I would appreciate your help with the pure ROM of the OCPC RX580 4GB DDR5 graphics card.
korea_man
8 (0.01/day)
Hello.
I am a person who lives in Korea.
I got an RX580 this time, but the bios broke, so I'm currently looking for a pure ROM.
The model is OCPC and is confirmed by the RX580 4GB DDR5 SK Hynix RAM model.
I tried to find and apply various ROMs, but I keep failing, so I upload them like this. If you have a graphics card of the same model as me, I sincerely request a bios.
If you need any more information, please let me know and I will post it right away.
I hope you always have a happy day.
Hello, can you make a photo of the whole card and a good picture of the GPU as well?
Those are good. There is no BIOS specifically created for your card because it's an unlicensed bootleg. However there are some good news, ASIC type 215-0910038 indicates that your GPU has a real RX 580 core. If GPU-Z reports Device ID 1002 67DF, this one should work:
It has the reference clock speeds for RX 580, supports Hynix H5GC4H24AJR (same memory as your card) and the same type of core, with the same 8-pin power input and seems to have the same display output configuration, or close to it anyway. Make a backup before you attempt to flash this.
그것들은 좋다. 라이센스가 없는 해적판이기 때문에 카드용으로 특별히 제작된 BIOS가 없습니다. 그러나 좋은 소식이 있습니다, ASIC 유형 215-0910038은 GPU에 실제 RX 580 코어가 있음을 나타냅니다. GPU-Z가 장치 ID 1002 67DF를 보고하는 경우 다음과 같이 작동해야 합니다.
RX 580의 기준 클럭 속도를 가지며 Hynix H5GC4H24AJR(카드와 동일한 메모리) 및 동일한 유형의 코어를 지원하며 동일한 8핀 전원 입력을 사용하며 디스플레이 출력 구성이 동일하거나 어쨌든 이에 가까운 것 같습니다. 플래시를 시도하기 전에 백업하십시오.
I've already lost the original bios, and now I'm leaving all hope to you...I've been running nonstop for three days already due to this problem.Thank you very much for the little information.
It's not working...
This is the only ROM file that this guy is close to, but considering that the memory is held by a micron, it seems that it is not Hynix Memory ROM.That's too bad...
Did you already try the bios I provided? Its based on the C940 board like the dump you shared with us.
당신은 이미 내가 제공한 바이오스를 시도했습니까? 당신이 우리와 공유한 덤프와 같은 C940 보드를 기반으로 합니다.
Yes, I tried, but it still doesn't work.
Are you sure? Than one should have worked. Are you getting no screen? Can you share the output of GPU-Z?
Can you tell us how you are flashing this bios and what commands you are using?
are you re installing the drivers as well?
The ROM is flashing with the ch341 tool and the driver is a MacBook Pro 16 inch, so bootcamp red version 23 May is the latest in use.
It's egpu, so you can check it right away.
Oof well that’s not generally how it should be done on the checking side; you should really be removing drivers. Are you following the correct hardware flash procedure and wiping the eeprom?
Do you have a normal x86-64 pc where you can test the card?
For Mac you need a special bios otherwise the drivers are not loaded. Not sure if it is the same for Bootcamp.
Thanks to you guys, I solved it. After flashing to CH341 with the uploaded rom file and uploading it to Windows 11, it works normally. Thank you all for your help.
I'll leave this article as it is. There may be someone who needs it like me, so the ROM file is an OCPC RX580 4g Hynix RAM model and a genuine file.
