tianhui
- May 2, 2010
- 134 (0.03/day)
- US
System Name | Orphanage * Donations Welcomed |
Processor | Intel Quad Q6600 Kentsfield G0 @ 2.4Ghz |
Motherboard | ASUS P5Q PRO LGA 775 |
Cooling | Thermaltake Big Typhoon Heatpipe CPU Cooler |
Memory | 3.0GB Dual-Channel DDR2 @ 399MHz 6-6-6-18 |
Video Card(s) | Ati Radeon 4870 512mb |
Storage | 244.14GB Western Digital WDC WD2500AAJS-75B4A0 |
Display(s) | DELL E228WFP @ 1680x1050 |
Case | CM Elite 430 Black |
Audio Device(s) | Realtek High Definition Audio (integrated) |
Power Supply | Coolermaster Silent Pro 700W modular |
Software | Windows 7 Ultimate 64-bit |
brother trying to burn something onto
memorex DVD+R DL
Got and Error "O/I Error"
Anyways- included log file
Any help would be appreciated.
Already tried 2 blank DVDs- will wait for suggestions before i try another
memorex DVD+R DL
I 19:14:39 ImgBurn Version 2.5.5.0 started!
I 19:14:39 Microsoft Windows Vista Home Basic Edition (6.0, Build 6002 : Service Pack 2)
I 19:14:39 Total Physical Memory: 3,143,996 KB - Available: 1,975,496 KB
W 19:14:39 Duplex Secure's SPTD driver can have a detrimental effect on drive performance.
I 19:14:39 Initialising SPTI...
I 19:14:39 Searching for SCSI / ATAPI devices...
I 19:14:40 -> Drive 1 - Info: PLDS DVD+-RW DH-16A6S YD11 (E (ATA)
I 19:14:40 -> Drive 2 - Info: MJYJ 6ZCHQVS 1.03 (F (SCSI)
I 19:14:40 Found 1 DVD±RW/RAM and 1 BD-ROM/HD DVD-ROM!
W 19:16:22 User accepted disc space warning and is attempting to underburn!
I 19:16:22 Operation Started!
I 19:16:22 Source File: C:\TDdownloads\Microsoft Windows 7 Ultimate Retail(Final) x86 (32 bit) and x64 (64 bit)\x64(64 bit)\en_windows_7_ultimate_x64_dvd_x15-65922.iso
I 19:16:22 Source File Sectors: 1,574,554 (MODE1/2048)
I 19:16:22 Source File Size: 3,224,686,592 bytes
I 19:16:22 Source File Volume Identifier: GRMCULXFRER_EN_DVD
I 19:16:22 Source File Volume Set Identifier: 9b77ad00MS UDFBridge
I 19:16:22 Source File Application Identifier: CDIMAGE 2.54 (01/01/2005 TM)
I 19:16:22 Source File Implementation Identifier: Microsoft CDIMAGE UDF
I 19:16:22 Source File File System(s): ISO9660 (Bootable), UDF (1.02)
I 19:16:22 Destination Device: [1:0:0] PLDS DVD+-RW DH-16A6S YD11 (E (ATA)
I 19:16:22 Destination Media Type: DVD+R DL (Disc ID: RITEK-S04-66) (Speeds: 4x, 6x, 8x)
I 19:16:22 Destination Media Sectors: 4,173,824
I 19:16:22 Write Mode: DVD
I 19:16:22 Write Type: DAO
I 19:16:22 Write Speed: MAX
I 19:16:22 Link Size: Auto
I 19:16:22 Lock Volume: Yes
I 19:16:22 Test Mode: No
I 19:16:22 OPC: No
I 19:16:22 BURN-Proof: Enabled
I 19:16:22 Write Speed Successfully Set! - Effective: 11,080 KB/s (8x)
I 19:16:45 Optimal L0 Data Zone Capacity: 787,280
I 19:16:45 Optimal L0 Data Zone Method: ECC Block Boundary
I 19:17:41 Set L0 Data Zone Capacity Succeeded!
I 19:17:41 Filling Buffer... (40 MB)
I 19:17:42 Writing LeadIn...
