I need help with a .bat file.
Flpoolboy
5 (0.00/day)
Hi, I was wanting to make a .bat file so that when you open it replaces a certain file with a different file, the files im trying to replace are .png's and .mesh's.
570 (0.25/day)
PL, Krk (JPN, Tokyo)
System Name Nilin
Processor Ryzen 9 5800x
Motherboard Asus Rog Crosshair VIII Hero Wifi
Cooling Lian Li Galahad AIO 360
Memory G. Skill TridentZ Neo 32gb 3600Mhz CL16-16-16-36
Video Card(s) Asus TUF RTX 3080
Storage Samsung Evo 960 250gb (System), Samsung Evo 860 500gb (Misc), ADATA SX8200PNP (Games)
Display(s) LG 27" UHD IPS, LG Ultragear 27" WQHD Nano IPS
Case InWin 303 (7x Fractal Prisma 120mm)
Power Supply Tt Toughpower Grand RGB 850W
Mouse Razer Viper Ultimate
Keyboard SteelSeries Apex 3
Benchmark Scores https://www.3dmark.com/fs/21022952 (old system)
5,576 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
I think he wants to replaces files not rename them
570 (0.25/day)
System Name Nilin
oh, i thought he meant extension change... oopsie!
bug
13,950 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
I'm not sure I understand the question, but if I do you need:
copy /y <replacing_file> <file_to_be_replaced>
Deleted member 67555
Yeah.. Run that in an Event for your script
1,092 (0.20/day)
Essex, England
Processor Ryzen 5900X OC 5150Mhz
Motherboard Asus ROG Crosshair VIII Formula
Cooling Custom EKWB for CPU, VRM's & GPU with 2x 480mm Rads
Memory Gskill TridentZ 3600 Mhz C17
Video Card(s) Powercolor RX 6900XT Liquid Devil Ultimate
Storage Samsung 970 Evo Plus 2TB x 2 Raid0
Display(s) MSI Optix MAG272CQR 27 1440p x2
Case Corsair 1000D
Audio Device(s) onboard 7.1 HD Audio
Power Supply Seasonic PRIME Ultra 1300w PSU
Mouse Logitech G300s
Keyboard Logitech G19s
Software Windows 10 64Bit
Benchmark Scores R20 : 9329 Timespy: 21455
So copy command as already said,
copy /y (copies & suppresses prompts)
or
copy /-y (copies & allows confirmation prompts for overwriting)
Only thing I would say, I don't like copy overwriting with batch files as if there is an issue (a copy is corrupt) then you lose your original.
What is the copying for or how does it work, I'd possibly suggest a more complex but also safer method where the originals are moved, data is copied (not replacing the originals) and then the originals can be deleted at a later date (ie two days later maybe by the batch file)
But depends, you've not given details on what it's for.
bug
13,950 (3.95/day)
bug
13,950 (3.95/day)
I tried to do copy but I kept getting syntax error.
Ok, tell me where's the file you want to copy and where's the file you want to replace and I'll give you the copy command.
Flpoolboy
5 (0.00/day)
Source: C:\Program Files (x86)\Roblox\Versions\version-8ea9490e0ca04991\content\textures
Target : C:\Users\flpoo\OneDrive\Desktop\Roblox Skin Changer\MAIN FILES\faces\Epic Face
bug
13,950 (3.95/day)
copy /y "C:\Program Files (x86)\Roblox\Versions\version-8ea9490e0ca04991\content\textures\*.*" "C:\Users\flpoo\OneDrive\Desktop\Roblox Skin Changer\MAIN FILES\faces\Epic Face"
I think "textures" is actually a folder. If it isn't, then instead of "textures\*.*" just write "textures".
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.42/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
For future reference, there is xcopy too which has a lot more options.
