i5 2500k oc/voltage
81 (0.02/day)
System Name Main
Processor AMD Ryzen 5 1600 AF
Motherboard Gigabyte AX370-Gaming 3
Cooling Arctic Freezer 34 eSports DUO
Memory 16GB DDR4 3200 CL14-16
Storage Samsung 970 1TB, Crucial BX100 250GB, Samsung Spinpoint F1 1TB, HDD 3TB
Display(s) LG M2380D, Dell U2312HM
Case Nox Coolbay TX
Power Supply XFX PRO 750W
Mouse Logitech G203
Hello, I've been running my i5 2500k at 4.2 GHZ for a year or so, using turbo boost and setting 'auto' in core voltage (1.28v was the auto setting, which I think it's not too bad).
I wanted to extract a little bit more now that it's getting a little bit old so I tried putting the turbo boost at 4.5 GHZ and every other setting untouched. It crashed while starting windows. I tried manually changing the core voltage and I was able to get to Windows at 1.312v. I didn't perform any stress test to see if it was stable because I want to know, first, if it's possible to have the voltage to go down when idle, because if I set it up manually it stays at 1.312 at all times.
I have a MSI P67A-GD65 as MB, if it helps.
So my questions are; is there a way to lower that voltage at idle? (it usually goes down to 0.96v in auto). Are those voltages safe for the CPU? Would having 1.312v constantly damage the CPU?
Regards.
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.97/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Power Supply Corsair
Mouse cheap
Keyboard under going restoration
try Windows power options
press start and type "power + sleep settings"
additional power settings
9,660 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
SpeedStep is probably disabled in the BIOS which cause the CPU to run at the highest power state all the time.
6,871 (1.11/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Software Windows 11 Pro 64 bit
Benchmark Scores https://www.3dmark.com/spy/34962882
Your board should do that automatically as your CPU lowers it's clock speeds. If you have the CPU locked at 4.5 GHz, the voltage will stay at 1.312 volts.
Absolutely, the 2500k can handle up to 1.38 volts with no issues.
As long as you have adequate cooling to keep the CPU below 80'c, 1.312 volts will not hurt your CPU.
FreedomEclipse
~Technological Technocrat~
24,401 (3.75/day)
Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
I had 1.39v for 4.9ghz on my old 2500k. So long as you keep temps as close as you can below 70'c you'll be fine. My temps used to top out below 60'c on an Antec 920 AIO i later upgraded toa Corsair H80i and temps dropped to 55-57'c on load
81 (0.02/day)
System Name Main
Case Nox Coolbay TX
Mouse Logitech G203
I have the balanced mode there. The speed goes down (1600mhz) and I haven't touched many things there. Not sure if there is an option.
I don't have a 'SpeedStep' option in the BIOS. A quick search seems to indicate that MSI calls it EIST. Its enabled.
At 4.5 ghz the temperature remains at about 56-60º, with a pretty old CM 212 (Plus or evo, one of the earliest models).
_________________________________________
This is a screenshot I just take. With EIST enabled, 4.3 GHZ and 1.29v set on the BIOS, CPUZ shows a constant Core Voltage but CoreTemp VID is variable (starting from 0.98 to 1.35). Does this mean the voltage is constant, variable, or...?
38 (0.01/day)
System Name main rig
Processor i7 8700K @4.8GHz
Motherboard GA Z370 AORUS Gaming 3
Cooling Be Quiet! Dark Rock Advanced
Memory Patriot 16GB DDR4-2800
Video Card(s) GA RTX 2070 GAMING 8G
Storage ADATA XPG GAMMIX S11 PRO 1TB M.2 + more
Case Corsair Carbide 330R
Power Supply Seasonic Focus Plus Gold 750w
I wouldn't use Auto Vcore or a fixed value , add an offset voltage till 1.32v and stress it and yes 1.35v is the safe voltage like other users already mentioned.
1,533 (0.39/day)
Grunn
System Name Indis the Fair (cursed edition)
Processor 11900k 5.1/4.9 undervolted.
Motherboard MSI Z590 Unify-X
Cooling Heatkiller VI Pro, VPP755 V.3, XSPC TX360 slim radiator, 3xA12x25, 4x Arctic P14 case fans
Memory G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3600 14-14-14 1.45v)
Video Card(s) EVGA 2080 Super Hybrid (T30-120 fan)
Storage 970EVO 1TB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB
Display(s) BenQ XL2546K, Dell P2417H
Case FD Define 7
Audio Device(s) DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5
Power Supply Seasonic 860w Platinum
Mouse Razer Viper Mini, Odin Infinity mousepad
Keyboard GMMK Fullsize v2 (Boba U4Ts)
Software Win10 x64/Win7 x64/Ubuntu
Check the voltage using HWinfo. It should show the same as CoreTemp, if it doesn't you will have to dig through your BIOS for any "adaptive" voltage settings.
81 (0.02/day)
System Name Main
Case Nox Coolbay TX
Mouse Logitech G203
If only I knew... I tried looking at different guides, saw terms I didn't know like LLC or similar then went to my motherboard and... Not the same names or directly no options.
A little bit more of digging and I found this. If what the first answer says is true, then there's not much hope for me.
The max I can go with auto voltage and turboboost is 4.3 ghz, any more than that and it doesn't boot. For me to go further I need to set a manual vcore that will stick no matter the CPU speed. What do you guys think I should do? Stay at 4.3 ghz with auto (1.28v) voltage or 4.5+ with a constant voltage?
19,375 (3.51/day)
Regards.
1. Use the offset voltage instead of manual. You need to know what your stock voltage is idle, and ise the offset to reach your stable voltage. So for instance, if you manually test and 1.25V is stable, and your stoco voltage is 1.15, your offset should be around .1V/100mv...
2. 1.3v is fine. Keep it under 1.4v-1.45v. :)
2,707 (0.74/day)
On The Highway To Hell \m/
His board doesn't have offset voltage.
https://us.msi.com/Motherboard/support/P67AGD65_B3#down-manual
http://download.msi.com/archive/mnu_exe/7681_gd65_oc_guide.zip
http://download.msi.com/archive/mnu_exe/E7681v1.1.zip
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
81 (0.02/day)
System Name Main
Case Nox Coolbay TX
Mouse Logitech G203
Garbage board...lol
Curious thing is that I actually bought this motherboard especially for overclocking in the future (now), since I read several reviews and they all said it had I don't know how many power phases and it was good for OC. Obviously I have to improve at researching for my next build. I'm also never going to buy anything from MSI again; last time I opened a ticket with them I ended up waiting about six months for a predefined answer that didn't help me in any way.
9,660 (3.27/day)
Case Phanteks NV7
How did we end talking about voltage offset and such when OP's problem was that the CPU would not switch to the lower power sates when idle ?
Just let it be , running that voltage constantly is going to be fine. If you want to be extra cautious put a fan over the VRM heatsink.
hat
Enthusiast
21,750 (3.27/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Because when you force a voltage the way FerK is doing, it stops that from happening. When you use an offset voltage, the voltage you set is applied under load, and it's still able to switch to the lower voltage during idle.
9,660 (3.27/day)
Case Phanteks NV7
Never heard of that , maybe it's something specif to Intel boards. My board has a voltage offset option too and whether I use it or set the voltage manually it still switches between P/C states like it should.
hat
Enthusiast
21,750 (3.27/day)
Ohio
As far as I know, that's just how it works with Intel systems. I assumed AMD was the same, but maybe they work differently?
