Iiyama Intros LED-Backlit ProLite 21.5-inch Display
47,304 (7.52/day)
Japanese display maker Iiyama released its ProLite E2271HDS-B 21.5-inch monitor. This model has a display resolution of 1920 x 1080 pixels, and uses LED-backlit illumination, which further cuts down its thickness to 18.5 mm at its thinnest point. The panel has a response time of 5 ms, contrast ratio of 1,000:1 with 50,000:1 ACR; and brightness of 250 cd/m². It takes display input from DVI, D-Sub, and HDMI. The LED-backlit consumes lesser power than CCFL illumination used in traditional LCD screens, making the ProLite consume 21W for operation. The ProLite E2271HDS-B will cost 22,800¥ (about US $258) in Japan, when it releases to market in July.
Kreij
Senior Monkey Moderator
13,817 (2.12/day)
Cheeseland (Wisconsin, USA)
That's a bit pricey for a 21" monitor, but less power consumption is a good thing.
Mussels
Freshwater Moderator
58,413 (7.91/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
its no lower than any LED, my 23.6" uses 33W (as does my housemates asus) on default settings. it seems pricey for what it is.
5,731 (1.07/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
its 1/3 lower?
Though I agree too pricey for what it is, the only thing that stands out is it's LED backlit :rolleyes:
Mussels
58,413 (7.91/day)
Oystralia
its 1/3 lower?
its smaller. ofc it uses less power. i can get mine to about 25W by lowering the brightness as well.
WarEagleAU
Bird of Prey
10,812 (1.60/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
Ive been wanting to move to an LED Monitor, but this is a bit high. LG has some nice ones, and I think I seen a 23" on the egg for less than this....I think I did anyways.
