Inno3D GeForce GTX 560 SE Pictured
47,291 (7.53/day)
Here are some of the first pictures of Inno3D GeForce GTX 560 SE. Inno3D implemented NVIDIA's new SKU that's competitive with Radeon HD 7700 series, by designing a compact graphics card that's backed by relatively-powerful cooling. The PCB is very short (good for compact cases), and uses a simple 4+1 phase VRM to power the card. It features 1 GB of GDDR5 memory sitting on a 192-bit wide memory interface. The GTX 560 SE packs 288 CUDA cores, and clock speeds of 776/1553/953 MHz (core/CUDA cores/memory actual). Inno3D GeForce GTX 560 SE is cooled by a custom dual-slot cooling solution. This cooler makes use of two aluminum fin stacks, to which heat is conveyed by four 8 mm-thick nickel-plated copper heat pipes. The fin stacks are then ventilated by two 80 mm fans. The card has been tested at the source.
7,284 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
i was wondering why, does it miss 2 memory blocks on the pcb?
does this mean this pcb was made to do more than 1024gb? maybe 1280mb or something?
47,291 (7.53/day)
7,284 (1.03/day)
what? maybe they r planing about make it a GTX560 Ti 488 at some points, i just think it looks weird missing 2 memory blocks ^^;
and when u think about it, if that's layout is 1024mb than the ram block will be 170,66mb pr. block and that doesn't sound right o_O
2,214 (0.44/day)
System Name Ultima
Processor AMD Ryzen 7 5800X
Video Card(s) Palit GeForce RTX 4070 12GB Dual
Storage WD Black SN850X 2TB Gen4, Samsung 970 Evo Plus 500GB , 1TB Crucial MX500 SSD sata,
Display(s) ASUS TUF VG249Q3A 24" 1080p 165-180Hz VRR
Case DarkFlash DLM21 Mesh
Power Supply Corsair RM650
Mouse Rog Strix Impact 3 Wireless | Wacom Intuos CTH-480
Keyboard A4Tech B314 Keyboard
hint: 192bit memory interface
It uses similar memory configuration as the GTX 550 Ti:
nVidia did some modifications in the memory controller for the GTX 550 Ti, in such a way that it has three 64bit memory controllers, and each controller is controlling 2 32bit memory chips. 4 of the memory chips are 128MB in size while the remaining 2 are 256MB in size totaling 1024MB of memory at 192bit. The Raster Operators (ROP) are also tied to the memory chips, and each chip has 4 ROPs in it so in simple terms:
Note: GTX 550 Ti has 6 memory chips
Memory Controller 1 - 64bit - 128MB 32bit memory w/4 ROPs + 128MB 32bit memory w/4 ROPs
Memory Controller 2 - 64bit - 128MB 32bit memory w/4 ROPs + 128MB 32bit memory w/4 ROPs
Memory Controller 3 - 64bit - 256MB 32bit memory w/4 ROPs + 256MB 32bit memory w/4 ROPs
Total of - 192bit 1024MB memory w/ 24ROPs
In terms of memory controller, its really different from GTS 450 since it had to balance the load on the odd memory configuration, and thats up to the drivers.
1,964 (0.41/day)
Sydney NSW, Australia
System Name Shoebox Sandwich | Razer Blade 14 | Synology DS423+ w/ 4X8TB WD Red | ROG Ally | Mac mini
Processor AMD Ryzen 7 7800X3D | AMD Ryzen 9 5900HX
Motherboard ASRock B650E PG-ITX WiFi | Razer thing
Cooling NZXT Kraken 240 RGB w/ Lian Li P28 + Corsair AF120 Slim | Double fan vapour chamber
Memory G.Skill Flare X5 2x16GB 6000MHz CL32 DDR5 | 16GB 3200MHz DDR4
Video Card(s) Sapphire Radeon RX 7900 XTX | NVIDIA GeForce RTX 3070 8GB
Storage Seagate FireCuda 520 2TB + Lexar NM790 4TB | 1TB NVMe SSD + 2TB NVMe external SSD
Display(s) Alienware AW3423DW & Sony A90K 42" | 14" QHD IPS 165Hz & Sony BRAVIA 9 75" TV
Case FormD T1 - v2.1 - Titanium colourway w Aluminium mesh | Razer Blade 14
Audio Device(s) Schiit Hel 2E (Focal Clear & HiFiMAN HE-4XX & DROP PC38X) | Samsung Q950A
Power Supply Corsair SF750 Platinum | Razer 230W brick
Mouse Razer Viper Ultimate Mercury | Roccat Kain 202
Keyboard Womier SK75 (Green) | Corsair K63
VR HMD Oculus Quest
Software Windows 11 Home | Windows 11 Home
Benchmark Scores 2022 MINI Countryman SE PHEV Hybrid ALL4 | British Racing Green| Malt Brown Interior| YOURS Trim
hmm looks like there could be some turbulance between the two fans.
7,284 (1.03/day)
but why mix memory sized? it doesn't make much sense to me in the end, even making a 2gig card they will just do it like that, instead of using like 256mb chips all around bcs it's cheaper to mix or bcs they don't wanna go above the bandwidth it's released with?
