i5-2500k cpu package temps
965 (0.25/day)
System Name Sham Pc
Processor i5-2500k @ 4.33
Motherboard INTEL DZ77SL 50K
Cooling 2 bay res. "2L of fluid in loop" 1x480 2x360
Memory 16gb 4x4 kingstone 1600 hyper x fury black
Video Card(s) hfa2 gtx 780 @ 1306/1768 (xspc bloc)
Storage 1tb wd red 120gb kingston on the way os, 1.5Tb wd black, 3tb random WD rebrand
Display(s) cibox something or other 23" 1080p " 23 inch downstairs. 52 inch plasma downstairs 15" tft kitchen
Case 900D
Audio Device(s) on board
Power Supply xion gaming seriese 1000W (non modular) 80+ bronze
Software windows 10 pro x64
i never had a cpu before where the package temps were hotter than or the same as core temps..
but the 2500k seems to be at or around the same temps as the cores..
ther is some variation to it.. but in generall the package temp is right about the same temperature as my hottest core..
if im stress testiong it will usually be a little bit lower than the hottest core temp but will generally end up at about the same.
and at idle it is usually about the same temps as my core temps.. The picture i took has it a bit hotter but the core temps drop[ed just as i hit prt screen.
is this normal for a 2500k or not? (ignore cpu fan speed running pump of a molex)
and here is a shot of aida 64 osd whilst running ibt
brandonwh64
19,542 (3.47/day)
Test with realtemp that is downloadable from TPU and test again.
965 (0.25/day)
System Name Sham Pc
Case 900D
that only shows the core temps not the package temps
brandonwh64
19,542 (3.47/day)
Hmmm I trust realtemp more than the others but it does seem odd. AIDA shows my package to be the same temp as my core.
965 (0.25/day)
System Name Sham Pc
Case 900D
all the apps report the core temps the same (near enough) so thats not an issue.. i believe the core temps are close enough to correct for me to use them for my fan speeds and oc ability and so on..
but i just dont get why cpu package is the same temp as my core..
historically package temps have always been 20 or so c lower than core temps. sometimes 30c lower. which is why i never used them and just went from the core temps.
but is the 2500k supposed to have the same temps for package as the core or not?
because if its not then it could cause throttling earlier than it should happen because the cpu temp is reported as being 20c hotter than it should be.
or is it really supposed to be the same as a core temp deliberatly for oc protection now intel offer oc insurance.
Kursah
Super Moderator
14,734 (2.20/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
Package temps have been like that on CPU's I've dealt with for years now. I wouldn't worry too much about it. If you're stable and not overheating, do what you do with it and enjoy!
965 (0.25/day)
System Name Sham Pc
Case 900D
hmm ok.. never noticed that before. always knew them to be a lot lower than core temps which is why i have always watched the core temps rather than the cpu tempi guess simply not paying attention to the cpu temps would mean i didnt notice it though.
2,693 (0.42/day)
System Name panda
Processor 6700k
Motherboard sabertooth s
Cooling raystorm block<black ice stealth 240 rad<ek dcc 18w 140 xres
Memory 32gb ripjaw v
Video Card(s) 290x gamer<ntzx g10<antec 920
Storage 950 pro 250gb boot 850 evo pr0n
Display(s) QX2710LED@110hz lg 27ud68p
Case 540 Air
Audio Device(s) nope
Power Supply 750w superflower
Mouse g502
Keyboard shine 3 with grey, black and red caps
Software win 10
Benchmark Scores http://hwbot.org/user/marsey99/
package temp is tjmax, the temp the cpu uses to work out when to throttle.
it is the only cpu temp that matters, realtemp is a useless app these days.
1,865 (0.34/day)
London
System Name Jaspe
Processor Ryzen 1500X
Cooling Stock
Memory 16Gb Corsair 3000mhz
Video Card(s) EVGA GTS 450
Storage Crucial M500
Display(s) Philips 1080 24'
Case NZXT
Power Supply Enermax 425W
Kursah
Super Moderator
14,734 (2.20/day)
Missoula, MT, USA
You're making something out of nothing IMHO. Pay attention to core temps like you have, OC, use it, play games, browse the web, move on. What you knew at one point doesn't always translate into what you know in the future in this hardware arena. Sensors and standards are changing all the time. As-long-as you're within what the specs are for the cores I'd say you have nothing to worry about.
:toast:
965 (0.25/day)
System Name Sham Pc
Case 900D
not making a thing about it, just never knew it to be like that i wasnt sure if mine was being different and had a faulty sensor or similar, or if they are all like that these days.
