Incorrect GPU speed with Radeon DDR / 7200 DDR (retro problem)
Fred23
9 (0.01/day)
GPU-Z shows 27 MHz for GPU speed:
1,093 (0.22/day)
Botevgrad, Bulgaria, Europe
System Name Main PC/OldPC/3rd PC
Processor Intel Core i7-3770K Ivy Bridge/Core i5-3470 Ivy Bridge/Core i3-4330 Haswell
Motherboard ASUS P8Z77-V/ASRock Z68 Pro3 Gen1/ASUS H81M2
Cooling Cooler Master Hyper 212 EVO/Intel Box cooler/Intel Box cooler
Memory 32GB Corsair Vengeance/32GB ADATA/16GB ADATA
Video Card(s) SAPPHIRE R9 290 Tri-X OC 4GB/MSI RX 480 8GB/SAPPHIRE R9 390 8GB
Storage 2x1TB ADATA SSDs in RAID0+3 HDDs/2xCrucial 1TB SSDs in RAID0+3 HDDs/Samsung 1TB SSD+8TB+4TB HDDs
Display(s) Philips 274E5QHAB@HDMI + Philips 273EQH@DVI (both 27")
Case Fractal Design Define R4 Titanium
Audio Device(s) Kenwood Mini HiFi system/Microlab speakers/Philips HDMI (main)+LG TV monitor HDMI + Apple headphones
Power Supply Cooler Master Silent ProM 600 W (modular)
Mouse Microsoft Ergonomic Sculpt Desktop 2.0 (combo)@Razer Goliath mousepad (Medium speed)
Keyboard Microsoft Ergonomic Sculpt Desktop 2.0 (combo)
Software Win10 64-bit (Main PC v.1809 RTM Enterprise/2nd PC v.1903 Insider Preview Pro/3rd PC - same as 2nd)
What GPU-Z versions are you testing with? Try something from 2019-2021?
W1zzard
Administrator
27,983 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Yeah, what's the output with latest GPU-Z?
Fred23
9 (0.01/day)
& Naki:
The newer ones are not good for me. It should work under 32-bit Windows 2000, the rest doesn't matter much to me. If this is impossible, should i try 32 bit XP? (Worth more than nothing, if it is good with it.)
1,093 (0.22/day)
WinXP 32-bit should work.
Installer of latest versions won't work on WinXP, however, so you may need to use GPU-Z as Standalone/Portable (without installing it).
I am unsure if or when Windows 2000 was dropped as supported, maybe @W1zzard knows. :)
W1zzard
Administrator
27,983 (3.71/day)
Memory 48 GB
& Naki:
What error message do you get?
Fred23
9 (0.01/day)
GPU-Z-ver*.exe is not a valid Win32 application.
Thx, i will try on XP later.
7,311 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
I also got a Windows XP box I use for gaming so if we need a second test rig I will be happy to start it up and test GPU-Z too.
W1zzard
Administrator
27,983 (3.71/day)
Memory 48 GB
I looked some more into this and the problem is that our compiler only supports targeting Windows XP. This is already the legacy compiler.
I spent the last two hours trying to figure out Windows 2000 targeting, but it's simply not feasible.
For example, UPX, our exe compressor can't run binaries on Windows 2000. Another problem is that the C++ standard library uses several functions that aren't available on Windows 2000.
Fred23
9 (0.01/day)
Thanks for your time and infos & here are the screenshots under XP:
W1zzard
Administrator
27,983 (3.71/day)
Memory 48 GB
Why so many screenshots?
543 (0.36/day)
Not Chicago, Illinois
System Name Desktop-TJ84TBK
Processor Ryzen 5 3600
Motherboard Asus ROG Strix B350-F Gaming
Cooling ARCTIC Liquid Freezer II 120mm, Noctua NF-F12
Memory B-Die 2x8GB 3200 CL14, Vengeance LPX 2x8GB 3200 CL16, OC'd to 3333 MT/s C16-16-16-32 tRC 48
Video Card(s) PNY GTX 690
Storage Crucial MX500 1TB, MX500 500GB, WD Blue 1TB, WD Black 2TB, WD Caviar Green 3TB, Intel Optane 16GB
Display(s) Sceptre M25 1080p200, ASUS 1080p74, Apple Studio Display M7649 17"
Case Rosewill CRUISER Black Gaming
Audio Device(s) SupremeFX S1220A
Power Supply Seasonic FOCUS GM-750
Mouse Kensington K72369
Keyboard Razer BlackWidow Ultimate 2013
Software Windows 10 Home 64-bit, macOS 11.7.8
Benchmark Scores are good
They all show different readouts for clocks.
