If Noctua had made a GPU Cooler...
1,850 (0.42/day)
Netherlands
System Name TheDeeGee's PC
Processor Intel Core i7-11700
Display(s) EIZO CX240
Case Lian-Li O11 Dynamic Evo XL
Audio Device(s) Creative Sound Blaster ZxR / AKG K601 Headphones
Mouse Logitech G500s
Keyboard Keychron Q6
Noctified my GTX 1070 Arctic Accelero Xtreme 3 :)
Fans are the Noctua NF-A9 FLX hooked up to a Lamptron FC5 V3 Fan Controller running at 900 RPM. So far the Temps have peaked at 44C during gaming with +135 on the Core and +500 on the Memory.
From where i sit the setup is inaudible.
1,598 (0.36/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite Wifi / B450i Aorus Pro
Cooling Lian-Li Galahad 360 / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) RTX 3080 FE / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Fractal Arc XL / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM850 / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
I can only imagine the flex on the PCB without that bracket... :eek:
the54thvoid
Intoxicated Moderator
12,642 (2.37/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
You need to match the case by covering it in beige corduroy. ...Nice...
632 (0.33/day)
This should be in the Oxford dictionary under Overkill! :D Still, as a big silence enthusiast myself, I understand the motive...
1,850 (0.42/day)
Netherlands
Ye, without the bracket it's quite a sad day for the GPU... It will sag atleast 1 CM.
It's perfectly level now.
bug
13,454 (4.02/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Is that CPU fan pulling hot air from the GPU or just pushing hot air towards it?
1,850 (0.42/day)
Netherlands
Incase someone wonders how the fans are attached.
Blue = Cooler Fins
Purple = Fans
I basically used one end of a Zip Tie as a nut, it gave me the cleanest look for mounting.
The only bulky thing dangling on the cooler is the 3-Way Y-Splitter for the Fans, but i have a closed case so i don't really care.
It somewhat is, but i tried both ways and i get better results with this setup.
The way it's mounted now dumps heat out of the case more quickly.
bug
13,454 (4.02/day)
Interesting.
6,966 (1.02/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Video Card(s) ASUS PROART RTX 4070 Ti-Super OC 16GB
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data 1 and 2), ASUS BW-16D1HT
Case Lian Li O11 Air Mini
Power Supply Super Flower Leadex Platinum SE 1000W 80+ Platinum White
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
I have a similar setup with a 140mm Yate Loon zip tied on a Arctic Mono Plus mounted to my 1060 6GB and temperatures usually sit at 50*C peak.
1,901 (0.33/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
I love it, them fans aint cheap either, props for the effort and the step up. "Necessity is the mother of all invention" , you sir stepped it up!!!! I thought for sure I was gonna see a CPU cooler strapped to a GPU.....That gives me an ideal for my Chiller on a GPU(EVIL GRIN!) :D
836 (0.20/day)
System Name White Shark
Processor 5600x
Motherboard MSI B550 Tomahawk
Cooling Noctua U12A Chromax
Memory Crucial Ballistix 16GB (8GBx2) CL16 3200 MHz
Video Card(s) RTX 3080 12gb Asus TUF OC
Storage Samsung 980 Pro 1TB OS / 860 EVO 500 GB /860 EVO 1TB/ Seagate 1TB
Display(s) LG 34GP83A-B 3440x1440p 144hz nano-ips ultrawide
Case Phanteks P500A (White/Black)
Audio Device(s) HyperX Cloud Alpha Wireless
Power Supply Seasonic 850FX focus gold 80plus
Mouse HyperX Pulsefire Haste
Keyboard HyperX Alloy Origins Core - Tenkeyless
Software W10
gj lol you got it NOCTIFIED!!!! LMAO
1,819 (0.79/day)
Arizona
System Name Space Heater MKIV
Processor AMD Ryzen 7 5800X
Case Phanteks Enthoo Pro M
Mouse Logitech MX Master 3
Keyboard Glorious GMMK 2 96%
Blue = Cooler Fins
Purple = Fans
Man, why didn't I ever think of that? Gonna start using this technique.
Starting with my media server's CPU fan.
HTC
4,612 (0.77/day)
Portugal
System Name HTC's System
Processor Ryzen 5 5800X3D
Motherboard Asrock Taichi X370
Cooling NH-C14, with the AM4 mounting kit
Memory G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB
Video Card(s) Sapphire Pulse 6600 8 GB
Storage 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III
Display(s) LG 27UD58
Case Fractal Design Define R6 USB-C
Power Supply Corsair TX 850M 80+ Gold
Mouse Razer Deathadder Elite
Software Ubuntu 20.04.6 LTS
How long until AIBs start using designs which incorporate standard 92mm fans instead of the flimsy up to 15mm fans they usually ship the cards with?