I 19:17:55 Writing Session 1 of 1... (1 Track, LBA: 0 - 1574553)
I 19:17:55 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 1574553)
I 19:17:55 Writing Layer 0... (LBA: 0 - 787279)
I 19:21:34 Writing Layer 1... (LBA: 787280 - 1574553)
I 19:25:14 Synchronising Cache...
I 19:25:32 Closing Track...
I 19:25:33 Finalising Disc...
I 19:26:17 Exporting Graph Data...
I 19:26:17 Graph Data File: C:\Users\Samuel\AppData\Roaming\ImgBurn\Graph Data Files\PLDS_DVD+-RW_DH-16A6S_YD11_WEDNESDAY-FEBRUARY-16-2011_7-16_PM_RITEK-S04-66_MAX.ibg
I 19:26:17 Export Successfully Completed!
I 19:26:17 Operation Successfully Completed! - Duration: 00:09:54
I 19:26:17 Average Write Rate: 7,173 KB/s (5.2x) - Maximum Write Rate: 8,362 KB/s (6.0x)
I 19:26:17 Cycling Tray before Verify...
W 19:26:24 Waiting for device to become ready...
I 19:26:45 Device Ready!
I 19:26:55 Operation Started!
I 19:26:55 Source Device: [1:0:0] PLDS DVD+-RW DH-16A6S YD11 (E (ATA)
I 19:26:55 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: RITEK-S04-66) (Speeds: 4x, 6x, 8x)
I 19:26:55 Image File: C:\TDdownloads\Microsoft Windows 7 Ultimate Retail(Final) x86 (32 bit) and x64 (64 bit)\x64(64 bit)\en_windows_7_ultimate_x64_dvd_x15-65922.iso
I 19:26:55 Image File Sectors: 1,574,554 (MODE1/2048)
I 19:26:55 Image File Size: 3,224,686,592 bytes
I 19:26:55 Image File Volume Identifier: GRMCULXFRER_EN_DVD
I 19:26:55 Image File Volume Set Identifier: 9b77ad00MS UDFBridge
I 19:26:55 Image File Application Identifier: CDIMAGE 2.54 (01/01/2005 TM)
I 19:26:55 Image File Implementation Identifier: Microsoft CDIMAGE UDF
I 19:26:55 Image File File System(s): ISO9660 (Bootable), UDF (1.02)
I 19:26:55 Read Speed (Data/Audio): MAX / MAX
I 19:26:58 Verifying Session 1 of 1... (1 Track, LBA: 0 - 1574553)
I 19:26:58 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 1574553)
I 19:26:58 Verifying Layer 0... (LBA: 0 - 787279)
I 19:31:14 Verifying Layer 1... (LBA: 787280 - 1574553)
W 19:31:48 Failed to Read Sector 787280 - Reason: No Seek Complete
W 19:31:48 Sector 787280 maps to File: \sources\install.wim
W 19:32:19 Retrying (1)...
W 19:32:26 Retry Failed - Reason: No Seek Complete
W 19:34:47 Failed to Read Sector 787280 - Reason: No Seek Complete
W 19:34:47 Sector 787280 maps to File: \sources\install.wim
W 19:34:58 Failed to Read Sector 787281 - Reason: No Seek Complete
W 19:34:58 Sector 787281 maps to File: \sources\install.wim
W 19:37:36 Retrying (1)...
W 19:37:45 Retry Failed - Reason: L-EC Uncorrectable Error
W 19:37:50 Failed to Read Sector 787281 - Reason: L-EC Uncorrectable Error
W 19:37:50 Sector 787281 maps to File: \sources\install.wim
W 19:38:01 Failed to Read Sector 787282 - Reason: No Seek Complete
W 19:38:01 Sector 787282 maps to File: \sources\install.wim
W 19:38:07 Retrying (1)...
W 19:38:15 Retry Failed - Reason: L-EC Uncorrectable Error
W 19:38:23 Failed to Read Sector 787282 - Reason: L-EC Uncorrectable Error
W 19:38:23 Sector 787282 maps to File: \sources\install.wim
W 19:38:35 Failed to Read Sector 787283 - Reason: L-EC Uncorrectable Error
W 19:38:35 Sector 787283 maps to File: \sources\install.wim
E 19:38:47 Failed to Read Sector 787283 - Reason: L-EC Uncorrectable Error
E 19:38:47 Sector 787283 maps to File: \sources\install.wim
E 19:38:47 Failed to Verify Sectors!