#1-3 are running GPU-Z 2.25.0
#1 lists nan(ind) MHz for GPU and Memory clock, and -nan(ind) GPixel/s and GTexel/s.
#2 lists 0 MHz for Memory clock.
#3 has nothing for Pixel and Texture fillrate, 2 MHz for GPU clock and 14 MHz for Memory clock.
#4 is running GPU-Z 2.28.0, and I think it's showing everything correctly?
#5 is running GPU-Z 2.38.0, and it's the same as #4 but with Resizable BAR listed as "Not supported".
Fred23
9 (0.01/day)
"GPU-Z 2.28.0, and I think it's showing everything correctly?"
No. Different results, but none of them is the good one.
W1zzard
Administrator
27,983 (3.71/day)
Memory 48 GB
Could I use AnyDesk to log onto your machine to (try to) fix the clock readings? (Tomorrow, about to head to bed)
64K
6,773 (1.71/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
Mainstream support ended in 2005 and extended support ended in 2010.
1,093 (0.22/day)
No, this does not apply - I meant GPU-Z support for Windows 2000. :)
(and not Microsoft support, the dates of which are easily available in many locations, and which was not discussed at all)
64K
6,773 (1.71/day)
Processor i7 7700k
My bad. I only use GPU-Z every once in a while and I wasn't aware that older versions of Windows get dropped from support. I thought GPU-Z was just about displaying info about the GPU.
W1zzard
Administrator
27,983 (3.71/day)
Memory 48 GB
I'm with you. If there was a reasonably easy way to keep support for Windows 2000, I'd definitely use it. The problem is that the whole toolset has moved on. Even targeting Windows XP isn't officially supported anymore.
1,093 (0.22/day)
@W1zzard -- all or almost all Windows software in the world lists the supported/required Windows OS versions (often with minimum CPU generation(s)/types listed too for system tools such as GPU-Z) in their Downloads page(s).
I think GPU-Z download page lacks such info currently? :) Could you please add it?
I.e. something like -- Supported Windows OS versions: Windows 10, Windows 8/8.1, Windows 7, Windows Vista, Windows XP (partial support, no Installer).
Or if you prefer shorter text -- "Windows XP (partial support, no installer) up to Windows 10" (or similar wording of your choice).
IF latest GPU-Z versions also require the AMD/Intel CPU being used to have a certain instruction set present, IMHO you should list that too - i.e. say "SSE2 required for CPU" (or similar wording as you prefer, with whatever instruction sets are required).
EDIT: Okay, sorry about that - looking again, it seems the WIndows OS versions are listed, but not in Downloads page. :oops:
They are on the main product page, here: https://www.techpowerup.com/gpuz/
You might still want to add a brief line on supported Windows OS versions to the Downloads page too, if possible.
Also, it does not say WinXP cannot use the Installer anymore - I think this should be explicitly mentioned too. :)
1,978 (1.48/day)
Lithuania
System Name Shizuka
Processor Intel Core i5 10400F
Motherboard Gigabyte B460M Aorus Pro
Cooling Scythe Choten
Memory 2x8GB G.Skill Aegis 2666 MHz
Video Card(s) PowerColor Red Dragon V2 RX 580 8GB ~100 watts in Wattman
Storage 512GB WD Blue + 256GB WD Green + 4TH Toshiba X300
Display(s) BenQ BL2420PT
Case Cooler Master Silencio S400
Audio Device(s) Topping D10 + AIWA NSX-V70
Power Supply Chieftec A90 550W (GDP-550C)
Mouse Steel Series Rival 100
Keyboard Hama SL 570
Off-topic:
Those Radeons look so nice