The only drawback i see is this would make the cards use @ least 2.5 slots, possibly even 3 slots thick, instead of the usual 2 slots thickness.
@ OP: out of curiosity, what were your original temps and what speeds did the GPU get with the previous GPU cooling setup VS this one?
1,850 (0.42/day)
Netherlands
It's actually 3,5 Slots right now :p
My Temp with the standard Arctic Fans was 52C @ 1020 RPM, yesterday the Noctua Fans peaked at 45C @ 900 RPM. Though i had to reapply Thermal Paste (Noctua NT-H1, which was applied previously as well), which may or may not made a difference.
The reason i wanted to get rid of the Arctic Fans is because of a "hum" i heared. They're really just cheap fans and only 12MM thick or something.
6,966 (1.02/day)
USA
Mouse Zowie EC3-C
With the Mono Plus it started rattling because I have the fan impellor facing up (I have an inverted design case), and it started killing the cheap bearing. It started making a dead bearing noise. The default Arctic fans are junky. The Arctic heatsinks are actually well designed though despite their flimsy appearance, they definitely perform really well. I was seeing a peak of 75 with the default Zotac single fan heatsink before I switched to the Arctic and have seen it hit 50*C peak now. I used a 140 Yate because they can withstand the impeller facing up without any issues since its actually an industrial fan out of a power supply with a robust dual ball bearing design, the extra size blows air around the circuit board.
Your Noctua fans look a lot more attractive than my setup :D.
HTC
4,612 (0.77/day)
Portugal
That's because the cooler is not made specifically for the card in question.
Basically, all manufacturers need to do is to raise the height of the shroud to accommodate the thickness of the standard fan as well as the fan's connection: should be able to support 3 or 4 pin connectors, like those on motherboards.
To swap fans, remove the top shroud, replace fans and close it again: no need to "strip the card naked". Done this way, i'd expect "standard GPU card thickness" to be 2.5 slots, with the occasional 0.5 extra thick card here and there.
EDIT
Or you could make one of these ...
1,850 (0.42/day)
Netherlands
Same card still (who would have thought), but a different theme now ;)
110 (0.11/day)
System Name Phenomenal1
Processor Ryzen 7 5800x3d
Motherboard MSI X570 Gaming Plus
Cooling Noctua NH-D15s with added NF-A12x25 fan on front
Memory 32 GB - 2 x 16 GB Ripjaws V CL16 @ 3600
Video Card(s) Dell RTX 3080 10GB
Storage Boot SSD: SATA 500GB - 1tb pcie3 nvme / Spinning Drives: 1tb + 1tb + 1tb + 2tb + 6 tb
Display(s) Gigabyte M27Q 27" 1440P 170 Hz IPS BGR monitor
Case Montech X3 Mesh - Black
Audio Device(s) Realtek ALC1220P
Power Supply 750 Watt Antec Earthwatts - 4 rail
Mouse Razer Viper
Keyboard Corsair K70 LUX RGB
That's one of the best looking setups I've ever seen.
1,565 (0.24/day)
The Gulag Casino
System Name ROG 7900X3d By purecain
Processor AMD Ryzen 7 7900X3D
Motherboard ASUS Crosshair X670E Hero
Cooling Noctua NH U12A
Memory 64Gb G.Skill Trident Z5 neo RGB 6400@6000mhz@1.41v
Video Card(s) Aorus RTX4090 Extreme Waterforce
Storage 990Pro2Tb-1TbSamsung Evo M.2/ 2TbSamsung QVO/ 1TbSamsung Evo780/ 120gbKingston Now
Display(s) LG 65UN85006LA 65" Smart 4K Ultra HD HDR LED TV
Case Thermaltake CoreX71 Limited Edition Etched Tempered Glass Door
Audio Device(s) On board/NIcomplete audio 6
Power Supply Seasonic FOCUS 1000w 80+
Mouse M65 RGB Elite
Keyboard K95 RGB Platinum
Software Windows11pro
Benchmark Scores [url=https://valid.x86.fr/gtle1y][img]https://valid.x86.fr/cache/banner/gtle1y-6.png[/img][/url]
Nice Build. Looks bang on. :toast:
