ID-COOLING Releases SE-225-XT BLACK CPU Air Cooler
1,519 (0.85/day)
ID-COOLING today announced the SE-225-XT BLACK CPU air cooler, featuring 5 HDT V3.0 copper heatpipes, dual 120 mm PWM fans and metal-mecha mounting kit for Intel LGA2066/2011/1200/115X and AMD AM4. This cooler is designed to cool those processors with a TDP under 220 W with 5 newly developed HDT V3.0 heatpipes and a solid built aluminium heatsink. Overall dimension is 128x108x154mm to fit all ATX platforms.
Two 120x120x25mm fans have been included to get a push-pull configuration. Rubber dampeners have been pre-attached to all corners of both sides. With PWM function, both fans will run at 700 to 1800rpm while pushing 76.16CFM air at maximum speed with noise level measured at 15.2 to 35.2 dB. The bundled thermal grease is named ID-TG25, which has a thermal conductivity of 10.5 W/m-K. The SE-225-XT BLACK CPU Air Cooler will be available for 42.99 USD / 39.99 EURO from Late Nov - Early Dec 2020.
8,226 (2.13/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
i see no mention of it clearing mem slots.
136 (0.04/day)
System Name Computer!
Processor i7-6700K
Motherboard AsRock Z170 Extreme 7+
Cooling EKWB on CPU & GPU, 240 slim and 360 Monsta, Aquacomputer Aquabus D5, Aquaaero 6 Pro.
Memory 32Gb Kingston Hyper-X 3Ghz
Video Card(s) Asus 980 Ti Strix
Storage 2 x 950 Pro
Display(s) Old Acer thing
Case NZXT 440 Modded
Power Supply Seasonic PII 600W Platinum
Mouse Razer Deathadder Chroma
Keyboard Logitech G15
Possibly stupid question - if you paint your CPU heatsink black doesn't it attract heat to the heatsink and therefore increase your CPU temps? Maybe the difference is negligible and it's nothing to worry about - but 'every little helps'?
9,675 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
It doesn't attract heat, electromagnetic radiation hits the heatsink no matter what color it is. The reason something is black is because most of the energy carried by the wavelengths which are in the visible spectrum get absorbed by the material.
Anyway, the point is that the only kind of radiation that carries any significant amount of heat is infrared and well, it doesn't actually carry that much heat. (It doesn't actually carry "heat" it carries energy)
318 (0.15/day)
Berlin, Germany
System Name Workhorse
Processor 13900K 5.9 Ghz single core (2x) 5.6 Ghz Allcore @ -0.15v offset / 4.5 Ghz e-core -0.15v offset
Motherboard MSI Z690A-Pro DDR4
Cooling Arctic Liquid Cooler 360 3x Arctic 120 PWM Push + 3x Arctic 140 PWM Pull
Memory 2 x 32GB DDR4-3200-CL16 G.Skill RipJaws V @ 4133 Mhz CL 18-22-42-42-84 2T 1.45v
Video Card(s) RX 6600XT 8GB
Storage PNY CS3030 1TB nvme SSD, 2 x 3TB HDD, 1x 4TB HDD, 1 x 6TB HDD
Display(s) Samsung 34" 3440x1400 60 Hz
Case Coolermaster 690
Audio Device(s) Topping Dx3 Pro / Denon D2000 soon to mod it/Fostex T50RP MK3 custom cable and headband / Bose NC700
Power Supply Enermax Revolution D.F. 850W ATX 2.4
Mouse Logitech G5 / Speedlink Kudos gaming mouse (12 years old)
Keyboard A4Tech G800 (old) / Apple Magic keyboard
I can tell you that it's pretty much negligible and that a certain color is just for cosmetics effect.
56 (0.03/day)
A simple UV blocking foil, usually used on the glass of store windows, should eliminate this... (we are talking about a case with tempered glass, right? lol)
Only the thickness of the black coating will add to heat building up at that point, which should be within a margin of 1C...
6,420 (1.55/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Colors (as in paint or other methods) themselves don't attract heat on their own, unless they contain some type of conductive substance, they can either absorb it or reflect it, or some combination thereof....
Which is why, in simple terms, a black material that is exposed to an energy source (sunlight/radiation/heat etc) feels a bit hotter on the surface than a white one :)
8,768 (4.01/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
That looks like it doesn't, and it's only a problem if you use silly RGBLED memory. It's the same design as my ancient NH-U12 and that clears most non-RGBELD RAM.
For €40 that's a lot of cooler for the money, but I think the biggest issue here will be how well it copes with direct-contact heatpipes instead of a solid copper base.
14,315 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Their website shows the fans sitting next to the Ram, not over them.
8,768 (4.01/day)
Case Veddha T2
Mouse MX Anywhere 2
Those images show it almost touching the DIMM in the second slot though. Like my old Noctua with no sweepback in the heatpipes, the fan will block the first slot, and I've found that to be true on every single board I've ever used this Noctua on, and that's probably 10+ boards at this point.
There are multiple workarounds though:
  1. Don't buy stupid RAM in the first place
  2. Just run two sticks if you have stupid RAM.
  3. Use a single fan in pull configuration - it's not quite as good but you don't lose too much performance and it is at least quieter.
  4. Move the front fan up a couple of fins on the heatsink - regular wire clips allow a huge amount of flexibility in fan positioning (this is what I do with my slightly stupid RAM)
  5. Buy a flagship motherboard that is wider than regular ATX and spaces out the socket a bit more.
9,916 (1.82/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
actually it looks pretty good, and basic where like you can change the fans if needed without any worries about how install it
no RGB, for some it's bad but for some it's good since RGB effect everywhere, except maybe the magic jar
318 (0.15/day)
Berlin, Germany
I also used to do #4 my self with Scythe Mugen 2 (which I still have on the PC :D)
14,315 (3.80/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Looking at the position of the mounting screw under the fans, it doesn't look like it is possible to lift the fan slightly to even use the first Dimm slot.
427 (0.20/day)
Australia
System Name Ryzen
Processor AMD Ryzen 7 5700X
Motherboard Asus TUF Gaming B550-Plus (Wi-Fi)
Cooling Cryorig H7
Memory Kingston Fury Beast DDR4 3200MHz 2x8GB + 2x16GB
Video Card(s) Sapphire NITRO+ Radeon RX 6700 XT GAMING OC
Storage WD_Black SN850 500GB NVMe SSD + Adata XPG SX8200 Pro 512GB NVMe SSD
Display(s) Gigabyte G27QC
Case NZXT H510 Flow
Audio Device(s) SteelSeries Arctis Prime
Power Supply Corsair RM650x Gold 650W
Mouse Logitech G502 X
Keyboard HyperX Alloy FPS Cherry MX Blue
This is why I like the Cryorig units; they angle the heatpipes so the whole thing sits away from the RAM area.
For example, their H7 model which I have:
