(i7 11700KF) Are those temps normal at idel?!
102 (0.08/day)
Are those temps normal when I'm not doing anything at all on my PC?
unclewebb
8,078 (1.33/day)
It looks like you have disabled the low power C states in the BIOS. That means your CPU will consume more power when idle and that will make it run hotter than it needs to. It is OK to do this. Some people like the lower latency and better SSD performance that disabling the C states gives you.
With the low power C states enabled, a similar 10th Gen, 10 core Intel CPU can drop power consumption and temps significantly at the same 5000 MHz that you are running.
102 (0.08/day)
I see, thank you
13,537 (2.00/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Your temps are fine. This is just me, but I only start to think about worrying about my temps when they sit above 60°C for more than a few seconds. Even then I still have lots of headroom. And typically, if they sit above 60° for more than a few seconds, that generally just means it is time to clean my air filters.
Your idle temps are in my mid 30s. And the max was just 61°C. Those are perfectly fine.
836 (0.60/day)
ÐҼƱ₸ꞨƇҤՆԹՌÐ
System Name °( ఠ ͟ʖ ఠ)°
Processor Intel | i7 _ 11700K | @ ~ 5GHz all | cooling ~ Thermal Grizzly CARBONAUT
Motherboard Asus | ROG Strix -- Z 590-E wifi
Cooling Asus | ROG Ryujin 240 2* _Noctua F PPC °3000 | 4+1* _beQuiet_ Silent/Light Wings 3 °2200
Memory G Skill | Trident Z *RGB @ 4000_ | _15-15-15-36_ |
Video Card(s) Asus | ROG Strix -- RTX 3070Ti_ #OC Edition
Storage WD black | Samsung EVO 860 / 970 EVO plus| WDC WD40 | Intenso x2
Display(s) Alienware | AW3821DW _ 38" {3840*1600} wide - curved
Case be Quiet | DARK BASE PRO 900 --- _rev. 2 --- #Silver
Audio Device(s) Asus | ROG Throne - Qi_7.1 | LOGITECH_G560 Speaker (RGB)
Power Supply be Quiet | DARK Power PRO 12 __ 1200W *titanium
Mouse Razer | NAGA Trinity (19 buttons)
Keyboard Razer | Huntsman V2 analog | Razer Goliathus (RGB) black
VR HMD Razer | Kraken Ultimate HEADSET __7.1 THX ____| DX RACER - Gaming Leather Chair_____ VR?? is odd!
Benchmark Scores See signature URL
the temps are absolutely okay! beside: the 11th GEN is much more "hotter" then the 10th ever can be. (under load to ~90°C)
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
836 (0.60/day)
ÐҼƱ₸ꞨƇҤՆԹՌÐ
the voltage is very okay aswell
yes. mid 30s is mine aswell. from cold state is a different sheet of paper
he is doing nothing. maybe surfing etc. u do not know which cooling he has
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
Never mind i was just trying to understand what ( abolutely ) means.
Joke aside.
Agree with you, temps are ok.
836 (0.60/day)
ÐҼƱ₸ꞨƇҤՆԹՌÐ
Happy Fun GIF by Big Brother
funny! :toast:
9,340 (5.19/day)
Louisiana
Keyboard G710+x3
This doesn't look normal
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
13,537 (2.00/day)
Nebraska, USA
Mouse Logitech M190
Just Core Temp misreporting one of the core temperatures.
Or the sensor is bad. It happens. Best to test with another monitor. HWiNFO64 is also very (if not too) informative. When using for the first time, I recommend you select “Sensors only” when prompted. Then scroll down to see the temps.
I thought HWINFO was more accurate
Nope. They all use the same sensor. It really is not an issue of accuracy, but rather support. HWiNFO is certainly more informative. But I use CoreTemp as my primary real-time monitor too. I just have it set to display the highest temp so I only see one temp in my system tray.
9,340 (5.19/day)
Louisiana
Keyboard G710+x3
102 (0.08/day)
Confirmed, HW-Monitor reporting right temps.
Thanks all for your inputs
5,251 (3.74/day)
Colorado, U.S.A.
Software Windows 11 Home
Body temperature; nothing to worry about at all.
9,340 (5.19/day)
Louisiana
Keyboard G710+x3
9,340 (5.19/day)
Louisiana
Keyboard G710+x3
good, to know .. it least it didn't do what CPU TEMP did
HWinfo use sensors only check box don't worry about the warning message.
It will show if you ever thermal throttle/.....
9,340 (5.19/day)
Louisiana
Keyboard G710+x3
13,537 (2.00/day)
Nebraska, USA
Mouse Logitech M190
HW monitor is crapware
No it isn't. Just because you don't like it does not mean it is crapware.
I too prefer HWiNFO, but it is far from perfect too. See this and note where it is reporting 127°C. Does that make it crapware? No. The fact is, the amount of information HWiNFO reports can be overwhelming for many.
No HW monitor is best at everything. And it is important to note these are all software based. They simply look at sensors the various hardware makers put on their products. And those sensors are cheap, low tech devices that simply express some value as a number. Any software can read that number and convert it to a temp or voltage or whatever.
So why do different programs report different values? Most often it is simply due to different sampling rates and times. Note a CPU can go from cool to overheated in just a few CPU clock cycles. And most CPUs run at 3 billion+ clock cycles every second!
The real problem is there is no industry standard for where motherboard, CPU, GPU, etc. manufacturer will place their sensors, the type sensors or how those sensors will function. Another problem is there is no industry for how different sensors (or the point they are monitoring) are labeled.
So the solution is to use a variety of HW monitors. I use HW Monitor, Speccy, HWiNFO64, TPUs own Real Temp, and I use Core Temp as my real-time solution.
9,340 (5.19/day)
Louisiana
Keyboard G710+x3
2,585 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
Do not forget AIDA64. Although, unlike the others, it is not freeware.
But, to answer the original question; looks fine to me. My 9900K idles at ambient +10°C @ 5000MHz, all C states disabled.
