i7, 6700K, I reached 5ghz!
amatris1996
2 (0.00/day)
hey guys just want to share that i managed to get 5ghz with my chip. iv tired a few times and failed.. Alot. i read up and looked at other peoples overclock's to get there 5ghz. and its helped me. if been running at 5ghz for 4 days now, its not going to be my final overclock but this was just a Goal iv had for a while. now i know some will Slate me and say its not 5ghz as you have not stress'd it But so far gaming, GTA5, Arma3,Players Unknown, all on max is fine, been on them for hours on end without crash. so in my eyes iv achieved my goal!, if anyone is interested here is my Cpuz Validation
Voltage is at 1.5v on a cool master AIO at the moment the Temps as i look over now, that is semi idle is 36c Temps for the cpu when gaming hit around 70c so not too bad..
IV also overclocked my Ram to 3000 mhz, they are HyperX rated at 2666, XMP,
Also running gtx 980 in SLI
https://valid.x86.fr/nqfgvv
peche
Thermaltake fanboy
6,709 (1.83/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
42,078 (6.63/day)
Congrats, test suggestions, get Ryzen Blender, 7Zip, Unigen Heaven and Valley, set 7zip to utilize max cores and threads and compress and extract files in zip and 7zip formats, use ryzen blender there is a thread on how to set it up, and set unigen heaven/valley to max tessalation, no lockups/reboots/bsods you should be good to go.
My rig is oranges to yours but look at my signature. Still though Good going I hope its stable for your needs
2,963 (0.84/day)
Long Island
That puts you in the top 1% as far as overclock.net's list goes
Sample Size143
Average OC4.68
Median OC4.70
Average Vcore1.38
Median Vcore1.38
Voltage is a bit too high for my taste ... never gone above 1.3875. The 3 who got that far on OCN needed 1.47, 1.583 and 1.44 ... of course that means could see 1.6 or more when advanced instruction sets present.
Where's ya ring / cache ? .... I find Graphic programs gimme lower benchies when I have cache < 3 below CP multiplier. We havent recommended synthetics since Sandy Bridge days on CPU but curious to see how ya OC stands up against RoG Real Bench. I start feelin comfy when i get 2 hours but for final test wil run for 4 hours.
Would also be curious to see what max core voltages and cores are during during the test, you only have to run the RoG RB benchmark (about 8 minutes) to get this result while recording with HWiNFO (sensors only)
3,624 (0.50/day)
System Name TheReactor / HTPC
Processor AMD 7800x3d 5050Mhz / Intel 10700kf (5.1ghz All Core)
Motherboard ASrock x670e Taichi / ROG Strix z490-e gaming
Cooling HeatKiller VI CPU/GPU Block -2xBlackIce GTX 360 Radiators - Swiftech MCP655 Pump
Memory 32GB G.Skill 6000Mhz DDR5 / 32GB G.Skill 3400Mhz DDR4
Video Card(s) Nvidia 3090ti / Nvidia 2080ti
Storage Crucial T700 2TB Gen 5 / Samsung Evo 2Tb
Display(s) Acer Predator xb271hu - 2560x1440 @144hz
Case Corsiar 550
Audio Device(s) on board
Power Supply Antec Quattro 1000W
Keyboard Corsair Gaming k70
If you delid you will probably be able to maintain 5Ghz and probably lower voltage as well. Worked for me! :)
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
Voltage is at 1.5v and the cpu when gaming hit around 70c so not too bad..
1.5V+ that's what the validation shows and 70c when Gaming.
No thanks.
I want to run a CPU not a Toaster.
2,963 (0.84/day)
Long Island
That's one that I can't wrap my head around ... lower temps makes sense ... lower voltages ?
Looking at the validation ...
says 41 cache... that makes it bit easier
says 1.536 volts ... wonder what peak is ... prolly close to 1.6 ... that's quite high for 24/7 OC
says 92 °C ... nah, that's way too high for me
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
Nice work!
Hope that AIO don't poop the bed!!!
fullinfusion
Vanguard Beta Tester
9,909 (1.61/day)
@amatris1996 try and tune down the cpu voltage a bit, imho that's to high for 24/7 but good job man!
Download AIDA64 and under system stability check un-check everything except FPU and run it.. watch those temps though as it'll hammer the shit outa the cpu ... run it for 30min or so and if it passes that cool! that'll really show you how hot the cpu will get and if the cooler can actually keep up ;)
7,054 (1.01/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data), ASUS BW-16D1HT (BluRay)
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
I don't think its worth it, after a year you might find you will have to lower the clock or it won't remain stable. You might end up with a malfunctioning processor even at stock speeds.
fullinfusion
9,909 (1.61/day)
at that voltage that's a FOR sure thing!
I only need 1.345v for the magical 5ghz :p
21,443 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
Not really... at least for that last bit.
I ran a 6700k "balls to the wall" like that around a year and it had no trouble returning to stock at the end, though it couldn't OC as well by then. It certainly degrades, but no reason to assume it will "ruin the chip."
fullinfusion
9,909 (1.61/day)
1.50v ?
I'm not as smart as you but I'm smart enough to know 1.50v is waaaay to much for 24/7 and I didn't ever mention stock degrade..
I've been in the game long enough to know better o_O
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
Yeap, those Voltages and temps are just for a quick Benchmark.
Two things that i don't mess with:
1 - Voltages
2 - temps
I do whatever it takes to lower it as much as i can.
Outback Bronze
Super Moderator
2,028 (0.42/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
1.50v ?
Ive seen voltages at 1.6 and no degrade after 3 years, although that was Nehalem with custom loop.
Would I do it? Prob not.
18,584 (2.70/day)
System Name AlderLake
18,584 (2.70/day)
21,443 (3.40/day)
System Name Pioneer
1.50v ?
Oh it's too much.
The line you quoted just mentioned a degrade to "below stock." I was refuting that and only that.
Rig was a benching/"I don't care what happens" rig. Ran for about 6 months before starting to lose OC efficiency, and a year before I got rid of the OC entirely and gave it an easy life as a stock gaming rig for a friend.
peche
Thermaltake fanboy
6,709 (1.83/day)
System Name Athenna
Nope not Delided dont want to Try that "Yet" lol
Should consider it , delid lower temps, so might help to reduce voltage too, since the voltage you are using is a bit high ....
Regards,
2,541 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 2X D5T Vario, XSPC BayRes, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Thermaltake Xaser VI
Mouse Logitech
Keyboard Logitech
Software Win11PRO
Nice job!
I was able to get my 6700K to 4.835MHz @ 1.39VCore and pass IBT at Maximum for 3 hours (30 passes) with 16GB of RAM @ 3640 15-15-15-35.
CoreMax was 71°C at 23°C ambient. Custom loop.
CPU delidded, Conduconaut on die, Kryonaut on waterblock.
