I can,t get 3DMark99 or 2000 to work on 2000
2,463 (1.80/day)
UK
3DMARK99 on the board says i need drectx6.1 ,2000 ask for direct 7 and something about 3d accelerator?And one or both the apps say they come from somewhere else"Of course they do i can,t get on line with 2000.I have tried using the ones on Phils site ,and the ones from the 3dmark site with the same results. :(I have tried putting them direct to the drive as opposed to flash drive.I wish someone could do a updated integral version of 2000 and ME as well as 98se like they do for XP and one that has 3dmark built in.
7,870 (5.12/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
3DMARK99 in the board says i need drectx6.1 2000 ask for direct 7 and something about 3d accelerator?And one or both the app comes from somewhere else"Of course it does i can,t get on line with 2000.I have tried using the ones he put on his site and the ones from the 3dmark site with the same results. :(
Try installing these two mate.
3,033 (6.45/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
@Dr. Dro
Not sure if it will be as straightforward, though won’t hurt to try. I distinctly remember something about having to use hacked .dlls on 10/11 to make those ancient 3DMarks work. Will have to try and dig up that info.
7,870 (5.12/day)
São Paulo, Brazil
@Dr. Dro
I think he's trying to run it on Windows 2000 at least from what I read in the thread title
3,033 (6.45/day)
@Dr. Dro
Gotcha, that wasn’t there when I replied at that moment. Yeah, in that case just installing the runtimes should do the trick.
2,463 (1.80/day)
UK
I tried directx7 it says it is to new for 2000 o_OThanks anyway Dr:)Why does it not work on mine , it says it does on the site that,s weird.:(
@Dr. Dro
I have seen posts about this all the time and even back in the day. :(
822 (0.12/day)
Terminus GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) RX 9070 XT Hellstone OC
Case Rocketfish (Lian Li) e-ATX (2006)
Audio Device(s) Harman Kardon HK695 2.1
Mouse HP Gaming wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
For one of the benches to work, you need to copy a file to one of the futuremark folders. I'm going to be home later today & will see if I can find what's needed.
2,044 (4.25/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) 1080P 144hz
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
3dmark 99 just needs to be installed and exe run in compatibility mode W98.
W2000 you can get to run on XP and earlier, maybe W7 and that's it. I have not been successful to run 3Dmark 2000 on w10 or 11.
GL.
Edit, nvm, I see better now, you ARE running windows 2000(ME?). Never mind lol.
7,870 (5.12/day)
São Paulo, Brazil
Did you install Service Pack 4? I think it's needed for most of this stuff to work. The DirectX 8.1 installer should be enough. 9.0c is supported up to February 2006 version on 2000 SP4.
Also it's been a while but there's an "unofficial SP5" that features all service packs optionals and update rollups in one, worth a try
2,463 (1.80/day)
UK
@Dr. Dro
I don,t know what i am doing tried to download runtime for 2000 . :(
Thanks very much 68olds :)
822 (0.12/day)
Terminus GA, USA
System Name Gamer
Follow the instructions for the 3dMark99 fix. Unzip the DDRAW.zip and copy the DDRAW.dll into the \3dMark99 folder. Let me see if I can remember what I did to get 3dMark2000 working...
BTW, what video card are you trying to bench?
  • DDRAW.zip
  • readme.txt
2,463 (1.80/day)
UK
x400 i have tried it is not working
822 (0.12/day)
Terminus GA, USA
System Name Gamer
What is an x400?
2,463 (1.80/day)
UK
What is an x400?
I got that wrong ,this one here. GeForce MX4000.I have put a sticker on the card so i remember it for any time i use it.:)
1,879 (0.32/day)
UK Warwickshire
System Name PC-Chips
Processor AMD Ryzen 7 5700x3D
Motherboard Asus ROG Strix B550-F Gaming.
Cooling White arctic liquid freezer iii 360 a-rgb AIO.
Memory Patriot Viper 32gig dual channel 3600mhz
Video Card(s) PowerColor HellHound RX 7900 GRE OC.
Storage 2 Samsung 860 EVO's 500gig / 2TB crucial P3-NVME / WD-BLUE SN550 1TB M.2 / SP A55 512gig / 8TB HDD
Display(s) TCL 50-inch 4k TV freesync HDR
Case White NZXT H9 Flow Dual-Chamber
Audio Device(s) Realtek S1220A - Yamaha A-S501 AMP - Wharfedale diamond 9.1 speakers - Wharfedale SW150 sub
Power Supply EVGA SuperNOVA G6 750W 80+ Gold
Mouse Some cheap wireless thing
Keyboard Razer Cynosa lite
VR HMD Oculus Quest 2 128gig version
Software Windows 11 pro 64bit
If that is the same card as this one damn i am not suprised it's a pain to get working.
822 (0.12/day)
Terminus GA, USA
System Name Gamer
2,463 (1.80/day)
UK
I want use that card anymore. :)i use this one Sapphire. ATI Radeon 09600 XT. i also have the pro version.i did hear that the other card was the pits,
Which driver are you using?
Edit: deleted link to wrong driver...
Latest driver from nvidia.
I want be using that one after seeing that video.
Thanks for that link 68olds :)
