I want to set up a live underwater web cam.
trickson
OH, I have such a headache
7,595 (1.06/day)
Planet Earth.
System Name Ryzen TUF.
Processor AMD Ryzen7 3700X
Motherboard Asus TUF X570 Gaming Plus
Cooling Noctua
Memory Gskill RipJaws 3466MHz
Video Card(s) Asus TUF 1650 Super Clocked.
Storage CB 1T M.2 Drive.
Display(s) 73" Soney 4K.
Case Antech LanAir Pro.
Audio Device(s) Denon AVR-S750H
Power Supply Corsair TX750
Mouse Optical
Keyboard K120 Logitech
Software Windows 10 64 bit Home OEM
I need some help , I have an Idea (Not sure it's a good one) about setting up a live underwater video of my Koi pond.
It is roughly 45 feet from the pond to the computer for hard wiring a cam and Wifi as well.
I have no idea what I am doing. I have an Idea and haven't a clue as to what I need to make it reality.
This is why I am asking you all.
Example of my Idea.
My pond is HUGE I need to cover 3,000 Gallons 20'x8.5'x2.75'
I also have a bridge spanning my pond and I would like to install a cam facing the waterfall and top of the water for feeding time.
Any ideas as to the hardware / software I will need. I mean I know I need a set of cam's but what kind and well GO....
Thank you all in advance.
the54thvoid
Intoxicated Moderator
12,663 (2.37/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
Frankly, it sounds cool. But with a 20' x 8' area. how would the clarity be underwater? I'm not a specialist at all on this (sounds quite niche, to be honest) but it's certainly doable. I'd make sure you figure out good, underwater cams. Things designed specifically to filter the wavelength properly under water.
Good luck to you on the project and when it's up and running, you've got to share the link.
:toast:
dorsetknob
9,106 (1.29/day)
wireless IP Cams
Make a waterproof Sealed Tank
fit cam inside tank
Run Areil and power through waterproof connections (MICC comes to mind)
weigh tank down with weights
GHETTO IT
for software use your Browser
1,486 (0.33/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
Maybe this ? But it looks expensive. Or if you are handy at building stuff, like @dorsetknob said
Or These ?
12,538 (1.91/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Many of these ponds have underwater lights where the lights and electronics for the lights are sealed behind glass, but accessable from a dry access point on the ground surface. It seems the camera could easily go in one of those. I would, however, look for a camera that has a detachable antenna so you could raise the antenna above the ground/water level - otherwise I think reception of the RF signal may be a problem.
2,664 (0.69/day)
Alabama
Processor Ryzen 2700X
Cooling Scythe Big Shuriken 3
Memory C.R.S.
Video Card(s) Radeon VII
Software Win 7
If it's setup shallow in depth it should work but water does tend to interfere with RF signals. However since it's probrably going to be a really shallow setup I don't believe it would matter (Much if at all).
Lighting underwater is another thing and even the clarity of the water itself could be an issue at times but those are things you'll have to work with, figure out and resolve as time goes, dorset's suggestion is probrably the best way to go with it.
JC316
Knows what makes you tick
9,397 (1.39/day)
System Name Budget Gaming
Processor AMD FX6300
Motherboard Gigabyte 880GMA-USB3
Cooling Coolermaster Hyper 212+
Memory 8GB Ripjaws DDR3 1600
Video Card(s) HD7850 1GB
Storage 1TB Sata2
Display(s) Acer 24" LED
Case Generic black
Audio Device(s) Stock onboard
Power Supply FSP Aurum Gold 650W
Software Windows 7 Home Premium 64bit
Water clairty is going to be a huge problem. I'm a scuba diver and I've filmed in fresh and salt water with visibility ranging from 20ft to 200ft. Here is some of my footage.
30-40ft vis, filmed from about 10 feet away.
10-15 foot vis, filmed from about 5 feet away.
trickson
7,595 (1.06/day)
Planet Earth.
Cooling Noctua
Mouse Optical
I love all the feedback thank you all.
Water clarity is not really an issue, What I mean to say is I can see the bottom of the pond just fine, Very little alge at all ( I run a 35watt UV filter light. I have a 3 stage skimmer filter and a 8 stage waterfall filter. As for the amount of viewable area, Now that is the hard part.
Can I setup multiple WiFi action cams?
WiFi Action cams is what I was looking at they are cheep too.
I think I want to forgo making boxes and things and just have cams that are able to live underwater for there life. 2 would be nice then one on the bridge to show surface water and fish feedings.
Does this sound like something you would watch? I could post up a video of the fish there are Koi and goldfish, All are getting HUGE!
