- Oct 9, 2007
- 47,308 (7.52/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
ID-COOLING today announced IS-60 EVO ARGB low profile CPU air cooler, featuring only 64 mm total height, 6 copper heatpipes, copper base and one 120x120x15mm PWM ARGB fan plus a 92 mm x 92 mm x15 mm PWM fan. IS-60 EVO ARGB is specially designed for high performance small form factor builds with a TDP up to 130 W. It is compatible with the mainstream CPU sockets on ITX systems, including Intel LGA1200/1150/1151/1155/1156 and AMD AM4.
The thermal solution is achieved by utilizing a few key structural designs: pure copper base and pure copper heatpipes, high quality aluminium fins which soldered to the heatpipes. Similarly to IS-47K, this new cooler is carefully designed so the layout enables a 100% RAM compatibility on almost all ITX motherboards when the motherboard doesn't have high M.2 heatsink between CPU and PCI-E, for those motherboards who do have high M.2 heatsink module, this cooler can be mounted in an upward direction, which will have around 40 mm tolerance for memory.
IS-60 EVO ARGB is equipped with two PWM fans: one 120x120x15mm on top of the heatsink and 92x92x15mm fan down the heatsink. 5 V 3-pin ARGB lighting is applied to the 120 mm on the top.
Last but not least the package includes a tube of high cooling performance thermal grease ID-TG25 which has a 10.5 W/m-K thermal conductivity.
- MSRP for IS-60 EVO ARGB: $46.99 USD/ 41.99€ (Excl. VAT).
- Available date: End of Oct-Early Nov, 2020.
- Shipments starts: End of Sep, 2020.
