I need to find vbios for gigabyte rx 580 rev 2.0
didula bhagya
6 (0.01/day)
Count von Schwalbe
Nocturnus Moderatus
3,261 (2.79/day)
Knoxville, TN, USA
Can you tell us what your card is doing, that makes you think it needs a new VBIOS?
A screenshot of the main screen of GPU-Z would help as well.
1,933 (0.31/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
some times gpu get black screen while gaming
Does the screen stays black or just for a moment? If it stays black and you must reset your computer then you likely have a VRM issue.
Put your GPU FAN on 100% and see if the issue still occurs. If it happens less often, your VRM is overheating (or could be dying lowly).
Count von Schwalbe
Nocturnus Moderatus
3,261 (2.79/day)
Knoxville, TN, USA
Looks like you are fine from a VBIOS perspective. I would monitor your temperatures and try limiting clock speeds, to see if that helps.
didula bhagya
6 (0.01/day)
max temp 83°C is that a issue
stay black and after restart it work normal max temp get 83°C
Count von Schwalbe
Nocturnus Moderatus
3,261 (2.79/day)
Knoxville, TN, USA
83 should be ok, but it is a tad high. I would recommend repasting your GPU and swapping out the thermal pads, and while it is open, inspect it for damage.
Tatty_Two
Gone Fishing
25,960 (3.74/day)
Worcestershire, UK
Software Win 11 Home x64
Strange, I have just checked about 8 bioses in our database and none that I have checked have Micron memory matching your device ID (I only saw Samsung and Hynix) for that model card although I didn't check everyone because there were loads), the first Bios I found with micron memory was a mining Gigabyte 8GB also listed as a Gaming model with a different device ID ............
VGA Bios Collection: Gigabyte RX 580 8 GB | TechPowerUp
Did you buy the card used? When you repasted did you check the memory?
didula bhagya
6 (0.01/day)
i bought used care and no any damage model is gigabyte rx 580 8gb rev 2.0
Count von Schwalbe
Nocturnus Moderatus
3,261 (2.79/day)
Knoxville, TN, USA
I found about a dozen with the matching device ID and Micron HFB memory. However, we don't have the Rev 2.0 in our database, so I cannot check if there are any changes between revisions - these all seem to be for Rev 1.0 or Rev 1.1, if they say at all.
I am also not positive there is an issue with the VBIOS, but I will link a couple that might work. @didula bhagya Can you try and use MSI afterburner to limit power and/or clocks and run a couple of tests? That might be the problem. These cards are getting pretty old, they may be degrading to the point where they don't meet advertised clocks.
If power limiting doesn't work:
didula bhagya
6 (0.01/day)
sure thanks for the advice i will try that :):love:
1,933 (0.31/day)
I think your VRM is busted. Does a second/third/forth crash direcly happens again after a reset when you start gaming again?
Can you place a case fan to blow cold air on this part of the graphics card?
If it takes longer to crash when a fan has been put on that spot, it means your VRM is unstable and can't longer provide power properly when it is hot.
1,891 (1.38/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Does this black screen appear ONLY when you are gaming ?
Or even in web browsing and everything else ?
