i7 10700F Low Cinebench Score
9 (0.01/day)
I saw people get 12250 Score with this CPU but I am not even close. I get 8303 score on multi-core benchmark. I have 2400 MHz single-channel 16 gb ram. Ram could be the problem because of single-channel but I dont think it would make that much difference. Any idea why this is happening? My bios settings and CPU info that I took while I was benchmarking:
Deleted member 193596
so you run a single 16gb stick with timings like back when X99 came out?
that's totally your problem. you probably have less memory bandwidth than a smartphone
9 (0.01/day)
So ram is causing the problem? I didnt think it would make that much difference (12250 to 8303)
Also do I have a different option than buying a new ram?
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Do you have 2 sticks of RAM or just one? If it is just 1 16GB stick, then no you can't really do anything until you buy more RAM. Single channel DDR4 2400MHz gives only 75% of the bandwidth of dual-channel DDR3 1600, and that was obsolete years ago. And now you have 8 cores all traying to share that extremely limited memory bandwidth.
9,671 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
The memory speed and configuration is as basic as it can be, in other words it’s just slow.
Also Geekbench is utter trash anyway.
