I need help to unlock the "Advanced" settings tab in my bios
31 (0.04/day)
I need help to unlock my advanced settings in my bios because i want to tweak some settings
iv'e tryed dozens of thins and nothing worked so please i need some help
  • LENOVO-6DCN91WW(V8.05).rom
There is no public BIOS editor for Insyde ROMs.
Look online for hidden hotkey combos like CTRL+F1 in the BIOS screen.
Or maybe:
Power off the laptop. Power button to turn on → F2 to enter the normal BIOS → Power button to turn off → then press the following keys in sequence:
F1 → 1 → Q → A → Z
F2 → 2 → W → S → X
F3 → 3 → E → D → C
F4 → 4 → R → F → V
F5 → 5 → T → G → B
F6 → 6 → Y → H → N
Power button to turn on → F2 to enter the BIOS which should now have an "Advanced" tab.
Or maybe just use ThrottleStop if you trying to change CPU settings.
To activate the Debug Bios:
Enter BIOS → disable OneKeyBattery → save and exit. Poweroff the laptop. Power button to turn on → F2 to enter the normal BIOS → Power button to turn off → then press, moving fast, the following keys in sequence
F1 → 1 → Q → A → Z
F2 → 2 → W → S → X
F3 → 3 → E → D → C
F4 → 4 → R → F → V
F5 → 5 → T → G → B
F6 → 6 → Y → H → N
Turn on the power button → F2 enters the hidden Debug BIOS.
Then go to;
Advanced → Power & Performance → CPU-Power Management Control → CPU Lock Configuration → CFG Lock → Disabled
Then go to;
Advanced → System Agent (SA) Configuration → Graphic Configuration → DVMT Pre-Allocated Selection → DVMT Pre-Allocated → Set to 160MB
save and exit.
There is a lot of customizable in the Debug Bios, just change the two points CPU-Lock & Graphic DVMT !!!!
With other points you break the system.
If it doesn't work, look in this page for a possible BIOS editor.
i dont think thiss is goood
it crashed
what file am i supposed to grab
I can only change variables but i dont know wich one to change
i only have the variable if i klick on to the setup tab the window just closes
I need some explenation its kina complicated for me to understande
the older versions just show a white screen with lines
got his window :)) but again justvariables
when i chose image variable editor this shows up
this is prabably because i am running a legacy os
This is the dump variable i do not know what to do wiht it or what it is
