For some laptops, the early BIOS versions left the CPU voltage controls in the FIVR window unlocked. Your FIVR screenshot shows that voltage control has been Locked by the BIOS.and for him all he options worked perfectly fine
Do you have a Nvidia GPU as well as the Intel GPU? If you also have a Nvidia GPU then I do not bother undervolting the Intel GPU. There is usually very little to be gained.should i undervolt the igpu?
Try it and find out. I never do because I do not find any meaningful gains when undervolting the System Agent. Maybe your CPU will be different.should i undervolt the system agent
it's so annoying man when you try trying to get most out of your cpu.Yeah man i have exactly the same problem, while on normal circumstances my cpu is from 3.4 to 3.6 Ghz and while under load it starts at 3.2Ghz and then after 5 seconds drops to 1.7Ghz and then rises again
@Hamse_Baydaani
No bro i didn't touch it's the default settings the only thing i changed is the speedshift to 32.@Hamse_Baydaani
Did you try increasing the turbo power limits?
These settings are telling your CPU to PL1 power limit throttle during any long term test at 17W. Your screenshot with Limit Reasons opened up shows that the CPU is doing exactly what you are telling it to do. Clear the Disable Controls box and try increasing the PL1 power limit to 25W and see if it helps. Better yet, try increasing both power limits to 35W. You have great cooling so no worries.
If you are using an early BIOS version, maybe your computer will allow you to run the CPU at the higher power level. Most computers with updated BIOS versions will not allow you to do this.
The cooling on the hp probook isn’t the best, i actually had to undervolt because i was always thermal throttling while gaming@Hamse_Baydaani
But how did you unlock the fivr control then, because i had to downgrade my bios version to a stable 2020 versionit's so annoying man when you try trying to get most out of your cpu.
i changed the settings as you said and i don't see any improvement it's still doing the same thing it even decreed the clocks little bit i think. and for the bios i think windows updated it recently you can see it's few months ago version is it possible to downgrade to have more bios options because my bios there isn't power option settings at all and i sent you the log file running cinebench23.
My laptop is hp to hp 15 but i used to thermal throttling too then the undervolt helped alot.The cooling on the hp probook isn’t the best, i actually had to undervolt because i was always thermal throttling while gaming
Yeah man, but i’m actually on a weekend trip now i’ll be back tomoroww so i’ll send you a screenshot, but i think i can set it to maximum performance etcMy laptop is hp to hp 15 but i used to thermal throttling too then the undervolt helped alot.
I don't know bro ever since i installed throttlestop all my settings were unlocked maybe they didn't locked when they updated my bios cuz i see from bunch people that newer bios locked the bios.
Bro does your bios gives you options to change power options and such?
The log file shows that the CPU is PL1 power limit throttling right at 17W. It is common for HP laptops to use an embedded controller (EC) which is used to force this limit to the CPU. The MSR and MMIO power limits that ThrottleStop has access to are ignored. The lower EC power limit wins control of the CPU. There is nothing you can do about this limitation.i don't see any improvement it's still doing the same thing
It realy sucks bro i7 8550u is power hungry to be honest and the fact that manufacturer messed up big time releasing locked power limit on this system is realy overwhelming.The log file shows that the CPU is PL1 power limit throttling right at 17W. It is common for HP laptops to use an embedded controller (EC) which is used to force this limit to the CPU. The MSR and MMIO power limits that ThrottleStop has access to are ignored. The lower EC power limit wins control of the CPU. There is nothing you can do about this limitation.
Some manufacturers leave the power limits completely unlocked when they first release a new laptop. This makes for some good initial reviews. After that, a BIOS update might be released that enforces a much more restrictive power limit. I am not sure if it is possible to find or install an early BIOS version. Many manufacturers prevent going back to an earlier BIOS version.
For me downgrading the bios unlocked undervolting, so it might unlock the power limit for you.It realy sucks bro i7 8550u is power hungry to be honest and the fact that manufacturer messed up big time releasing locked power limit on this system is realy overwhelming.
I guess i have to use it like this i don't think even downgrading bios will help me, but i will try if i can downgrade and see if helps.
Maybe it's possible but it's unlikely my sis hp is same too always doing this and her laptop have early bios version and it's still the same just like uncleweb said we can't do anything when that Embedded controller have full authority over throttlestop tpls limits.For me downgrading the bios unlocked undervolting, so it might unlock the power limit for you.
Yeah sadly, but i wanted to know if you undervolted the igpu or system agent because that also contributes to overall gaming performanceMaybe it's possible but it's unlikely my sis hp is same too always doing this and her laptop have early bios version and it's still the same just like uncleweb said we can't do anything when that Embedded controller have full authority over throttlestop tpls limits.
I didn't undervolted those i only undervolted the cpu core and cache i heard those other settings aren't that important and doesn't give you huge performance too but i didn't try it yet.Yeah sadly, but i wanted to know if you undervolted the igpu or system agent because that also contributes to overall gaming performance
Ah okI didn't undervolted those i only undervolted the cpu core and cache i heard those other settings aren't that important and doesn't give you huge performance too but i didn't try it yet.
Yeah, i'll take the risk i just want the best performance out this cpu
Bro i rolled the bios version back to 2019 and it's now actually unlocked!
Man, thanks for the help i’m now getting 3.6 ghz stable at 69 degrees while running cinebench