I 19:38:48 Exporting Graph Data...
I 19:38:48 Graph Data File: C:\Users\Samuel\AppData\Roaming\ImgBurn\Graph Data Files\PLDS_DVD+-RW_DH-16A6S_YD11_WEDNESDAY-FEBRUARY-16-2011_7-16_PM_RITEK-S04-66_MAX.ibg
I 19:38:48 Export Successfully Completed!
E 19:38:48 Operation Failed! - Duration: 00:11:51
I 19:38:48 Average Verify Rate: 2,223 KB/s (1.6x) - Maximum Verify Rate: 7,961 KB/s (5.7x)
W 19:40:25 User accepted disc space warning and is attempting to underburn!
I 19:40:26 Operation Started!
I 19:40:26 Source File: C:\TDdownloads\Microsoft Windows 7 Ultimate Retail(Final) x86 (32 bit) and x64 (64 bit)\x64(64 bit)\en_windows_7_ultimate_x64_dvd_x15-65922.iso
I 19:40:26 Source File Sectors: 1,574,554 (MODE1/2048)
I 19:40:26 Source File Size: 3,224,686,592 bytes
I 19:40:26 Source File Volume Identifier: GRMCULXFRER_EN_DVD
I 19:40:26 Source File Volume Set Identifier: 9b77ad00MS UDFBridge
I 19:40:26 Source File Application Identifier: CDIMAGE 2.54 (01/01/2005 TM)
I 19:40:26 Source File Implementation Identifier: Microsoft CDIMAGE UDF
I 19:40:26 Source File File System(s): ISO9660 (Bootable), UDF (1.02)
I 19:40:26 Destination Device: [1:0:0] PLDS DVD+-RW DH-16A6S YD11 (E (ATA)
I 19:40:26 Destination Media Type: DVD+R DL (Disc ID: RITEK-S04-66) (Speeds: 4x, 6x, 8x)
I 19:40:26 Destination Media Sectors: 4,173,824
I 19:40:26 Write Mode: DVD
I 19:40:26 Write Type: DAO
I 19:40:26 Write Speed: MAX
I 19:40:26 Link Size: Auto
I 19:40:26 Lock Volume: Yes
I 19:40:26 Test Mode: No
I 19:40:26 OPC: No
I 19:40:26 BURN-Proof: Enabled
I 19:40:26 Write Speed Successfully Set! - Effective: 11,080 KB/s (8x)
E 19:40:41 Optimal layer break position is such that L0 < L1.
E 19:40:41 Image Size: 1,574,554
E 19:40:41 Optimal L0 Sectors: 1,574,560
E 19:40:41 Calculated L1 Sectors: 4,294,967,290
E 19:40:41 Operation Failed! - Duration: 00:00:15
I 19:40:41 Average Write Rate: N/A - Maximum Write Rate: N/A
W 19:40:44 User accepted disc space warning and is attempting to underburn!
I 19:40:44 Operation Started!
I 19:40:44 Source File: C:\TDdownloads\Microsoft Windows 7 Ultimate Retail(Final) x86 (32 bit) and x64 (64 bit)\x64(64 bit)\en_windows_7_ultimate_x64_dvd_x15-65922.iso
I 19:40:44 Source File Sectors: 1,574,554 (MODE1/2048)
I 19:40:45 Source File Size: 3,224,686,592 bytes
I 19:40:45 Source File Volume Identifier: GRMCULXFRER_EN_DVD
I 19:40:45 Source File Volume Set Identifier: 9b77ad00MS UDFBridge
I 19:40:45 Source File Application Identifier: CDIMAGE 2.54 (01/01/2005 TM)
I 19:40:45 Source File Implementation Identifier: Microsoft CDIMAGE UDF
I 19:40:45 Source File File System(s): ISO9660 (Bootable), UDF (1.02)
I 19:40:45 Destination Device: [1:0:0] PLDS DVD+-RW DH-16A6S YD11 (E (ATA)
I 19:40:45 Destination Media Type: DVD+R DL (Disc ID: RITEK-S04-66) (Speeds: 4x, 6x, 8x)
I 19:40:45 Destination Media Sectors: 4,173,824
I 19:40:45 Write Mode: DVD
I 19:40:45 Write Type: DAO
I 19:40:45 Write Speed: MAX
I 19:40:45 Link Size: Auto
I 19:40:45 Lock Volume: Yes
I 19:40:45 Test Mode: No
I 19:40:45 OPC: No
I 19:40:45 BURN-Proof: Enabled
I 19:40:45 Write Speed Successfully Set! - Effective: 11,080 KB/s (8x)
I 19:40:46 Optimal L0 Data Zone Capacity: 787,280
I 19:40:46 Optimal L0 Data Zone Method: ECC Block Boundary
I 19:41:41 Set L0 Data Zone Capacity Succeeded!
