- Oct 9, 2007
- 46,989 (7.60/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
ID-Cooling introduced the SE-904 Twin CPU cooler. This compact D-type dual aluminium fin-stack heatsink looks big, but is designed with a compact profile. It uses a pair of 92 mm fans to push-pull air through two 40-fin stacks, to which heat drawn directly from the CPU is fed by four 6 mm-thick copper heat pipes. The 92 mm spinners feature blue LED illumination, take 4-pin PWM input, and spin between 600-2,200 RPM, pushing up to 38.5 CFM of air, each; and a noise output of 14-23.8 dBA, each. The cooler measures 100 mm x 121.9 mm x 124 mm (LxWxH), weighing 550 g. The cooler can deal with thermal loads of up to 150W, and supports all modern CPU socket types, including LGA2011v3, LGA115x, AM3+, and FM2+.
![](https://www.techpowerup.com/img/16-03-07/24a_thm.jpg)
![](https://www.techpowerup.com/img/16-03-07/24c_thm.jpg)
![](https://www.techpowerup.com/img/16-03-07/24b_thm.jpg)
![](https://www.techpowerup.com/img/16-03-07/24d_thm.jpg)
