I need a PSU for one HDD and one ODD
Trackr
265 (0.05/day)
System Name White Phoenix
Processor Intel Core-i7 2600k @ 5.0Ghz 1.45v 24/7
Motherboard Gigabyte 'P67'-UD7
Cooling Dual-Fan TRUE (Lapped)
Memory G.Skill 16GB (4x4GB) 2000Mhz CL9
Video Card(s) nVidia GTX 480 SLi
Storage Crucial RealSSD C300 256GB
Display(s) Dell 'PLP' - 2007FP | 3007WFP-HC | 2007FP
Case Antec p190 (Modded)
Power Supply Silverstone 1000w (Single-Rail)
Software Windows 7 SP1 Ultimate 64-bit
8,257 (1.32/day)
Mouse Logitech G604s
The 130w should do. Id personally get the 200w since its $12 though. Gives you more breathing room as well.
19,371 (3.57/day)
A HDD and an optical (is that what ODD is?)? That, even on spinup, wont use more than 30W. After spinup, Like 10-15 at most...
Trackr
265 (0.05/day)
Well, I tried one of these guys out:
It exploded after 5 minutes.
So, I'm thinking I need something stronger.. but I don't know what.
Those PSUs seem tohave a 24-pin connector, which I don't need. Would it work without connecting the 24-pin? All I need is a molex.
8,257 (1.32/day)
The 24pin is what would generate the power to the other peripherals. I honestly dont know how a secondary power supply would work as I have never used one before; seeing that it uses a 24 pin power connector and the main PSU uses the same, i dont know where you would plug it in.
Athlon2K15
HyperVtX™
7,909 (1.19/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
grab some 14 guage wire and wire some new ones in?
Trackr
265 (0.05/day)
193 (0.03/day)
Nashville, Tennessee
System Name DeathAdder
Processor Intel Core i7 6700K @4.6 Ghz 1.31v
Motherboard Gigabyte Gaming 7 Z170X
Cooling NZXT Kraken x61 280mm
Memory 4x8GB G.Skill 3200Mhz
Video Card(s) MSI NVidia GeForce 980 Ti 6GB
Storage 2x Samsung 850 EVO 500 GB + 16 TB in HDDs
Display(s) LG UC87C 34" Ultrawide 3440x1440
Case NZXT H440 White
Audio Device(s) JBL LSR310S + 2x JBL LSR308
Power Supply EVGA P2 Platinum 1000 W
Mouse Corsair M65
Keyboard Corsair K70 RGB
The adapter didn't work because it was low on 5v rail.
A secondary power supply would work but you'd have to manually switch it on and off, and short two wires.
The best solution according to me would be to get some wire and create your own sata and molex adapters. Just get the shoe from an old PSU, and power it from the 24 pin connector.
You can easily create one.
And then use wires from Molex connector to create a SATA connector.
or get a molex to sata adapter.
4,213 (0.72/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
I would, but I have no experience.
I would need a tutorial.
It's pretty easy, there are just 3 wires you need to split, i believe. the 12v one, 5v and ground. if i remember correctly.. yellow is 12v and black is ground and red is 5v, but u need to double check.
You can easily google for the pin layout of molex and sata power connectors
1,539 (0.27/day)
Canada/Québec/Montreal
System Name Main PC
Processor PII 925 x4 @3.724GHz (266x14) 1.525v NB 2660 1.425v
Motherboard Gigabyte AM3 GA-890XA-UD3 (790x+SB850)
Cooling Scythe Mugen 2 rev.B
Memory Hyperx 8GB (2x4) 1600@1418 8-7-7-20-27-1t
Video Card(s) GTX 680
Storage 256GB SSD / 2TB HDD
Display(s) LCD Samsung 24" 16:9
Case Cooler Master HAF 912
Audio Device(s) On-Board HD
Power Supply CM 750w GX |3.3v@25a|5v@25a|12v@60a
Software Kubuntu dual boot /Windows 7 Ultimate 64bit
Benchmark Scores later...
Trackr
265 (0.05/day)
Okay but, what do I do with the cables? Do I solder?
I guess a video/image tutorial would really be necessary, because I'm not going to cut up my 24-pin without knowing exactly what I'm getting myself into.
Why not just buy a cheap PSU ~$30?
Or get a little bit better PSU for around $50 should be able to get an 700w for that price
I would, but it has to be tiny. I have about as much space left in the case as a 2-3 slot cooler.
Best thing to do , unless you are telling us that there is no molex at the end of the wires , cut off?
193 (0.03/day)
Mouse Corsair M65
This is what a 24 pin connector looks like
Just attach a wire to any +5v DC rail, and another to any +12v DC rail, and one to the Ground rail and then use the diagram I posted earlier to create your Molex and Sata connectors.
12v rail would be yellow in color, Ground should be black and 5v rail would be red in color. Now it should be easy
4,213 (0.72/day)
Vietnam
You should just be able to buy some crimps and some heatshrink. it's what i did when i cut up some of my power connectors, i had no idea what i was doing either. Just follow the colour coding of the wires and the molex diagram.
i.e. cut a black cable and strip it a little then reconnect it including another wire with a crimp. add a little solder if you want a stronger connection and put some heat shrink around it (put the shrink on the wire before you connect the joint)
You only need to split 3 wires, then you can just hook up a couple of molex splitters for the rest.. Not the most elegant solution but it should work without needing to add a second psu to your case.
Edit - If you use crimp connectors, you must add solder
http://www.techpowerup.com/forums/archive/index.php/t-117205.html
http://www.pcmech.com/forum/computer-hardware/220788-splicing-into-atx-psu-cables.html
You could do an inline wire splice.
http://www.instructables.com/id/Master-a-perfect-inline-wire-splice-everytime/
If you add a second psu, you will have to permenantly short two of the wires and use the switch at the back to turn it on.. either that, or split some of the wires on both psus and connect them together.
http://www.evilbobbins.com/?page_id=157
edit 2 - I recently sleeved some cables on my old power supply, i'm not sure if i soldered all the joints or not. anyway, the 12v rail up dying a couple of months later. i'm not sure if it was the low rating (450w) the age (2+ years) or the fact that i had cut and reconnected some of the wires. So yea, you definitely need some expert advice if you do decide to split a connector.
Trackr
265 (0.05/day)
*shrugs*
I just don't think I can do this without pictures, no matter how much I read about it.
Getting the second PSU seems more safe. If I lose the main PSU, I'm toast.