I 19:41:41 Filling Buffer... (40 MB)
I 19:41:42 Writing LeadIn...
I 19:41:54 Writing Session 1 of 1... (1 Track, LBA: 0 - 1574553)
I 19:41:54 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 1574553)
I 19:41:54 Writing Layer 0... (LBA: 0 - 787279)
I 19:45:35 Writing Layer 1... (LBA: 787280 - 1574553)
I 19:49:15 Synchronising Cache...
I 19:49:36 Closing Track...
I 19:49:37 Finalising Disc...
I 19:50:21 Exporting Graph Data...
I 19:50:21 Graph Data File: C:\Users\Samuel\AppData\Roaming\ImgBurn\Graph Data Files\PLDS_DVD+-RW_DH-16A6S_YD11_WEDNESDAY-FEBRUARY-16-2011_7-40_PM_RITEK-S04-66_MAX.ibg
I 19:50:21 Export Successfully Completed!
I 19:50:21 Operation Successfully Completed! - Duration: 00:09:36
I 19:50:21 Average Write Rate: 7,157 KB/s (5.2x) - Maximum Write Rate: 8,365 KB/s (6.0x)
I 19:50:21 Cycling Tray before Verify...
W 19:50:28 Waiting for device to become ready...
I 19:50:49 Device Ready!
I 19:50:57 Operation Started!
I 19:50:57 Source Device: [1:0:0] PLDS DVD+-RW DH-16A6S YD11 (E (ATA)
I 19:50:57 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: RITEK-S04-66) (Speeds: 4x, 6x, 8x)
I 19:50:57 Image File: C:\TDdownloads\Microsoft Windows 7 Ultimate Retail(Final) x86 (32 bit) and x64 (64 bit)\x64(64 bit)\en_windows_7_ultimate_x64_dvd_x15-65922.iso
I 19:50:57 Image File Sectors: 1,574,554 (MODE1/2048)
I 19:50:57 Image File Size: 3,224,686,592 bytes
I 19:50:57 Image File Volume Identifier: GRMCULXFRER_EN_DVD
I 19:50:57 Image File Volume Set Identifier: 9b77ad00MS UDFBridge
I 19:50:57 Image File Application Identifier: CDIMAGE 2.54 (01/01/2005 TM)
I 19:50:57 Image File Implementation Identifier: Microsoft CDIMAGE UDF
I 19:50:57 Image File File System(s): ISO9660 (Bootable), UDF (1.02)
I 19:50:57 Read Speed (Data/Audio): MAX / MAX
I 19:50:58 Verifying Session 1 of 1... (1 Track, LBA: 0 - 1574553)
I 19:50:58 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 1574553)
I 19:50:58 Verifying Layer 0... (LBA: 0 - 787279)
I 19:55:15 Verifying Layer 1... (LBA: 787280 - 1574553)
W 19:55:37 Failed to Read Sector 787280 - Reason: L-EC Uncorrectable Error
W 19:55:37 Sector 787280 maps to File: \sources\install.wim
W 20:00:36 Retrying (1)...
W 20:00:44 Retry Failed - Reason: L-EC Uncorrectable Error
I 19:16:22 OPC: No
I 19:40:26 OPC: No
I 19:40:45 OPC: No
