
5,422 (0.86/day)
Tennessee
System Name AM5
Processor AMD Ryzen R9 7950X
Motherboard Asrock X670E Taichi
Cooling EK AIO Basic 360
Memory Corsair Vengeance DDR5 5600 64 Gb - XMP1 Profile
Video Card(s) AMD Reference 7900 XTX 24 Gb
Storage Crucial Gen 5 1 TB, Samsung Gen 4 980 1 TB / Samsung 8TB SSD
Display(s) Samsung 34" 240hz 4K
Case Fractal Define R7
Power Supply Seasonic PRIME PX-1300, 1300W 80+ Platinum, Full Modular
Fix those wires!
average..
28 (0.00/day)
London
Processor AMD Athlon 64 X2 4200 (939) @2.5 38.c idle 55.c max
Motherboard Foxconn NF4SK8AA
Cooling (AC-FRZ-64P) Freezer64 Pro, (exhaust) hiper 120 fan, 1 pci exhaust fan
Memory Crucial Ballistix Tracer 1GB (2x512MB) PC4000 + kingston value ram, 2x512mb
Video Card(s) Point Of View 7600GT 256mb (PCI-E) 620/820
Storage Seagate 200GB SATAII/300 7200RPM 8MB Cache
Display(s) LG FLATRON M1917A (19" 1280x1024)
Case still wants a black p182 :/
Audio Device(s) onboard AC'97
Power Supply Corsair HX Series 520W
Software Vista x32 / Gentoo AMD64
nice work, i like your window i would not have known that was not originaly a feature of the case if you did not say, good job!.
16 (0.00/day)
Pittsburgh,PA
Wow
Thanks :) I was pretty surprised myself how well it came out. Actually it came out so well im going to do it again on an older case i have and build a water cooling system to go with! Anybody got any suggestions?
V
vixstar
Vix
i luv the powerful blue
i think in my opinion
a mix of colours would be beta
but overall
very gd
