IBASE Reveals Digital Signage PC with NVIDIA MXM Graphics Cards
47,218 (7.55/day)
BASE Technology Inc., one of the world's leading manufacturers of innovative and high-performance digital signage systems, reveals its latest SI-614 digital signage player based on 7th Gen Intel Core desktop processors and supporting NVIDIA MXM GeForce GTX 10 Series graphics cards that feature amazing speed, power efficiency and with 3X the performance of previous-generation graphics cards.
The SI-614 digital signage player is designed for digital signage applications within hospitality, retail and education sectors to empower the establishments to connect and communicate with their guests, customers and audience, reliably delivering high-quality live video and digital signage content. The standard SI-614 signage player is powered by a 7th Gen Intel Core i5-7500 processor with a NVIDIA MXM NV1050 graphics card integrated with 4GB GDDR5 128bit memory, 16GB DDR4 memory and a 128GB 2.5-inch SSD storage device.
"With IBASE's SI-614, users have the option to choose the type of NVIDIA GeForce GTX 10 Series graphics cards to enable flexible deployments based on their specific requirements, including the GTX 1080 8GD5x, GRX 1070 8GD5, GTX 1060 6GD5, GTX 1050TI-LN 4GD5, GTX 1050-LN 4GD5, and GT1030 2GD5. The SI-614 has four DisplayPort video output connectors to support four independent displays - four displays with each supporting 4K @60Hz, or just one display with 8K@60 resolution. Another display option is to have four displays with 2x2 VW setting or just one single display with 8K super-high-definition image/video (based on GTX 1080 8GD5x)," said Archer Chien, Senior Manager of Solution Product Planning Dept. at IBASE.
The SI-614 has dimensions of 256mm(W) x 160mm (D) x 69mm(H) and can be installed with the standard system bracket. The model SI-614M comes with a system motherboard and 270W power adaptor but without processor and graphics card.
SI-614 FEATURES:
  • iCONTROL intelligent energy-saving & Observer remote monitoring technologies
  • 7th Gen Intel Core desktop i7/i5/i3 / Pentium / Celeron Processors
  • NVIDIA MXM graphics card (Type-B, Up to 150W)
  • 2x DDR4 2133 SO-DIMM, dual channels, Max 32GB
  • 1x HDMI 1.4 for console, 4x DP 1.3
  • 1x Mini PCI-E (full-size) for Wi-Fi, Bluetooth, 4G LTE or capture card options
  • 1x M.2 B key (3042) for storage or 4G LTE options
  • 2x 2.5" SATA III SSD device
  • Compact and rugged design
2,182 (0.51/day)
Deez Nutz, bozo!
A freaking entry level gaming PC as high-performance digital signage PC. :eek:
2,074 (0.47/day)
Jacksonhole Florida
System Name DEVIL'S ABYSS
Processor i7-4790K@4.6 GHz
Motherboard Asus Z97-Deluxe
Mouse Ttsports Talon Blu
Keyboard Logitech G510
With a high price, no doubt, more than that entry level gaming PC
2,182 (0.51/day)
Deez Nutz, bozo!
3,869 (0.89/day)
System Name Skunkworks 3.0
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software Manjaro
MXM is pointless. it has never caught on, and you cant buy the GPUs readily. When you do find them, they cost far more then their full size counterparts (GTX 1060 MXM for $650 anybody?).
184 (0.07/day)
System Name Linotosh
Processor Dual 800mhz G4
Cooling Air
Memory 1.5 GB
Agreed. I wish they had because I have a 4th gen core i7 MSI laptop and would love to be able to upgrade the graphics. The chip is plenty fast, but the graphics card is meh and if I could slot a 10 series in there it would be perfect.
847 (0.36/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
Just because you don't use it doesn't mean it's pointless. The main reason it hasn't caught on is the demand for terirble thin and light laptops made out of plastic that throttle themselves to death. Its a sad shame they never did catch on though...
You can easily find a 1060 MXM for $300+, which IMO is decent for its ability to slot into laptops. I would still go for a 980M mxm, as it still supports LVDS signalling, and not just eDP, allowing for the use of legacy laptops with only 60HZ panels to use it