I love the video's! AWESOME, But you are summing around in fresh water it is not filtered out not skimmed off so that natural water you are in is going to have more crap floating around. My water for the most part is clear as tap water. you can even see the food on top of the water.
122867
2,100 (0.50/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
They don't do anything. What are you going to watch......them grow? :p
trickson
7,595 (1.06/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Well Yes that is one thing you can do. And no they swim around and are really peaceful to watch. I mean "they do nothing" is a relatively hollow comment.
They look really cool colorful and some times they chase one another around so fast through the pond makes your head spin.
dorsetknob
9,106 (1.29/day)
My Brother Raise's Coy
Apparently it can Be Very Profitable ( Big Coy go for big money)
You should also Net the pond to keep out predators
12,538 (1.91/day)
Nebraska, USA
Mouse Logitech M190
Agreed. Why would aquariums in homes and offices be so entertaining if nothing to watch?
I don't know about the wifi action cams but I do know my auto-sensing security lights work by sensing motion as well as heat. Fish often just stay stationary or move about very slowly so not sure how they would be triggered by motion - especially with smaller fish. And of course fish are cold-blooded so detecting heat would not work. So it might just have to be on full time.
See: https://www.reef2reef.com/threads/how-to-live-underwater-webcam-fish-cam.246664/
trickson
7,595 (1.06/day)
Planet Earth.
Cooling Noctua
Mouse Optical
This will be a 100% up all the time thing. No need for any motion detection or things like that.
My Koi pond is covered with a 20'x20' canopy sail. no worries about any thing getting at my koi or other fish the pond is lined with various sized bolder and rocks and is deep at the deep end it is 3 foot deep and at the shallowest end it is 2.5 feet deep. very hard for any predator to get at my fish.
583 (0.28/day)
Umm, doesn't GoPro have a HDMI output ?
Just plug the cables, add silicon over the connectors and dunk it.
Then do whatever you need to do outside the pool with the other end of the HDMI cable.
trickson
7,595 (1.06/day)
Planet Earth.
Cooling Noctua
Mouse Optical
That sounds like what I want. Plug and play would be so cool.
And contrary to what some may say, My fish are very active nothing boring going on in my pond.
I don't mean to boast but everything you are about to see I have done myself.
122868
122869
122870
2,100 (0.50/day)
Spencerport NY
System Name Master
Because aquariums house odd, colorful fish usually.
Koi and Goldfish are just Carp basically. A garbage fish.
I do like the pond construction tough. It's very nice. Would rather see water lilly's in it, but that's just personal preference.
5,853 (2.96/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
If it's on teh internetz, somebody will watch it.
Low quality post by Bill_Bright
12,538 (1.91/day)
Nebraska, USA
Mouse Logitech M190
Low quality post by Mr.Scott
2,100 (0.50/day)
Spencerport NY
System Name Master
Yeah right.
Let me Google that for you: koi
3 1/2 years stationed in Japan tells me Koi = Carp in Japanese.
Don't be a dick Bill. It's not necessary.
trickson
7,595 (1.06/day)
Planet Earth.
Cooling Noctua
Mouse Optical
LOL yes Carp and also Koi (carp) can live a very long life 80+ years and get very big as well.
As for Wifi underwater web cams go any one know about these?
Wifi cams.
Wouls getting 2 of these do the job?
95Viper
Super Moderator
12,785 (2.22/day)
Stay on topic and no calling names.
Be civil or be gone.
Thank you and have a nice discussion.
trickson
7,595 (1.06/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Oh also would I need to setup a "server"? And / or a dedicated system for the web cams at all times?
1,486 (0.33/day)
Anchorage Alaska
You will need something that has constant power to it. GoPro and the other action camera's have about a 3-4 hour use on battery and the housings are not normally waterproof for any external cables to be plugged in.Unless you want to go switch batteries every couple of hours. I ran one like what you linked from ebay as a dash cam for a year and acouple of months. One battery died after 4 months and then the lcd screen shorted out and wiped it out.
Being submerged and running 24/7 is the issue, I know the ones I linked earlier are a bit pricey but will do the submerged part fine. If you were just streaming from above the water(dry ground) then 2 gopro's and a dedicated system to stream would be good.
EDIT: This A much cheaper version and it should work fine.
3,984 (1.16/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
I think the major problem you will run into with action cameras will be a constant power source and the fact they aren't designed to live in the water. Only spend some time in it. I think you will need to find hardware built for this purpose. I like to tinker with shit and what I constantly find out is that you can make stuff do things they aren't designed for...but for only a time.
Considering some recent movies put out that people flock to, you could probably charge for it. Just put a Godzilla suit on one and a shark suit on another.
