i7 haswell temps
1,227 (0.19/day)
United Kingdom
Processor Intel 10 Core i9 10900K Comet Lake CPU/Processor
Motherboard Gigabyte Intel Z490 AORUS MASTER ATX Motherboard
Cooling Noctua Intel/AMD NH-D15 Silent CPU Cooler
Memory Corsair 32GB ( 4x8) DDR4 Vengeance LPX 3000MHz Memory
Video Card(s) Zotac NVIDIA GeForce RTX 3080 8GB AMP! Extreme Turing Graphics Card
Storage Samsung 970 EVO PLUS 500GB M.2, Samsung 970 EVO Plus 1 TB PCIe NVMe M.2
Display(s) ASUS ROG Swift PG279Q 27" 2K WQHD 165Hz IPS G-Sync 2K Gaming Monitor, Sony Bravia 49" 4k uhd tv
Case NZXT Phantom 410 Black Orange Special Edition
Audio Device(s) Sound BlasterX AE 5 RGB PCIe Gaming Soundcard
Power Supply Corsair RM1000
Mouse Roccat ROC-11-812 Kone EMP Max Performance Razer Basilisk x Hyperspeed Wireless Gaming Mouse
Keyboard Roccat isku/ fx
Hi just put an i7 into my system how are these temps on idle, I don't want to overclock yet.
143 (0.04/day)
Argentina
System Name Silent Potato
Processor i5 4590 @ 3.3 / 3.7 (Stock)
Motherboard Asus z97-C
Memory 2x4GB Gskill Sniper 1866
Video Card(s) Gigabyte GTX960 Windforce
Power Supply XFX PRO650W XXX Ed.
IDLE? Not much I can say about those temps at idle. Load them, no need for burn, just go for your everyday use (gaming, etc) and load it that way.
Then post the load temps.
peche
Thermaltake fanboy
6,709 (1.84/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
Current 33c, minimum 32C max 42C?
pretty fine temps..nothing to worry about..
What are you worried about?
Regards,
4,501 (0.82/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
I only see one problem and that is the small box your put into together with two hot GPUs.
Kursah
Super Moderator
14,717 (2.23/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
Idle temps mean little. Load temps are critical. Being its a Haswell running below 100C you're fine...and you'd be fine running up there too. They thermal throttle quite nicely without totally killing CPU performance.
What do you get while gaming? Running CPU stress test like OCCT? You could also stress using an AVX test and that will almost certainly load your CPU close to the thermal throttle mark.
If your gaming temps are the screenshot posted in the OP you're in gr8 shape! Even if you load into the 80s you're just fine.
4,501 (0.82/day)
Denmark
That is not load temperatures. Look at the numbers - 43 C GPU for a 290. That can't be done even under water. If he plans to use those two 288 W beasts (http://www.techpowerup.com/reviews/Sapphire/R9_290_Vapor-X/23.html ) he better have a some 3000 rpm fans to keep the temperature down below 50 C inside the case. OC of the CPU will bring it to the 80 C even at stock if he run the GPUs flat out.
peche
Thermaltake fanboy
6,709 (1.84/day)
System Name Athenna
@cookiemonster dude tryout HWinfo64 the best shit for temp and info ....
http://www.hwinfo.com/download.php
let it run for about 30 min ... play some games for a while, then check and compare temps fella... could be better...
like this for example:
My computer has been running for a while... also this is my Work beast....
using stock cooler with old ocz paste... tomorrow i will repaste it!
Regards,
4,501 (0.82/day)
Denmark
Regards,
Why ;) If this 45 nm chip had run at 98 C since birth we all have no need to think about better coolers ect. I like (no hard facts to back it up) to run my "things" below 70 C but I did have some laptop CPUs running at +80 C for 1000 hour non-stop.
peche
Thermaltake fanboy
6,709 (1.84/day)
System Name Athenna
i have to take care of it.... this 1st gen i7 has been abused for many time, so a decent cooler, more airflow and repaste may be like a payment for the work this beast has done!
my personal PC its under total care, watercooled and excellent airflow, BTW
:peace:
Regards,
143 (0.04/day)
Argentina
Damn, and I was thinking of buying an aftermarket cooler for my 4590 because I saw it getting to 67ÂşC once. Guess I'm still thinking of my previous FX Tjmax temps.
I'm still gonna buy an aftermarket for noise tho since I can't/don't want to OC :p
1,386 (0.35/day)
Alabama, USA
Processor 5900x
Motherboard MSI MEG UNIFY
Cooling Arctic Liquid Freezer 2 360mm
Memory 4x8GB 3600c16 Ballistix
Video Card(s) EVGA 3080 FTW3 Ultra
Storage 1TB SX8200 Pro, 2TB SanDisk Ultra 3D, 6TB WD Red Pro
Display(s) Acer XV272U
Case Fractal Design Meshify 2
Keyboard Ducky One 2
Honestly I like to keep mine under 80c, but that is even a bit antiquated. Haswell is a weird chip with it's wonky TIM and IHS. You could always lap and delid and you might see a 20c drop if it came from the factory bad, or only a 5c drop if it came from the factory well pasted. The TIM between the die and IHS can be the worst insulator though, so the chips temps might be more limited by the chip than the cooler.
1,227 (0.19/day)
United Kingdom
after coming out of Battlefield 4 everything set on very high
Kursah
Super Moderator
14,717 (2.23/day)
Missoula, MT, USA
Looks like what I would expect for a heavy gaming load, and BF4 does a good job of stressing CPU, RAM, HDD and GPU.
1,261 (0.30/day)
System Name Some computer stuff
Processor Mostly Intel or AMD
Motherboard ATX or mATX
Cooling Bong Cooler
Memory DDR2-4
Video Card(s) A few
Storage Plenty Platters or SSDs or USBs
Display(s) Samsung 23"
Case 5 on the floor
Audio Device(s) There's one for my M7 Gene, Oh I have 3-4 PCI 5.1 ones.Sabrent! lol
Power Supply 750-1000W
Mouse cheap
Keyboard Used ps2 from garage sales
Software Yeah
Benchmark Scores http://hwbot.org/user/schmuckley/#Hardware_Library http://valid.canardpc.com/rbjpbg
That looks to be within spec and stuff.
You could try openhardwaremonitor, too.
Is your CPU overclocked?
143 (0.04/day)
Argentina
Yup, I don't know of any other game that stresses CPU as hard as BF4 does.
He said in OP that he doesn't want to OC yet, I guess he wanted to make sure his temps are ok before doing so.
Kursah
Super Moderator
14,717 (2.23/day)
Missoula, MT, USA
The Wargame RTS series does a pretty decent job honestly...zoom into the trees or into a hectic firestorm...that game actually fleshed out more CPU OC errors than BF4 did during my testing with my first 4770k.
But really BF4 is about the best out there for a sure-fire heavy-stress test via gaming. If you can pass BF4 and not thermal throttle, odds are most other games will do just fine. Maybe Crysis 3 maxed out would be the next one to try?
If its not overheating and you can game, then game on good friend! :D
1,261 (0.30/day)
Cooling Bong Cooler
Memory DDR2-4
Video Card(s) A few
Case 5 on the floor
Mouse cheap
Software Yeah
I wouldn't do that unless the temps looked a bit better..
1,227 (0.19/day)
United Kingdom
As you said just wanted to check my temps, tied to midi case because of space and tower is beside cupboard with water heater in so I don't think I can improve temps in any way.
1,261 (0.30/day)
Cooling Bong Cooler
Memory DDR2-4
Video Card(s) A few
Case 5 on the floor
Mouse cheap
Software Yeah
