I need the model of these Gate Drivers
12 (0.01/day)
System Name Mr Bottleneck
Processor Core i7-7700K
Motherboard Gigabyte GA-Z170 D3H
Memory G.Skill Aegis DDR4 8GBx2
Video Card(s) Asus Dual RTX 4070 OC
Storage Samsung Evo 860 SSD
Display(s) Samsung SyncMaster BX2231
Case Cooler Master CM 590 III
Power Supply Seasonic SS-750JS
Hello folks!
The card is a Zotac GTX 970 AMP Extreme Core Edition, and the high side MOSFETs failed after replacement.
I need the part number of these Gate Drivers so I searched for what is written on them, but I can't find the model/part number. They seem like electrical values rather than part numbers if I'm not mistaken. Any Ideas?
42,841 (6.70/day)
Reach out to @buildzoid which has a youtube channel called Actually Hardcore Overclocking and @Andy Shiekh for pcb repairs
1,927 (0.43/day)
UK
System Name TITAN Slayer / CPUCannon / MassFX
Processor i7 5960X @ 4.6Ghz / i7 3960x @5.0Ghz / FX6350 @ 4.?Ghz
Motherboard Rampage V Extreme / Rampage IV Extreme / MSI 970 Gaming
Cooling Phanteks PHTC14PE 2.5K 145mm TRs / Custom waterloop / Phanteks PHTC14PE + 3K 140mm Noctuas
Memory Crucial 2666 11-13-13-25 1.45V / G.skill RipjawsX 2400 10-12-12-34 1.7V / Crucial 2133 9-9-9-27 1.7V
Video Card(s) 3 Fury X in CF / R9 Fury 3840 cores 1145/570 1.3V / Nothing ATM
Storage 500GB Crucial SSD and 3TB WD Black / WD 1TB Black(OS) + WD 3TB Green / WD 1TB Blue
Display(s) LG 29UM67 80Hz/Asus mx299q 2560x1080 @ 84Hz / Asus VX239 1920x1080 @60hz
Case Dismatech easy v3.0 / Xigmatek Alfar (Open side panel)
Audio Device(s) M-audio M-track / realtek ALC 1150
Power Supply EVGA G2 1600W / CoolerMaster V1000 / Seasonic 620 M12-II
Mouse Mouse in review process/Razer Naga Epic 2011/Razer Naga 2014
Keyboard Keyboard in review process / Razer Blackwidow Ultimate 2014/Razer Blackwidow Ultimate 2011
Software Windows 7 Ultimate / Windows 7 ultimate / Windows 7 ultimate
Benchmark Scores cinebench 15.41 3960x @ 5.3ghz Wprime32m 3.352 3960x @ 5.25ghz Super PI 32m: 6m 42s 472ms @5.25ghz
12 (0.01/day)
5,192 (3.75/day)
Colorado, U.S.A.
Software Windows 11 Home
1,927 (0.43/day)
UK
Thank you so much.
BTW can I use NCP81062 instead?
It is pin compatible and the specs seem close enough so that should be ok.
Not my fault it if fails tho.
42,841 (6.70/day)
5,192 (3.75/day)
Colorado, U.S.A.
12 (0.01/day)
No need to worry about that :) The card is already dead and I'm desperate to fix it by myself as I can't find somebody experienced enough where I live. Thanks a lot.
5,192 (3.75/day)
Colorado, U.S.A.
12 (0.01/day)
12 (0.01/day)
I couldn't replace the MOSFET drivers yet, but I noticed something, which is while measuring the resistance of the shorted MOSFETs and then I short pin#1 (boot) and pin#2 (PWM) in the MOSFET driver, the short in the MOSFET is gone.
Can anyone help to determine if the MOSFET driver is faulty or something else?
Xenon
2 (0.00/day)
I dont understand this type of problems but can i ask you something? I have the same card and bios chip died on me. I need the full bios and i see that you have no problems with bios. Can you put the bios chip on a reader and backup it? Thanks
