Idle Gpu temp at 54 c
10 (0.01/day)
System Name Pc
Processor Ryzen 5 2600
Motherboard Asrock b450m pro4
Cooling Stock cooler
Memory G skill Ripjaw v series 2x8gb
Video Card(s) Gigabyte 1660 super
Storage 1tb barracuda hdd
Case Cougar mg120-g
Power Supply Thermaltake 500w
Software Windows 10 pro
My idle temps for my Gigabyte 1660 super are around 54 c nowadays when i remebr it being around the mid to high 40s, not sure what caused it to increase idle temps, its not OC. Haven't tweaked any setting so im not sure what's causing this.
1,470 (0.21/day)
Processor Ryzen 1600AF @4.2Ghz 1.35v
Motherboard MSI B450M PRO-A-MAX
Cooling Deepcool Gammaxx L120t
Memory 16GB Team Group Dark Pro Sammy-B-die 3400mhz 14.15.14.30-1.4v
Video Card(s) XFX RX 5600 XT THICC II PRO
Storage 240GB Brave eagle SSD/ 2TB Seagate Barracuda
Display(s) Dell SE2719HR
Case MSI Mag Vampiric 011C AMD Ryzen Edition
Power Supply EVGA 600W 80+
Idle fan? it means the fans dont kick in until the GPU hits 60c which does result in higher idle temps but obviously lower noise and less stress on the fans as opposed to running all the time
You can check using MSI afterburner or GPU-Z to monitor the fans behaviour when the GPU is idle.
10 (0.01/day)
System Name Pc
Case Cougar mg120-g
Thank you for clearing things up, i did notice fans didn't kick in till around 55 c, so just making sure those idle temps are normal for a 1660 super?
1,470 (0.21/day)
just monitor them when your playing a game, if they remain idle until a certain threshold and then kick in when the GPU is taxed and it remains under 85c then that is normal behaviour
3,763 (1.91/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2605), upgraded from Win10 to Win11 on Jan 2024
When a GPU card is idle it should have the fan stopped and temp around or under 40C, if ambient/case temperature is in reasonable levels. Modern GPUs from nVidia or AMD are pulling around 10W when idling, and much less or even 0 W for VRAM.
@Calvin292 you should check if anything that you dont know loads the GPU core or any part of the card.
HWiNFO is a way to inpect the card and/or the system in general.
I know I have a different GPU but this will give you an idea...
Deleted member 191766
I seem to recall that a high idle temperature is actually rather important (achieved by keeping the fan slow at idle) as then the temperature variations are smaller and thermal cycling less, as it is often the solder than fails due to thermal fatigue.
