- Oct 9, 2007
- 47,504 (7.49/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
ID-COOLING today announced SE-224-XT RGB CPU air cooler, featuring 12 V RGB Lighting on both the heatsink top cover and fan, 4 direct-touch copper heatpipes, 120 mm PWM fan and newly designed metal-mecha mounting system. This cooler is designed to cool those processors with a TDP under 180 W. With a dimension of 120x73x154mm, this cooler is basically compatible with all regular ATX cases.
Similar to SE-224-XT ARGB, this new cooler features a black coating on the heatsink and a black cover with carved logo and aesthetic lines letting the lighting through. Same high performance copper heatpipes and same metal mecha mounting system ensures a very good cooling performance. 4-pin 12 V RGB lighting is applied to both the fan and heatsink top cover so you can enjoy the RGB from all directions. You can synchronize the lighting with all motherboard RGB Sync system from including ASUS, Gigabyte, MSI, ASRock. Either way you can control the lighting with a SATA powered internal 3 button controller. There is a 1 female in 4 male output 4-pin RGB splitter included in case you want to add more RGB fans or LED strips.
The included 120x120x25mm fan adopts 2-ball bearing for durability and long lifespan. It has 8 pcs rubber dampeners on all corners of both sides, running at 900 to 2000rpm with PWM support while pushing 56.5CFM air at maximum speed, noise level measured 16.2 to 31.5 dBA. An extra fan clip set is included for a push-pull configuration.
The bundled thermal grease is named ID-TG25, which has a thermal conductivity of 10.5 W/m-K.
The newly designed metal-mecha mounting system provides secure installation of the cooler. With a full set of metal mounting brackets, SE-224-XT RGB is compatible with all mainstream CPU sockets, including Intel LGA2066/2011/1200/1150/1151/1155/1156 and AMD AM4.
MSRP for SE-224-XT RGB: 30USD/27 EURO (Excl. VAT).
Available date: Mid May, 2020.
