- Feb 24, 2023
- 2,600 (4.48/day)
- Russian Wild West
System Name | DLSS / YOLO-PC |
Processor | i5-12400F / 10600KF |
Motherboard | Gigabyte B760M DS3H / Z490 Vision D |
Cooling | Laminar RM1 / Gammaxx 400 |
Memory | 32 GB DDR4-3200 / 16 GB DDR4-3333 |
Video Card(s) | RX 6700 XT / R9 380 2 GB |
Storage | A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD |
Display(s) | Compit HA2704 / Viewsonic VX3276-MHD-2 |
Case | Matrexx 55 / Junkyard special |
Audio Device(s) | Want loud, use headphones. Want quiet, use satellites. |
Power Supply | Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup] |
Mouse | Don't disturb, cheese eating in progress... |
Keyboard | Makes some noise. Probably onto something. |
VR HMD | I live in real reality and don't need a virtual one. |
Software | Windows 10 and 11 |
As title says, I'm wondering if buying a GPU with, say, two 8-pin power connectors to ultimately solder a third one to it so I could get my OC potential higher and per-cable load lower makes any sense.
I'm aware of what VRMs are and how to make sure it can handle another one 8-pin connector.
I'm also aware that no double 8-pin GPU is enough for what I want to do and triple 8-pin GPUs are not an easy find so I'm considering a plan B.
I also don't give a zap about warranty and my RMA eligibility. I am going full YOLO with this purchase.
What I'm not aware of is what I should consider besides VRM and temperatures. I know how to make it cool enough. I don't know what else matters. I also don't know how to make GPU "see" the third power connector and actually use it.
The most likely frankensteining candidate is an RX 6900 XT with the PCB of the reference design. Less likely, a 6800 XT.
Answers like "it's stupid" are ignored because I know it's stupid and answers like "get a job" are also ignored because getting a job is also stupid.
