- Oct 9, 2007
- 46,926 (7.61/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
In Win introduced the wackiest (and possibly the smartest) case fan we've seen at Computex this year, the Aurora. This is the first fan to support wireless remote control. It's also the first fan to support multi-unit daisy-chaining, so one fan's power input and control can be shared with multiple fans. This way, you can control each of your multiple liquid cooling radiators by simply pointing the remote at them.
As simply a fan, the Aurora is a 120 mm spinner, with 800 to 1,400 RPM speeds in PWM mode, and 2,000 RPM in high-voltage mode (12V). At 1,400 RPM, it can push 40.26 CFM of air, with a noise output of 23.7 dBA. The remote allows you to fine tune fan-speed (within the PWM speed range), set and switch between presets, and control the lighting. Each fan features two 6-pin power ports, with which you can daisy-chain multiple fans. Each fan ships with a connector.
![](https://www.techpowerup.com/img/16-06-02/49a_thm.jpg)
![](https://www.techpowerup.com/img/16-06-02/49b_thm.jpg)
![](https://www.techpowerup.com/img/16-06-02/49c_thm.jpg)
![](https://www.techpowerup.com/img/16-06-02/49d_thm.jpg)
